Question about Magic Chef MCD1611ST Microwave Oven
Turntable works, lights work, but the heating element doesn't
I purchased this microwave based on the fact that we knew the Magic Chef brand from previous positive experiences with Magic Chef!! However, this product has left a very negative impression with me..we purchased this product the first week of February from our local Home Depot, even paid for an extended warranty, replacement for free from Home Depot, however, our paperwork was never filed with Home Depot.
I have not been able to use this microwave since the second week of March, which means, I barely was able to enjoy the benefits of a microwave at all..
Home Depot is not helping at all so maybe you as the manufacturer of this product can help us straighten out this problem..
5 Suggested Answers
dmftrucker
  • 1922 Answers
SOURCE: Microwave won't Work
sounds like a fuse for starters, remove outer cover there will be a white cartridge appx 1"longX1/8"dia this is a ceramic fuse avail at most hardware stores in 15 or 20 amp configurations, if this blows again after repl suspect a faulty H.V. Diode/H.V. Capacitor, or the magnetron tube unless while inside unit you see something obviously wrong 2 fuses are under $5.00
Posted on Sep 27, 2009
Testimonial: "Thanks for the help! I'll try it and let you know."
MicrowaveSvc
  • 9085 Answers
SOURCE: I purchased a Magic Chef under cabinet microwave
Since it's a clearance item, it may not have a warranty.
But you should check with Home Depot on that if you haven't already.
Otherwise, you'd have to have it repaired yourself.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Oct 11, 2009
  • 8404 Answers
SOURCE: no heat on magic chef microwave
Check the door safety interlock switches.
Posted on Dec 29, 2009
KevinWhite
  • 1902 Answers
SOURCE: My magic chef microwave model
Hello & Welcome to FixYa
The door switch is bad and needs replacement, as it is bad so the control senses that the door is not closed so won't heat. Please get back to me if you have any other questions.
Kevin
Posted on May 14, 2011
Magic chef microwave
There's a fuse that has blown. look for it near the bulb socket or on the main board inside the unit.
Jan 24, 2014 | Microwave Ovens
Magic chef microwave runs backwards with door closed and no time set - works normally when time is set and door is closed - any ideas?
Probably a bad door switch or door switch mount. See help file here.
It's normal for a microwave turntable to run either direction at random. That's common in such AC motors.
Dec 26, 2012 | Magic Chef Microwave Ovens
Appliance will not heat,but operates
The problem is in the magnetron the heart of the system, or the inverter board, if microwave oven is 7 years old or less.
Jun 08, 2012 | Magic Chef CMV1000B Microwave Oven
Turntable
The turntable motor is defective, since it is 6 months old your warranty should cover the repair or replacement of the microwave oven.
Apr 04, 2012 | Magic Chef Microwave Ovens
Magic Chef MCO 153 UQ heats but doesnt' turn
You can still use it, but must be aware that this is a relatively high power microwave, so food will burn if it isn't turned.
Jul 28, 2009 | Magic Chef Microwave Ovens
Magic Chef M/W MCD990ARB - heat quit
Mine did the same thing: Replaced the HV Cap and diode - works fine now.
Jul 05, 2009 | Magic Chef MCD990W Microwave Oven
Microwave not heating up food
This model is a lower-end type that probably didn't cost very much. Since it's over 2 years old, you have no warranty left. Most appliance repair shops charge extra $$ for servicing installed items in the home. You'd probably be better off purchasing a new comparable model. The labor fee alone might equal what you paid for it.
Jan 08, 2009 | Magic Chef Microwave Ovens
Microwave oven does not heat anything
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
l;hkhtguii
Oct 13, 2008 | Magic Chef MCP13E1ST 1000 Watts Microwave...
Turntable not turning
check control circuit, and related spares.
Oct 29, 2007 | Magic Chef MCD1311ST Microwave Oven
Magic Chef Over-Range Microwave Oven Model:MCO153UBF
The turn table and fan are connected in series with the bulb,as you have mentioned that you have replaced bulb,so please check again for any loose contact on bulb holder or bulb continuity again.
Aug 03, 2007 | Magic Chef CMV1000B Microwave Oven
Magic Chef MCD1611ST Microwave Oven Logo
65 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
