Question about GE DBXR300EFWS Electric Dryer
Settings know very loose and dryer will not turn on
  • GE Master
  • 8,220 Answers
settings know very loose and dryer will not turn - 357b860.jpgThe non-resetable limit(fuse) is located here on the back inside. You gonna need to unplug that machine and take it outside so you can clean it up a bit and repair whats broken. Start here4aab275.jpgthen remove the front and take a look see More here
Posted on Jun 04, 2010
The POWER button fell inside and it won't turn the dryer on. How do we fix it on our own?
take the panel off and place back in from inside the panel should be able to remove the back perhaps
Jul 31, 2014 | GE Dryers
Sparks coming out the back of dryer where plug is at dryer not wall
Sounds like the wires are arching. My Questions is this a news set up? First thing unplug it before doing anything. Don't even touch the dryer before unplugging it. Then look at the back of dryer are the wires loose tighten them to the terminals. If they are not loose not maybe they are wired wrong make sure your color code matches up. What are your color codes? You can search your dryer model and come up with a diagram. That is all I can do without seeing it in person or knowing the model.
Jul 17, 2013 | Dryers
Whirlpool Dryer is not heating
suspect element. refer to wiring diagram. unplug dryer. unscrew or unplug wires from element. use multimeter set to "continuity," and touch leads to ends of element where you removed wires. If no meter reading or "beep," element is probably bad. If you have continuity, suspect loose wires or switches. That's all I know!
Apr 14, 2013 | Dryers
Dryer is Making a really loud noise
Your drum has bearings that turn it easier. They are worn or loose.you will need to have them replaced to get rid of the noise. How old is this dryer.
Feb 22, 2013 | Dryers
I have a Whirlpool electric dryer, it is a Duet with a model # of: GEW9250PW1. When I try to select the the "normal" setting on the automatic side, it lights up the delicate light and has the...
Is the selector knob loose on the stem? Look on the knob to see if there is a set screw of some sort that you can tighten to set it where it belongs, it just seems it's loose and isn't pointing to where it should. Let me know if this works or not,
Please rate and comment, Thank you,
Joe
Sep 01, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer turns on but the drum will not turn
Have you checked to see if the belt is loose? If it is tight and still routed correctly around the drum, motor and tensioning arm, I would suspect your motor needs replacing.
Hope this helps...
Oct 06, 2009 | Kenmore 63942 Dryer
Maytag neptune dryer has three tumbler arms and one is loose. I can see set screws but do not know how to get to them.
Unplug Unit.
Refer to pages 5-2 and 5-3 of the manual below (Should be similar to yours) to see how to expose the drum by lifting the top of the machine. Then turn drum very slowly and only until the screw holes for the missing fins are within your reach. Most of these dryers have two sizes of fins make sure you order the right one if you need to replace them.
Good Luck
Download this file : Maytag Dryer
Sep 07, 2009 | Maytag Dryers
Maytag proforma gas dryer no heat
The model says electric and is listed as gas. If it is electric. Move all the settings (exercise the controls) If that does not work Turn both of the breakers off at your electric panel and back on. If one feels loose you know it may have tripped and you just reset it. Your drier will work fine now. Just turn it on.
Aug 12, 2009 | Maytag PYE2300AY Electric Dryer
GE dryer does not run and just hums
Yes, open it. You'll probably find a broken or loose belt.
More help?, let me know.
May 09, 2009 | GE Profile DPSB619ED Electric Dryer
Neptune gas dryer
Did you check the baffles( fins inside the drum) loose of broken.
Can you turn it by hand and hear the same sound? does it turn easy or very hard...let me know I can help
krazytech
Mar 23, 2008 | Maytag Neptune MDG5500AW Gas Dryer
GE DBXR300EFWS Electric Dryer Logo
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
