Question about Car Audio & Video
2001 Subaru Outback security code won't stop flashing !
After giving my car a through interior spring clean, the red security light behind the steering wheel is now flashing twice (not a code listed in owners manual) and will not stop flashing. My searching online leads me to believe that I now have the car in valet mode but my attempt to re-arm the alarm by holding the small remote button has failed, as well as other "resetting" suggestions in owners manual. It does not flash while driving but still its driving me crazy! Besides I fear my car no longer is armed with an alarm.
Please help!
Thanks,
Sindientes
  • 3 more comments
  • toma61 May 28, 2008
    I have the exact same problem with my 2000 Subaru Outback.
  • jcbreck Nov 12, 2008
    Same problem with my 2002 Outback. Any luck resolving it?
  • milton200898 Dec 16, 2008
    Thanks!  I had to same issue and that resolved it!  I couldn't find anything in the user manual that even talked about valet mode.  When I went to other sites I figured out that must have been the problem, but it gave an alternative method to enable the system that didn't work!  Thanks again!
  • kaga3 Jan 05, 2009
    Security light flashes continuosly, lights no longer flash twice. Tried all methods in the manual but to no avail. How can I reset the security alarm?
  • ms_femi
    ms_femi Jul 03, 2013
    I had that problem...also car would not start. The parking attendant at my garage worked it out with the remote.
Im a service manager at a Subaru dealer. The security system is in valet mode. Open the drivers door, with the drivers door open hold the small unlock button on the remote and keep holding it until the light stops flashing.
Posted on Dec 06, 2008
  • Jean Todd
    Jean Todd Nov 25, 2013
    This didn't work for me. Anything else to try?
2001 Subaru outback limited security light flashing rapidly!!?
Reset the system by removing both battery terminals
Hold the positive and negative together for 30 seconds
The. Reinstall both terminals
The system will re learn for the next 10 miles or so
If it happens again to the light
We will have to try another approach
Best of luck
Feb 22, 2015 | 2001 Subaru Outback
Why won't my 2010 subaru outback wagon interior lights go off unless it's locked
Check your Interior Light Switch what position is it?
The Striker may have lost a Wire. Test EACH DOOR
Apr 09, 2013 | 1999 Subaru Legacy
I have a Subaru Outback. The security light behind the steering wheel is blinking twice, which I guess means it is in valet mode. The solution doesn't work though (hold down unlock button with driver's...
I think you have to have the key in the ignition, and set to "ON" with the driver door open and holding the unlock button down for several seconds. At least that works on my Forester.
Jan 08, 2010 | 2001 Subaru Outback
Disconected my battery cables.......lights flash
Regulator is bad or alternator is going out.
Sep 28, 2009 | 1997 Subaru Outback
Alarm On no remote
yes the door diarm switch is defective in that door you replaced or it doesn't have one.
Jul 14, 2009 | 2000 Subaru Outback
'99 subaru legacy gets 2 flashes from LED and
try opening door and holding unlock button ,it sounds like its in valet mode
Jun 15, 2009 | 2001 Subaru Outback
2001 Subaru Outback tail lights don't work
do you have a trailer hitch? if yes disconnect convertor box the light behind the dash should not be related bulb just out, also make sure bulbs you've changed are correct
Jun 09, 2009 | 2001 Subaru Outback
2000 subaru outback rear door stuck in open mode
Disconnect the wires going to the spring loaded switch in your hatchback.
Jan 19, 2009 | 2003 Subaru Outback
Car Audio & Video Logo
3,569 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
