Question about Whirlpool GU2400XTP Built-in Dishwasher
Loud houling noise when in the wash cycle mode only
There is no unusual noise when pumping out or filling.I have checked the filters & the spray jets,everything looks nomal.The machine was bought in 12/12/06.The noise started about 2-mons.ago,it is not getting any worse or better. Model #u2400xtpt Ser.ft2010050 p.s.there are no leaks coming from the unit. Dan;
    Sergeant:
    Champion:
  • 311 Answers
Bad bearings in wash pump- replace it.
Posted on Jun 05, 2010
Loud sounds
Many Frigidaire dishwashers come with the promise of being the "quietest dishwasher in its class," according to Frigidaire. However, a quiet dishwasher doesn't necessarily mean that the dishwasher is silent, as some noises are normal. It can take some troubleshooting at times to determine if a noise coming from the dishwasher is typical or if it indicates a larger problem Listen for the sound of water filling and draining throughout the wash cycle. These sounds are normal and do not indicate an issue.
  • 2 Pay attention to the drain motor, which operates at the beginning of each cycle. This noise should be fairly quiet and should not sound like a loud, grinding or banging sound.
  • 3 Note that the sound will change when the wash cycle moves between the lower and middle spray arms. This sound should be temporary and fairly quiet.
  • 4 Look for hard items in the dishwasher grinder or filter if a loud crunching, buzzing or grinding sound is heard. The dishwasher can typically grind up these items within one or two cycles, but the item may be lifted out and discarded to eliminate the sound.
  • 5 Remove the bottom rack and spray arms from the bottom of the dishwasher if there is a loud noise coming from the dishwasher that does not resolve itself. Look inside for the impeller, which is round and spins. Remove any debris that may be clogging up the impeller or pump.
  • Oct 07, 2011 | Frigidaire Professional Series 24 in....
    Loud continuous buzzing noise while dishwasher is running
    Hi hope you are well have you checked that the dishwasher isnt touching your units either side their should be a slight gap either side you will get this noise if it is touching anything at the sides or pressed up against something at the back if this is not the problem.
    If it is making the noise through most of the wash cycle the the chances are it isnt going to be a pump on the way out the only other thing it could be is the motor that turns the spray arms around and it could be either the top or bottom usually if you can get to the motors you can oil the moving parts as sometimes thse get dry over time.
    Try the first sollution first try moving the dishwasher a bit and then try it again if still noisy then the chances are one of the motors has got noisy on the spray arms it wouldnt be the pumps as the noise continues through most of the wash.
    Some times just moving the dishwasher will recitfy the problem as the same happens with fridges and freezers if it has been knocked and is not level or is touching a unit you will get a slight vibrating noise so try moving it a bit.
    Let us know how you get on
    Nov 28, 2007 | Whirlpool 24 in. DU1055XTPS Stainless...
    LG Dishwasher LD-1403W - loud whirring noise during wash
    We had same problem machine same age, had a service person in and the found that the motor was dying. LG wouldn't cover saying that it was normal wear and tear. b
    Jan 01, 2010 | LG Dishwashers
    Scratching noises
    hithere well if its stopped why worry.......probably due to debri in filter or drain pump.....remove filter ca and check......then check drain pump
    regards Sir Galahad
    Aug 20, 2009 | Washing Machines
    My GE washing machine is stuck on agiation mode.
    HUMMING NOISE MAYBE OVERLOAD ON MOTOR OR PUMP SO DEAL NOW WITH DRAIN PROBLEM 1ST IT MAYBE NEED TO DRAIN FILTER CLEAN
    THANKS
    Jul 15, 2009 | Washing Machines
    Washing machine makes buzzing noise
    Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
    Nov 06, 2008 | Fisher Paykel EcoSmart GWL15
    Screeching Noise From Fisher & Paykel GWL115 Washer While Filling
    if its while filling may be water pressure try turning tap down (hot)
    Apr 04, 2008 | Washing Machines
    Loud buzzing noise throu8ghout cycle. Sometimes washer sticks in wash mode
    first thing i would check is to make sure your copper water line is not touching the motor this will give you this noise. just take off lower kick plate and start d/w you will be able to tell where the noise is coming from.
    Whirlpool GU2400XTP Built-in Dishwasher Logo
    211 people viewed this question
    Top Whirlpool Dishwashers Experts
    Mike
    Owen Barnes
    Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
