Question about GE GSS25LGM Side by Side Refrigerator
Freezer is not cooling down
Reasons why freezer/friger is not cooling down (side by side, model GSS22K)
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
jjk
Posted on Sep 30, 2010
Maytag MSD2754G frig is not cooling properly. Freezer is great. Help
Please click here and u will understand everything what to do to fix ur problem.Everything is explained step by step
Click here
Goodluck,
Please don't forget to rate me as fixya..
Feb 04, 2008 | Maytag MSD2754G Side by Side Refrigerator
Not cooling enough on frigerator side but it still works on freezer side.
Hello Mjorgy,
I understand that you are having a problem with you refrigerator. The freezer is cooling fine, however the fridge side is not cooling enough. This is a common problem with the evaporator coil stops working. When you open the fridge or freezer you should hear a fan running or fell are coming out of the vents to the fridge.
I would love to help you further if you can please post a model number for the unit I will look up where the fan is located and let you know how to get to it in step by step instructions. You should be able to locate the model number in side the compartments on the wall close to the front. It is also located on the rear of the unit. Please post back to this thread so that I may assist you further.
Thank you for choosing FixYa.com
Justin
Apr 05, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
My kenmore side by side has a problem the freezer part work but the frigerator part doesn't what can I do help
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Mar 14, 2011 | Kenmore Refrigerators
Freezer works but frigerator does not
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
OR..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 14, 2009 | Refrigerators
Water was leaking out of the freezer so I cleaned the ice build up on the freezer and now the frigerator is not cooling. I have a Kenmore side by side
check and make sure the timer is not stuck in defrost mode. if you can turn the timer by hand past the current point it should advance past the defrost cycle and begin cooling. The timer is usally found near the bottom of the refrig located in the front side.
Jul 07, 2009 | Kenmore 72102 / 72104
My frigerator
This will get warm. If very hot check and clean coils in front, underneath. Also check fan behind rear panel. It should be turning when the unit is running. Also check for door not closing properly.
Nov 12, 2007 | Frigidaire FRS3R5EMB Side by Side...
GE GSS25LGM Side by Side Refrigerator Logo
126 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
