Philips DVDR3570H/05 constantly looping on startup
Just bought a Philips DVDR3570H/05 DVD hard drive recorder from ebay.
Whenever I switch the unit on it reads "starting" on the LCD screen, after a few seconds I see the Philips logo on the TV screen but then it seems to reset and continue lopping through this process.
Having downloaded the manual I've gone through the reset proceedure which involves unplugging the unit, holding the on/standy button and plugging it back in. It's then supoosed to reset and show "Demo mode" on the LCD. Pressing standyby again at this point should reset the system but ut doesn't work. The unit just continues to loop as described earlier!
Have I been sold a dud?
Anyone who can help would be greatly appreciated.
Cheers,
Carlos.
  • 1 more comment
  • emzicle Jan 23, 2009
    i have the exact same problem, did u ever fix it?
  • Anonymous Mar 12, 2009
    I have the same problem. It just wont start. The Philips logo keeps poping up and starts all over again.
  • Anonymous Apr 14, 2009
    I have had endless problems with my recorder as well. Came to the conclusion that it is ****. Have you seen all the problems and no solutions on this site? I am getting rid of it.
  • 4 Answers
I had this problem, it was solved by reformatting the hard-drive.
NOTE: if you do this, all settings and all that is saved on the harddrive is lost. But seeing that you can't start it anyway, that is acceptable, right? :)
Anyway, here's how you do it, according to Philips support:
  1. Pull out the power cord from the socket.
  2. Press and hold PREV and STOP (i.e. left and down) on the front panel.
  3. Plug the power cord into the socket again.
  4. Wait until the front panel says "FMT KEY" to let go of the buttons. Wait for it to finish formatting, upon which you will get "-- --" on the panel.
Restart the box and you should now end up at a screen asking you to set the language for the box, as if being started for the first time ever.
Also of note: if you want to restore the firmware to factory settings, Philips support told me to pull the cord, press and hold the STANDBY button, and plug it back in again. For the looping problem though, I didn't need that.
Posted on Dec 06, 2009
  • 1 more comment
  • jcoady999 Sep 24, 2010
    very good it work for my thank you
  • johnom Nov 14, 2010
    Excellent , great help - saved me from having to buy a replacement - many thanks
  • liplijn Apr 27, 2011
    I tried your solution and it was helpfull. Thanks a lot!
    Philips support was not able to help me; you did!
If you go to www.philips.co.uk, in the search box type the model number of your DVD (DVDR3570H) a blue dropdown will appear & click on it. This takes you to a new page highlighted is support info for your DVD. Click on this to go to next page, on this on the left had side there is a product support section with software & drivers section. Click on this & it will bring up a firmware upgdade download. This is a zip file you can download & once opened you can burn to a CD disc. Once you have the disc, unplug the dvd hold down the record & forward button at the same time & plug in the DVD. This will eventually open the disc tray, place the disc in the tray & it will auto run. if this does not fix it then its f****d
Posted on May 07, 2009
Can a person help me?
I bought philips DVDR 3570h/05 i've tried ton upgrade with a newer version 3.08. from then i could play anything. The unit is looping an restarting. can a person help me? Thanks
Serge
Posted on Mar 10, 2011
Ihave philips hdd/dvd player/recorder dvdr3570h/dvdr3590h wehave just had the digital tv switchover but we canot record tv progra
read the instruc. manual since they have information about this matter, if you can or NOT. go to the section troubleshooting for to see and fix it.
God bless you
Sep 27, 2012 | Televison & Video
Dvd drive dose not recognise any dvds i put in it keeps saying unknown disc
If your unit is older the optical pick up lens may be dirty or has gone bad. Most Philips units are exchange items only, meaning they replace it under warranty instead of fixing it, if its out of warranty there usually are no parts or service information on them. Philips was bought be Funai and is not the company it used to be. Check if the unit will play a audio CD, if it does the pickup assembly is bad, some will play a CD but not a DVD. You may be able to clean the p/u lens with alcohol and a Q-tip. The lens is under the clamp that holds the disc while spinning.
May 26, 2009 | Philips DVDR3320 DVD Recorder/VCR
DVDR3570h is stuck in standby, cannot turn on
Mar 15, 2009 | Philips DVDR3576H DVD Recorder
Philips DVDR3570
Nov 17, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Tv/loop what is it
Fix “Stop in Timer recording will cause recorder to go to TV/LOOP State (after TV/DVD in timer recording)”.
• Interrupt TV/LOOP whenever the customer uses the recorder.
Sep 15, 2008 | Philips Televison & Video
I bought a Magnavox 810H 160GB HDD/DVD recorder. It's a decent machine which worked perfectly for a few months, but now I can't get it to record to DVD. The HDD recording and playback functions work fine,...
Try switching it over to DVD . Because you may still have it on HDD when you put the disc in it may be that the unit is still thinking you are on HDD and don't recognise it as a disc just the hard drive
Sep 11, 2008 | Televison & Video
Hello! My Philips DVDR5350H/05 randomley records for 6 hours. The only way to stop this, once the recording has started, is to go into the system menu and select the option to remove the time shift...
Hello. This is not a fault. The DVDR5350H's Hard Drive (called Time Shift Buffer) begins recording (for up to six hours) as soon as the unit it switched on and only clears the 'temporary' recordings when it is switched off or you switch to 'Cam' mode on the remote control.
Like Sky+ and Freeview+, the continuous recoding enables you to save, pause and rewind live TV (this could also apply to Freeview or any source that you may have connected to the EXT1 and EXT2 SCART sockets. In other words, if you are watching TV or anything connected to the 5350 while it is switched on you can keep it without even having pressed record in the first place (pressing OK on the remote control will show you how).
It is normal for all HDD recorders with a 'pause live TV' function to record whether asked to or not.
May 27, 2008 | Philips Televison & Video
Philips DVDR3570H HDD DVD player Recorder - done basic set up last night but the start up search for analogue channels returned 0 - speant 2 hours re arranging plugs & it still wouldn't locate them? do...
The DVDR3570H will only find analogue channels if you have a TV aerial connected to it.
If you only have a satellite or cable box, then you can still use the recorder, but you will have to use the AV inputs on the recorder. In this case you will only be able to record the satellite or cable channel you are watching.
May 01, 2008 | Televison & Video
Philips DVDR3570H for multiregional playing
Hi Dominic,
here is good news for you.
THE philips DVDR3570H CAN BE MADE MULTIREGIONAL .FIRST OF ALL ON THE SET. NEXT REMOVE ANY DISK ON TRAY. OFF THE UNIT AND ON AGAIN.NOW CAREFULLY DO THE FOLLOWING. PRESS HOME,THEN PRESS PLAY/PAUSE. TYPE THE NUMBER 159121212005255 AND PRESS PLAY/PAUSE. OFF THE UNIT AND ON. NOW THE UNIT IS MULTIREGIONAL. i AM A 100% SATISFIED CUSTOMER. THANKS TO PHILIPS.
DR SAJEEV BHASKAR.
Feb 16, 2008 | Televison & Video
Televison & Video Logo
2,246 people viewed this question
Top Televison & Video Experts
