Can't get cover off Canon S630 printer
The cover of this dratted Canon S630 printer has slots with little triangles by them instead of screws. How do I get it off?
The reason I need to open it is because I have the dreaded "home head" error (print head stuck on rail toward right hand side), which I'm almost sure is accumulated cat fur. I'm hoping I can clean it out.
  • Katrina Lee
    Katrina Lee Jun 05, 2010
    This doesn't take a special tool. The triangles are labels stamped BELOW (and pointing to) the slots. It's one of those deals where you use a flathead screwdriver to push a tab or something inside the slot. Then you have to do something else with your other hand (which I can never finesse; I'm always afraid of breaking some tiny piece of plastic). Or maybe instead, all the slots have to be poked simultaneously.
  • Katrina Lee
    Katrina Lee Jun 06, 2010
    With some on-the-scene help, we finally figured it out. There is a slot on each side, and two slots on the back (four total). The slots on the back are low on the curved pieces that flank the sheet feeder.
    Inside each slot is a tab. By inserting a small flathead screwdriver (or a key) into both rear slots simultaneously, the tabs that hold the back of the cover on can be freed. The same thing needs to be done with the side slots, and the cover can be rolled forward just a little bit then lifted straight up.
    The reason for the lift: underneath, there are also two places at the front where pieces of molded plastic inside the cover sort of plug into corresponding pieces on the base. Fortunately, no tabs have to be released at those points.
    Getting the cover back on is also a bit tedious. There's absolutely no clearance, and everything has to be positioned precisely before you start pressing down. I was able to succeed only when I did the process in reverse, fitting the two front "plugs" together, then clicking down the two side tabs, and finally the two rear tabs. Perhaps there's a better method, but I couldn't discover it.
    If one of the tabs catches while the cover is askew, the screwdriver trick must be used to release it before you can start over.
    Unfortunately, I have not been able to resolve the printer's problem. I did clear out a LOT of fur, but now I have a new problem ... which I will describe separately.
  • 29 Answers
Goto your nearestelectronics store like radioshack or a hardware store that has a wide selection of tools like sears hardware or home depot or lowes and buy the triangle screwdrivers. i hate proprietary screws, i really do. just make sure you get the right size triangle screwdrivers okies?
Posted on Jun 04, 2010
  • Light Yagami
    Light Yagami Jun 05, 2010
    oh in that case, how many tabs are there? are they around the edges only?
Canon LBP-2900 Printer Open top cover insert toner cartridge
It is very easy to open the printer.First you need to remove the screws at the back.Then slowly remove the white panels which is fixed at the left and right sides.You should be very careful doing so,because there is no screws instead of that only plastic locks.Then you can remove the top cover.The total plastic panel you can remove only removing the two screws.Best of luck
Dec 14, 2010 | Canon LASER SHOT LBP-2900 Printer
My Canon i850 printer has stopped responding to a
The Canon i850 uses cartridges of type BCI-3. according to Canon, the color cartridges are compatible to:
BJC-3000 Series, BJC 6000, i450, i550, i850 Series, MultiPASS F30, F50, F60, F80, MP 700 and MP 730, S400, S450, S500, S520, S530D, S600, S630, S630 Network and S750.
The black one will work in a few more models.
Feb 07, 2010 | Canon i850 InkJet Photo Printer
Paper jams as a result of string feeding in through the paper fee
Both side covers come off first, then you unplug the scanner and remove. Canon uses a combination of screws and plastic clips to hold covers. You use a screwdriver and insert wherever you see a little triangle pointing to a hole. mark the plugs so they get back to the right place, good luck!!
Jul 24, 2009 | Canon Pixma MP800 All-In-One InkJet...
The timing strip drop off
you need to remove the covers and get to the carriage area and put back on the strip it just slots in on one end and usually a little spring and a metal piece holds in on the other end.
you would be getting error codes as it is as the print head doesnt know what position it is in
canon tech
Apr 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
"Paper Output Slot Jammed" Canon Pixma iP4300
These printers are FULL of very sensitive sensors, and chances are that one of them may have a small piece of paper blocking them. If you can get the covers off by finding the "Triangle" arrow markers, you can inspect all these sensors.
Good luck!!!
Mar 12, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Canon ip3300 printer
I fixed mine just last night, with the same symptom.
This is not an easy fix, but it is FREE!!!
On the bottom of the printer, on the inside of the case, there is an optical sensor that reads the positions of the roller going to the feed tray. I found ink had blocked that sensor, and was causing the error.
Getting to that sensor is not for a novice. Getting into the case is the most technical part.
Find the "arrow" points. These are points on the printer that indicate the release points for the outer shell. There are triangle "arrows" pointed at small, or large "slots" that if a small flat blade screwdriver is inserted, will release the covers.
Find the first under the carriage cover, at the left and right sides. A 1/4" by 3/8" cutout in the top of the black horizontal surface, about 4" from the center to the left and right, and about 2" back from the front. Insert a flat screwdriver, and rotate the screwdriver handle toward the center of the printer to release A PORTION of the left and right side covers. Note the triangle arrows. Now find the others!!!
Happy hunting! If you get the covers off, write back, and I'll tell you how to find the clogged sensor.
Feb 25, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
How do you install the ink roller in a canon p1 dh v
The instructions in the manual are (1) remove the printer cover by pressing down on the (triangle) mark. (2) Lift up the old ink roller and remove it (3) Insert the new ink roller by pressing it gently into position (Use Canon Ink Roller CP-16) (4) replace the printer cover. My roller has the term "Pull Up" on the left side of the roller.
Aug 12, 2008 | Canon P1-DHV Calculator
How to dismantle the canon i560 cover
To open the case, there are 6 slots holding the top cover in place. Insert a flat blade screw driver into the 2 slots at the rear while (gently) pulling the rear end of the cover up. Do the same thing for the 2 side slots, again (gently) pulling(prying) up the cover. Then, remove the 2 side (decorative) covers by (gently) rotating the rear portion down of each downward. They are held in slots by 2 plastic hooks and in front (the wrap-around part) by a tab. Once they're removed, the 2 remaining slots can be reached. Use the screw driver to pop up the front part of the cover. Then the interior of the printer is exposed.
Chas.
Jun 05, 2008 | Canon BubbleJet i560 InkJet Printer
Install instructions for canon s630 printer
in GOOGLE site.. just type the model **. of your printer in GOOGLE SEARCH, and then find the instruction for how to installing your printer.
Mar 10, 2008 | Canon BJC S630 InkJet Printer
Error message on canon i900D
1. Underneath the printer, look for the triangular arrow on the AC Adapter, which points to a detent. Fully depress the detent, remove the AC Adapter and unplug it. Align the cable so that it will pass through the hole in the case when you remove the printer assembly.
2. Open the front cover to the vertical position and tug it at the hinge points to remove it.
3. The black, card-slot cover has two holes marked by triangles. Remove the two Phillips head screws, being careful not to lose them in the printer mechanism. Coax up card slot cover with a dull knife or similar tool and remove it.
4. On the top left of the printer, notice the triangle point at a slot. Insert a screwdriver or similar tool into the slot and depress the detent. Ease the little cover over the USB cable connector towards the rear of the printer and remove it.
5. Remove the “Operation Panel and Window Display” (OPWD). Lift the window display to the horizontal position and remove the two Phillips head screws. Rotate the OPWD forward and out the two hinges at the bottom. Lower the tiny snap that holds the OPWD strap cable and remove the OPWD.
6. Note the slot marked with a triangle between the two OPWD hinge slots. This is one of the six slots, all marked with a triangle, which access the detents that hold the upper casing. Locate the other five. One is on the left-side front of the printer in the same relative position as the one hidden under the OPWD. The other four are in the rear of the printer. Depress these detents in turn, working around the printer, and coax up the upper casing. This requires fortitude, patience and one or more dull, thin instruments.
7. On the right side of the printer, remove the Phillips head screw that fastens the yellow wire to the chassis of the printer.
8. Disconnect the connector on the Digital Camera Connector (DCC) circuit board and ease the cable out of the printer casing as far as you can. (I feared damaging the connector and removed the circuit board and DCC cover instead.) This cable is hooked at the right hand rear corner of the printer casing.
9. Looking down on the printer mechanism, locate the two Philips head screws near the rear. These fasten the printer to the base. Remove them carefully.
10. Placing a hand under the paper feed barrel, lift the printer assembly up and rest it on the case while you fight the DCC cable off the hook at the right rear corner. Once you free it, remove the printer assembly and congratulate yourself.
11. Wearing disposable gloves, remove the five ink absorbent pads and rinse them under the facet in the laundry sink. Cold water is fine. Press the pads with your fingers until the water runs clear. Do not wring or otherwise torment the pads, as you want them to retain their shape. Press the pads between old newspapers to squeeze out most of the moisture. Expect to be surprised at the amount of liquid these felt pads can hold. I dried mine in the sun. Use a hair dryer, clothes dryer, microwave or oven at your own risk.
12. Reassemble the printer in the reverse order of disassembly.
12.1. Insert the small absorbent pads first. The right side pad with the green facing goes on top. (I think.)
12.2. Caution: Before replacing the upper casing, note the small electrical gismo on the left side of the printer assembly. It has a slot that fits into the plastic wheel. When properly positioned, the gismo snaps into place. Make sure the gismo is correctly seated before replacing the upper casing.
Dec 29, 2007 | Canon I900D InkJet Photo Printer
56 people viewed this question
jasbo
jasbo
