Question about Sony PlayStation Portable (PSP) Console
Cant find the files on memory stick on my psp
    Guru:
  • 374 Answers
What are you using to look at the files(the psp itself, a pc through usb or a memory card reader)???????
Posted on Jun 04, 2010
3 Suggested Answers
  • 77 Answers
SOURCE: my psp cant read my memory stick
If you cannot format it via card reader on your PC, I'd say the card is boned and you should try returning/exchanging it.
Have you tried on another PC?
Posted on May 16, 2008
SOURCE: about psp version 3.95
All of you need to get custom firmware installed onto your psp. The latest edition is 4.01 M33 for which instructions can be downloaded from the internet. There is NO WAY sony would let you copy games to a memory stick and just play them on your psp otherwise everyone would just be swapping games between each other. Custom firmware is a hack to enable these copies (er...I mean "back-ups") be played on your psp from the memory stick. It is risky if you get custom firmware from an unreliable source or if you don't know what you are doing. Youtube has some valuable video guides to help.
Posted on Aug 20, 2008
My psp memory card dont let me put stuff in
you may have to format the card. Also make sure your card is not placed in the lock position.
    How to Fix a PSP Memory Stick
  1. Step 1 Upgrade your PSP's Firmware (its operating system) before doing anything else. Firmware 5.0 solves many software problems that are encountered with older memory sticks. You can upgrade it by simply connecting your PSP to any wireless connection through its WiFi. Once a connection is established, the PSP will update itself automatically.
  2. Step 2 Check to see that your memory stick's plastic tongs, the small sticks that separate each connection, are straight. If one is bent, your PSP will not recognize the stick.
  3. Step 3 Remove your memory stick if it still does not work. Insert it into a PC with a memory stick slot. You will most likely be able to see all of your saved files. If so, continue to the next step. If you still cannot see your files, then your memory stick is defective, and it is not the PSP's fault.
  4. Step 4 Copy your files from the memory stick to the hard drive.
  5. Step 5 Format your memory stick using the "Format Disk" option in Windows. Open Windows Explorer, and find your memory stick listed in the "Drives" section. Right-click on the memory stick, and click "Format." Follow the on-screen instructions in the windows that pop up.
  6. Step 6 Insert your memory stick into your PSP. It should recognize the disk now. However, you now need to format the memory disk again with the PSP.
  7. Step 7 Go the PSP main menu, and select "Settings." Then select "Format Memory Disk."
  8. Step 8 Put your memory stick back in your PC, and return the files you removed earlier. When you reinsert the stick into your PSP, it should now see all the files.
Mar 25, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
Memory card corrupted , cant retrieve saved games
Try a "Reformat" or your memory card. here's how.
I recommend that you do this every so often regardless, and particularly when you first buy a memory stick. Reformat it, on the Sony PSP. So that anything added by the memory stick manufacturer is removed, along with any hidden files you might have accidentally added.
You can format any size Memory Stick Duo in the Sony PSP by doing this:
  1. Push the little HOME button on the bottom left of the face of the unit.
  2. Use the arrow keys to move to the SETTINGS area, then move the up and down keys until you get to System Settings.
  3. Once you are there, click on the "X" button and scroll up and down as needed to find Format Memory Stick. Click on "X" again to select that option.
  4. The Sony PSP will now confirm that you want to reformat the memory stick (which removes every file and game save thereon, of course): choose yes and it'll format in just a few seconds.
Now you have a pristine new Memory Stick to work with and should have no problems with music, photos or other material you might wish to copy onto your PSP.
Feb 12, 2010 | Sony PlayStation 2 (PS2) Console
I cant play the game in memory stick..
you'd first have to downgrade your psp. try to lower it to 3.50 or 4. something. then insert the .pbp file... this file is a hack.. or an upgrader for a psp.. once you do this.. your psp will be back to version 5.03 but now you can play downloadable games.
Jul 27, 2009 | Sony PlayStation Portable (PSP) Console
PSP not detecting files on a 4gb memory stick PRO Duo
There are certain folders that the PSP puts on the stick when it formats it. Format the new stick on the PSP first. Then, you can transfer you files to it.
Jun 28, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
Cant find the memory stick duo in
lol well dude make sure it has nothing on it... go to format memory card in system settings option in the psp
Jun 28, 2009 | Sony PlayStation Portable (PSP) Console
Our computer cant access our psp memory card
fe4875a.jpg Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} PSP uses Sony Memory Stick Pro Duo and you need an adaptor (see picture) to use it on your external card reader or your laptop’s built-in card reader. Also, please check your card reader if it supports Memory Stick Pro Duo.
If you already have an adaptor but still doesn’t work, you can buy a PSP USB data cable to transfer files between your computer and PSP.
Apr 09, 2009 | Sony PlayStation Portable (PSP) Slim...
I cant play games on my psp v5.01 in its memery stick
u need to find a MP4 game and put it into e folder tt said MP4.. but is hard to find those game.. if u find some.. pls let me noe.. thanks..
Jan 22, 2009 | Sony PlayStation Portable (PSP) Slim...
Psp problem
The psp memory stick comes with an adapter, which is where u need to put the memory stick into before trying to place it into a card reader. once you have done that it will appear as a removable disk in my computer. you will then have to open that folder and there is where u can view ur files.
please rate me. thank you.
Dec 02, 2008 | Sony PlayStation Portable (PSP) Slim...
I tryed putting a video on my psp and it didnt pop up in the videos but took up 400 mega bites of memory i cant get it off
You can play files of the following types on the PSP system.
  • Memory Stick Video Format
  • - MPEG-4 Simple Profile (AAC)
  • - H.264/MPEG-4 AVC Main Profile (CABAC) (AAC) and Baseline Profile (AAC)
  • MP4
  • AVI
  • - Motion JPEG (Linear PCM)
  • - Motion JPEG (μ-Law)
Copying a file manually Copy the video file to Memory Stick Duo media to enable it to be played on the PSP system. Using a PC, create a folder named "VIDEO" within the Memory Stick Duo media, and then copy the file into that folder.
Jul 07, 2008 | Sony PlayStation Portable (PSP) Console
Usb cable
Just like sorta of add-on to szwaan's answer:
You must have a memory stick to put music into your psp such as mp3 files, the psp itself does not have any internal memory for you to store any music files whatsoever.
if you got a memory stick already, connect your psp to your computer via usb cable, select usb under the setting section of your psp, and the memory stick drive will appear in your "my computer", so you can drag your music into the Music folder of your memory stick and play them from your psp.
Dec 21, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
91 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
