Question about Kicker CVR12 Car Subwoofer
How do i hook up two 12s to a one channel amp
  • 94 Answers
So you take Sub A's positive and connect it to Sub B's and then Sub A's negative to Sub B's negative, found a pic to help explain
http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2svc_4-ohm_mono.jpg
Posted on Jun 07, 2010
I have the xterminator 2000d amp and I am wanting to wire two 12s and one 15 to the one amp. Both Kicker speakers are 4 Ohm SVC. Am I able to do this safely?
Wire the two kickers in Parallel, this will half the resistance of 8 ohms to 4 ohms and match the 15" speaker on the other channel.
Jul 07, 2016 | DHD US Amps Xterminator XT-2000D
Wats the best way to hook up 3 hifonic hfx12d 12s. Dvc 4ohmd to a 2 channel 2600 watt planet audio. Amp is 2 ohm stable.
Wire each sub 8 ohms(sieries) than connect them in parallel, bridged @ amp, final impedence will be 2.6 ohms.
Jan 30, 2014 | Hifonics Car Audio & Video
How much can my speakers handle?
As a rule of thumb you should drive them before their clipping or start to distort point, hope this helps.
Sep 15, 2013 | Volfenhag ZX-5168 2-Channel 4000W...
I have 2 12s kicker comps 2ohm. One of them are working fine, the other one, when I hook up to amp, it throws them both off and just does this repetitive bass....or when I just hook the one thats...
Measure the resistance across the voice terminal of the known good sub, and then compare that to that of the problem sub. You may see a greatly changed value, which likely means the voice coil is damaged. Don't connect the subwoofer again because you risk damaging your amp as well.
Nov 16, 2017 | Kicker CVR152 CompVR 15 2/4 ohm 1000W...
I have a 8 0 4 phonix gold amp and two 12s i blew the 12s and i bought some but they are 4 ohm how should i wire them?
You will have to wire each sub to an individual channel. you cannot bridge the amp, because it is not stable at 2 ohms. You could bridge it if you wire the subs in series, but you will get more power by committing each sub to an individual channel.
Mar 20, 2011 | Phoenix Gold Octane-R 2.5:2 Car Audio...
ON MY Pioneer PRS-X720 Car Audio Amplifier WHEN I TRY TO HOOK UP THE BRIDGE LITTLE SOUNDS COMES OUT THE SPEAKERS I HAVE TWO 12S MTX THUNDER IN THEY ARE IN A 2OHMS BOX BUT WHEN I HOOK UP JUST ONE CHANNEL...
From the specs this amp can only handle 4ohms when bridged but can handle 2ohms when it's not bridged
Specifications
  • Continuous Power (20Hz-20kHz, 0.04% THD)
    • 2 ch: (4 Ohm) 100Wx2
    • 2 ch: (2 Ohm) 200Wx2
    • 1 ch: (4 Ohm) 400Wx1
  • Maximum Power (EIAJ)
    • 2 ch: (4 Ohm) 250Wx2
    • 1 ch: (4 Ohm) 750Wx1
  • Frequency Response: 10Hz - 50kHz (0,-1dB)
  • Total Harmonic Distortion: <0.01% (1kHz, 4 Ohm)
  • Signal-to-Noise Ratio: >105dB (IHF-A Weighted, at 1kHz)
  • Dimensions: 10-3/8" x 2-1/2" x 13-5/8"
Hope that helps.
Nov 08, 2010 | Pioneer PRS-X720 Car Audio Amplifier
How to wire a 2400w amp to 3 12s subs
if the amp is a 2 channel, u could either bridge them all, or if you wanted to, you could hook 2 speakers to the two seperate channels, and then hook the other one to the negative on one channel and the possitive on the other. if this wasnt what you meant, just, try to tell me more about the amp... thanks
Dec 05, 2009 | Kicker CVR10 Car Subwoofer
Amp turns off
You did not specify the model you have - however the Flex series is only stable with a load of 4 ohm mono (bridged) and 2 ohm (stereo).
You are driving the amplifier to work too hard, and it is shutting itself down.
Re-wire using one subwoofer (bridged) or wiring the subwoofers on seperate channels.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 08, 2009 | Car Audio & Video
Running 4 12s with two insignia 1000 watt amps
Use a pair of two-channel amps that are two-ohm stable, and wire a pair of subs to each amp. Wire them in parallel so the amps see two ohms (wiring in series will show four ohms). Doing this effectively "doubles" the power of the amps. If the amps are not two-ohm stable, they'll fail. Parallel wiring means putting the positive wire of sub 1 to the positive terminal of channel 1 on the amp, and the negative wire of sub 1 on the negative terminal of channel 2. Do the opposite for the second sub. This will give you a LOT of bass response as long as your sub enclosures are properly sized for the speakers.
Jul 21, 2008 | Insignia Car Audio & Video
High distortion
The head unit may be rated at 200 watts but it cannot produce more than ~20 watts of real power per channel. There's no way that it can drive the high end speakers to a level that will be needed to compete with the subs on a 1000 watt amplifier.
Apr 18, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Kicker CVR12 Car Subwoofer Logo
81 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
