Question about Haier HTQ21JAAWW Top Freezer Refrigerator
Haier refrigerator is not cooling and compressor is hot to touch
  • Haier Master
  • 8,220 Answers
If the compressor has a relay chances are it is toast.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 04, 2010
Haier model HRQ04WNAWW refrigerator. Stopped cooling suddenly. Compressor is hot, really hot, and doesn't make a sound. Light is still on inside of unit, so are getting power.
the compressor has an internal overlod inside of it after 115 degress it opens and wont start till it cools down below 115 unplug and try putting ice cubes on top of com pessor to cool it down otherwise it will take hours to cool off
Aug 07, 2011 | Haier HRQ04WNAWW 4.2 Cu. Ft. Refrigerator
Haier Mini spilt HSU18VC7 compressor runs for 5 minutes then stop 3 minutes then run another 5 minutes and so on.
This is called short cycling. It sounds like the compressor is getting hot and opening a bi-metal overload, which shuts the compressor off. The compressor cools, because it is not running and the bi-metal contacts close allowing the compressor to start again. This will repeat itself and is usually due to low refrigerant, which usually means there is a leak in the normally sealed refrigerant lines. The refrigerant cools the compressor windings and if it is low it cannot do that, hence the shutting off of teh compressor, cooling down process and restarting of your compressor. Short cycling will ultimately ruin the compressor.
If this has helped you please give me a rating worthy of my diagnosis.
Aug 03, 2011 | Haier Heating & Cooling
My 3yo Haier HTQ21jaaww refrigerator no longer cools. The coils have been cleaned to no avail. Help I have a big family and need my fridge!!!
things to ck . is the compressor running ? remove back the comp will feel hot if running . if its running it may have lost its gas .. / if not running but the cooling fans are . the relay on the compresser may have failed .. hope htis elps mm .. feed back pls ..
Jul 10, 2011 | Haier HTQ21JAAWW Top Freezer Refrigerator
Compressor running very hot but almost no cooling. Fan running
make sure the coils are clean both evaporator and condenser,then if there is a capacitor in the motor circuitry,check this,finally if the coils frost,then clear up and frost and clear up time and again,this is a sign of low refrigerant R134a,and this also will make the compressor run hot
Apr 09, 2010 | Haier 45-Pint Dehumidifier
Not cooling, but compressor running. No signs of leak.
to check the leak manually is when the compresor runs touch the condenser it must be hot.Or check the ventilation if it is a forced convection condenser with fan it must be hot if not then there is no refrigerant in the system.so no cooling.system has to be evacuated checked for the leak corrected and then recharged
Jul 01, 2009 | Haier HSC02 Refrigerator
Compressor on Haier hmse03waww mini-frige shuts off after 10-20 minutes and is hot to the touch.
If the temperature in the refrigerator is correct then this is proper function for the compressor. It should run until the desired temperature is reached then shut off. The compressor also gets really warm. If the compressor is shutting off prior to the correct temperarure being reached then you may have a compressor problem. If the compressor is bad and our of warranty, it is time for a new refrigerator. If it is still under a warranty, call for factory service. Good luck, and I hope this helps.
Mike
Sep 29, 2008 | Haier Refrigerators
Haier model hslorwnawn refrigerator/freezer neither one gets cold or freezes.
Could be a compressor or refrigerant charge problem. Check to see if the compressor is hot. If so is it running. If not and it is hot the compressor is the problem. If the compressor is cold it is in the power supply to the compressor. That would be the thermostat or defrost timer. If the compressor is running and it is not cooling it could be the refrigerant.
May 25, 2008 | Haier Refrigerators
Will not cool
If the compressor is getting really hot it's more than likely SHOT.
There is a small possibility you have a bad overload/start relay.
But compressors do not like getting hot.
Jan 06, 2008 | Haier HSB03 Compact Refrigerator
GE refrigerator not cooling
on most refrigeration, the refrigerant goes to the freezer first and the tail end to the fridge. it is probable that the compressor is failing. compressors are quite hotg when running but not too hot to touch. if the compressor is too hot that also indicates failure. doubt it is worth repair
May 19, 2007 | GE GSS25JEMWW Side by Side
Haier HTQ21JAAWW Top Freezer Refrigerator Logo
402 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
