Question about Malber WD1000 Front Load Washer/Dryer
No final spin
My wd 1000 is skipping the final spin cycle (4).  It also seems to be going through the other  cycles at much slower rate - taking longer to get to the end.   when it does finally stop, there is still water in the tub.  When I reset it to the spin cycle #4, it then goes through that cycle, spinning no problem.  Please help.
  • 55 Answers
I haven't experienced that problem, but is it possible that the machine becomes unbalanced with the spinning load and then aborts the spin, so it doesn't finish? Has the machine been properly leveled during installation?
Posted on Apr 23, 2008
What is the meaning of RPM
In general RPM is rotations per minute. This is usually a rating of the washer spin cycle; usually less water is left in the clothing after a faster spin cycle. The washer tub will rotate during the other cycles but that will often be much slower than the spin cycle.
I hope this helps.
(some front-loading High efficiency washers go up to 1200 RPM; top loaders only spin at half that rate usually.)
Dec 03, 2012 | Bosch Washing Machines
Excessive vibration during spinning
I think it should be normal.One of our washing machines does it too.No problem so far.
Aug 05, 2012 | Malber WD1000 Front Load Washer/Dryer
My Mom is 90 yrs old and lost her machine instructions. The model is front loader WD 80250 NP ( now 4 years old). Can I down load the manual? My other question is: On the Cotton cycle does the programme...
Home Depot Sales Associate-
You can find the manual for the product here.
http://www.lg.com/levant_en/support/product/support-product-profile.jsp?customerModelCode=WD-80250NP&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WD-80250NP&initialTab=documents&targetPage=support-product-profile
The unit is designed to only operate properly with a hot and cold faucet connection. The exception is if it has a cold wash cycle and you are operating it on such. (that model should not) Also, once you set the cycle, you should not manually interrupt the cycle to change to the desired portion of the cycle. Front load wash units take longer to run due to the usage of less water. They also need high efficiency detergents to operate properly and cannot be overfilled with detergent.
Your description of a soap lather sounds like you are using the wrong detergent and in the wrong quantity. HE only.
Mar 20, 2011 | LG Washing Machines
Whirlpool Ultimate Care II LSQ8243HQ0 weak spin, wet clothes
if it has a belt, it may be slipping, but you would smell a bit of burning rubber.in high use times(4 to 8 pm), the current of electric supply is low, thus less power. third, motor may need to be replaced. plz rate-bozcro
Sep 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Loud noise in final spin
Verify that the inner drum isn't broken. Sopin by hand it should trun smoothly and staight.
Aug 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing machine cycle
check the lid switch for failure - or else the motor controller should be tested.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 07, 2009 | Washing Machines
GE WHDRR418 top load washer won't spin at high speed; the washer does the complete cycle, and agitates in both directions and does physically spin, but it will not go into the 'high speed' spin that...
we can eliminate the motor and the switch since that part is working. sound like your timer might be faulty, timer make everything work in persistence cycles, if its goes bad sometime it tend to jump/skip cycles.
Jul 21, 2009 | GE WSXH208A Front Load Washer
Maytag washing machine skips rinse cycle
I found this problem with mine intermittently and it was because i had filled the machine too full that it was too heavy to initiate the spin. maybe try a lighter wash?
Jul 03, 2009 | Maytag Washing Machines
MALBER WD 1000 - UNSPUN HERO
use the rinse cycle on the machine in conjunction with the spin that should solve the problem
Apr 16, 2008 | Malber WD1000 Front Load Washer/Dryer
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
309 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
