Question about Brother CS-8150 Computerized Sewing Machine
My upper thread is catching the bobbin thread but not pulling it
  • 503 Answers
Check the needle to be sure it is correctly installed -flat side to the back of the machine on most models.
Check the bobbin to be sure the thread is feeding from the bobbin spool in the correct direction and through the guide on the side of the bobbin case.
Always thread the machine with the presser foot up to insure proper tension.
Please post your feedback and Vote if the issue resolved as per your satisfaction.
Posted on Jun 04, 2010
  • marinebingha Jun 04, 2010
    needle and bobbin are both fine. the bobbin itself wont turn thus allowing the top thread to make an accurate stitch
  • Monika Arora
    Monika Arora Jun 04, 2010
    Double check to see if the bobbin is in upside down and the thread is feeding from the bobbin spool in the wrong direction.
How do I get the thread from the bobbin to the needle?
If your machine is functioning properly, when the needle goes down into the bobbin area, the needle thread will catch the bobbin thread in a loop. (If you gently pull the upper thread tail, you will be able to pull the bobbin loop up above the needle plate.) If your machine is not doing that, then there is something wrong. Make sure the needle is installed correctly and both threads are threaded properly.
How and Why to Bring up the Bobbin Thread
Jan 24, 2016 | Sewing Machines
Can anyone help me with an idiots guide on engaging the bottom bobbin
Are you asking how to pull the bobbin thread up? Simply hold the thread tail from the top thread and gently handrotate the handwheel toward you. One full circle completes one stitch cycle. The upper thread should hook the bobbin thread and pull up a loop. When that loop appears above the needle plate, gently pull the upper thread tail, enlarging the bobbin thread loop and catch it with a sewing tweezer, pin, or even the point of a scissor blade to pull the rest of the bobbin thread to the top.
Nov 13, 2015 | Sewing Machines
When pulling my bobbin thread thru to top my upper thread doesnt go all the way around the bobbin case then it hooks on the little metal arm on top bobbin case on my PE700
The part that holds the bobbin case moves around it after catching the upper thread. Check it and see if it is not working as it should. I wonder if the bobbin is not in far enough.
Nov 09, 2014 | Sewing Machines
Why does my thread keep bunching up?
That is called "thread nesting," and several things can cause it. The upper thread enters the bobbin area during sewing, catches the bobbin thread, and as the needle goes up, pulls the stitch tight. Something is catching the upper thread as it goes around. The most common reasons are the bobbin or bobbin case (or both) is improperly inserted; the bobbin is warped (roll it down a flat surface--if it wobbles, it's warped), either the case or the bobbin is not seated evenly, there is a rough spot on the bobbin case that is catching the thread, or your bobbin is loosely/badly wound. You need to rule out the possibilities step by step until you find the cause. First, review your threading procedures from start to finish, using your user's manual. Then, without fabric, turn the hand wheel by hand (ALWAYS towards you) to see if you can see it start to catch. The top thread should rotate smoothly in the bobbin area. You should be able to pin-point the cause that way.
Sep 24, 2014 | Singer 2517 Mechanical Sewing Machine
The upper thread will not pick up the bobbin thread
You should do this by putting very slight pressure on the foot control (or turning the wheel by hand) with the machine's pressure foot up. Then pull the threads by hand to the back of the machine. If the upper thread does not catch the lower thread then the bobbin is not correctly threaded in the bobbin case.
Oct 16, 2013 | White Sewing Sewing Machines
Upper thread will not catch the bobbin thread
make sure to use every thread guide
try a new needle
make sure the bobbin is inserted correctly
if these suggestions don't help & if the machine is still under warrenty take it back & let them check it
Mar 20, 2012 | Singer Sewing Machines
I cannotl get my 270 D to even sew, it will not pick up the bobbin thread and do a thing. I have yet to sew the machine. donna
Picking up the bobbin thread has to be done by manually. Turn off the machine, open the bobbin door, lift the presser foot, hold the end of the upper thread and slowly turn the side wheel till the needle enters the bobbin race and on the way up it will catch the bobbin thread. Pull the upper thread till you lift the bobbin thread too. Put both threads to the back of the machine, close the bobbin door and you should be able to sew.
Apr 03, 2011 | Brother SE-270D Computerized Sewing...
The bobbin keeps jamming up and is not catching
Check that it is threaded correctly (both top and bottom) making sure that the upper thread is in the takeup lever. Watch the needle as you slowly turn the handwheel counter clockwise (toward you) and the needle point touches the fabric (make sure presser foot is down). Is the thread still relatively taunt? If it is loose, the upper thread tension unit does not have enough tension. Check the areas where the thread goes and make sure you remove any loose threads or fluff which could be inhibiting the tension discs from closing over the thread. If the tension unit still is not tightening enough, the tension unit may need to be replaced or the circuit board replaced. If everything is ok in the upper thread area, now look at the bobbin area. With no fabric, watch as the needle enters the bobbin area. Does it go down and the upper thread catch the bobbin thread and pulls it to the surface? Check for anything preventing the bobbin thread from being pulled up to the surface through the needle plate. If you have still not been able to resolve the problem suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Feb 05, 2010 | Husqvarna Freesia 415
Bobbin problem
Suspect the needle and hook timing is off causing threads not to catch to make a stitch.
Try these troubleshooting tips:
With machine off, remove the bobbin and bobbin case. Push the needle bar to the left. Lower the needle to the bobbin case and notice when the needle starts traveling upward does the tip of the hook in the bobbin area align with the eye of the needle? If it does not align, the timing is off. If it does, move on to check upper tension:
Good luck.
May 19, 2009 | Husqvarna Freesia 415
Brother CS-8150 Computerized Sewing Machine Logo
29 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
