Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
Where can I find a reference to the error codes that appear on the dispaly?
    Top Expert:
  • Whirlpool Master
  • 80,339 Answers
Go to the link below for a service and repair manual for the Duet line of washers.
codes are in section 6
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
Posted on Jun 04, 2010
  • Whirlpool Master
  • 8,220 Answers
Remove the bottom panel and the tech sheet will be inside there:Where can I find a reference to the error codes - a8f7847.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
  • Dan Webster
    Dan Webster Jun 04, 2010
    My notes:
    F01 power glitch: disconnect power for 2 mins verify correct CCU operation
    F11 Motor control unit internal failure MCU board failure or broken wire.
    F20 No water detected entering machine, pressure switch hose clogged
    F21 Long drain Possible cause: Clogged filter, clogged/failed pump
    F22 Door lock error Failed lock. corrosion,or broken wires.
    F23 Heater Failure Bad heater
    F24 Water temp sensor error Failed sensor or heater
    F25 Motor Tach error Bad MCU (motor control unit) or broken wire
    F26 Door switch error Door not opened after 3 cycles. Note: suds errors cause the machine to try 3 times to fix a problem with wrong detergent too much detergent , and this error could be associated with that, my opinion
    F27 Overflow condition Clogged drain, pump, kinked hose.
    F28 Com error between MCU and CCU (central control unit) Broken wire
    F29 Door unlock error bad switch,broken wire,corrosion
    F30 Dispenser system error Bad or jammed motor, broken wire
    F31 MCU failure due to motor overheating.
    F33 Pump drive system error, broken wire, corrosion
    rL (prewash)Clothes detect. Remove clothes and retry.
    5d Suds lock detergent overdose(hay I ain't making this up, too much detergent, the wrong stuff, added to the wrong compartment, etc
    The technicial data sheet along with that pesky clogged pump is located behind the toe kick panel; remove the screws under the bottom front edge of the washer. Tip the appliance back to get to them screws. With the screws removed, the panel will comes down and off.
    For diagnostics and further info refer to this handy dandy:
    DUET SERVICE MANUAL My tip:
    http://www.fixya.com/support/r4232744-du...
    Let me know
The dispaly blink "Sud" and
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Sep 05, 2011 | Washing Machines
Error code F2
The error code "F2" that appears on your KitchenAid microwave refers to a keyboard failure/short on the front button panel or loose keypad connector
Attempt the following to clear error:
Check keypad connector for firm connection.
Press "Cancel" after the error code is noted, if error code returns after 60 seconds, replace keypad ( also called touch pad or membrane switch ).
Best of Luck with the microwave.
Jan 26, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Where can I find fault cde info. Code is F1
unless it has been worked on before alot of the manufactures will put some technical information for the technicians in the control panel area. it requires removing the interface/dispaly control and usually taped inside there is a reference paper with some schematics and codes on unit...if nobody else in the past has taken off with them .... good luck to you...
Jan 08, 2011 | Ovens
No error code-no power to dispaly-Washer won't turn on
It could very well be the timer control (these are electronic,not mechanical, and electronic styles are more flukey). But, you need to know how to override certain wiring to test other components and know for sure if it is timer control board or other. Most people think there is a fuse to find and this will solve everything; unfortunetly, this is not your case. Goodluck, Macgivor
Dec 27, 2009 | LG Washing Machines
Getting error code e000
Mr.Rajonline,how can reset do you know?It is not diagonosis, we want to know how to reset it possible?
Jul 17, 2009 | Canon imageCLASS D760 All-In-One Laser...
Monitor dispaly problem
I think this problem appear video o/p section.Dry solder Pl. solder video output section
Jun 01, 2008 | LG Computers & Internet
Canon ir 2016 copier on display says ( Download Standby) thanks
We have a Canon IR 2016 J and in a beginning in the dispaly appears the message "Download Stanby" then after we replaced the PCB board appeared the message "System Error E354" what should we do to solve this problem, and if it is possible to send us the Service Manual with error codes for Canon IR 2016
Apr 18, 2008 | Panasonic KX-FB421 Plain Paper Film Fax
Error E354 in copier ir2016
Mar 26, 2008 | Kyocera KM-1505 Copier
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
261 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
