Question about Zodiac BARRACUDA G3 IN-GRND CLEANER
Baracuda G3 cassette extension tube handnut unscrews from body
Cassette extension tube handnut unscrews from body of my Baracuda G3
3 Suggested Answers
  • 990 Answers
SOURCE: Open Main Body Baracuda G3
You don't take apart the main body. You just have to remove the flower seal then you have to pry the old one off and grunt and strain till you get the new one on then replace the flower seal. If you bought this at a pool store you should be able to take the head to them and have them do it for you. If you bought it there they probally won't charge you and if you want to do it in the future then you can see it done once. Good luck.
Posted on Jan 28, 2010
jharwell668
  • 640 Answers
SOURCE: Baracuda G3
Check your pool cleaners hose to make sure that it is not becoming tangled. Storing the hose in a coiled position will cause this. If it is not moving and it is not the hose, you could have a leak in a connection somewhere. If the cleaner is getting adequate suction, it should be moving. Try adjust the hose weights to make sure the cleaner is at a 45 degree angle to the pools floor.
Posted on Apr 13, 2011
I need a new main body for my Zodiac Baracuda G3. Does anybody know how to replace that? I can get the part online but the manual doesn't show how to take it apart. Thanks.
The tube/pipe that your hose connects to, counter threads out then the diaphragm near the seal pulls out. Then the large seal is easily to be figured out how to take that off, and then the footpad, also pry's off the flange.
That's about it
Feb 05, 2015 | Zodiac Baracuda G3 Automatic In Ground...
Barracuda G3 manual
http://www.zodiacpoolsystems.com/Products/Cleaners/Suction/Zodiac-G3.aspx
Bottom of the page labeled downloads
Apr 08, 2013 | Zodiac Baracuda Zippy Pool Cleaner
Zodiac G3 stopped traveling even though there is good suction.
There are several things that you can check on these pool cleaners if you are sure that the suction is not a problem. Normally, I would start by suggesting you check for blockages and obstructions in the cleaner, filter, and skimmer. However, if you are getting the correct suction, this shouldn't be a problem. I would also check the diaphragm for damage. To adjust a worn diaphragm, loosen the cassette swivel, gently push down on the the inner pipe, and retighten the cassette swivel. Check all hose sections for leaks by lifting each section above water.
Mar 06, 2011 | Zodiac Baracuda G3 Automatic In Ground...
My cleaner keeps stopping all the time.
Is it pulsating? If not then either you don't have enough suction or the diaphragm is bad or clogged. Very common to have a **** or tear next to or just below the plastic retaining ring that holds the diaphragm on the inner cassette tube. Also check and make sure there are no holes or breaks on the hoses. If this doesn't solve the problem let me know, these cleaners are very straight forward. Good luck!
Sep 26, 2010 | Zodiac Baracuda G3 Automatic In Ground...
My baracuda is not moving....I took it apart and nothing is caught inside. The filters arer clean. I adjusted suction as well with no results
Is it pulsating? If not then either you don't have enough suction or the diaphragm is bad or clogged. you said it was not clogged so check closely for tears. Very common to have a **** or tear next to or just below the plastic retaining ring that holds the diaphragm on the inner cassette tube. Also check and make sure there are no holes or breaks on the hoses. If this doesn't solve the problem let me know, these cleaners are very straight forward. Good luck!
Sep 17, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Baracuda G3
Jul 06, 2010 | Zodiac Baracuda G3 Automatic In Ground...
My Baracuda Zodiac works for a few minutes and
check the diaphragm for debris, damage, or deformity. unthread the collar above the handle and push the tube downward. Inspect the rubber diaphragm, any damage or deformity will cause erratic behavior.
Apr 07, 2010 | Zodiac Baracuda G3 Automatic In Ground...
My baracuda G3 stop working is not pulsating and therefore not moving. I checked the suction and the hoses even the diaphram everything looks ok.
If you have suction at the bottom of the cleaner, there has to be a problem with the diaphragm. I would remove it and recheck.
Feb 01, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Jan 22, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Zodiac BARRACUDA G3 IN-GRND CLEANER Logo
87 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
