Question about Refrigerators
Compressor on fridge keeps on running - Refrigerators
  • kgmike Dec 13, 2008
    compressor keeps running.
    Champion:
  • 207 Answers
Perhaps you need to refill system with freon.
Posted on Apr 09, 2008
My fridge compressor is not running. I removed the thermal cutout and relay to replace. The parts list shows a capacitor which my fridge doesn't have. Is this required for my model? WSE6070SB model no
Yes
the start /run capacitor is required to jolt start the compressor with an over voltage and then to keep it running
fridge capacitors are generally flat squarish and yellow in color about 1/2 the size of a match box
get in a fridge technician to properly diagnose the fault and save money
Jul 21, 2016 | Refrigerators
Neff integrated fridge freezer. Intermittent fault. Sounds like compressor jerking on and off
Possible cause is start/run capacitor faulty.Do not run fridge please get a tech to confirm problem.
Jan 17, 2016 | Neff Refrigerators
Both fridge and freezer keep rising in temp, seems to be running constantly. Only about 3 years old. Replaced the board in it, seemed to run quietly for one day keeping proper temps, now back to running...
when you install a new board you have to check i think it's the 9 pin connector,the instructions will tell you what one it is,if there's a wire in the second pin you need to cut the wire or the machine won't run correctly.
Aug 17, 2010 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
Continues to make ice when grill cover is off, then trips on safety limit #2 when replaced. condensor has been fully cleaned
If this is a combination gas grill with the accessory fridge mounted in the cabinet, then the issue is that once you put the grill cover on, you are preventing proper airflow/circulation needed to keep the fridge's compressor ventilated enough to keep operating.
Try leaving the grill cover off and move the grill/fridge out of direct sunlight, as the thermal heating of the cabinet isn't helping the fridge get enough air circulation to help it (the compressor) run cool enough to keep from tripping the thermal overload sensor (thermistor or Klicxon themal protection device) mounted on the compressor.
This device prevents the compressor from extreme heating that can cause the compressor have a catastrophic failure.
Hope you find this Very Helpful and best regards!
Aug 20, 2009 | Manitowoc Refrigerators
Comperssor kicks on but quickly cuts off intermittently every 5 minutes on my frigidaire fridge side by side
Freezer defrosted everything fan continues to run but will not freeze. Compressor is cycling enough to keep refigerator section cold. 106 Series Kenmore. Turned up thermostat to keep fridge cold and a shorter intermittent compressor cycle run
Jun 06, 2009 | Frigidaire FRS26H5AS Side by Side...
Fridge is not cooling freezer is not freezing
Your compressor is seized and is cycling on intenal overload, you will have to get someone out to get a price at replacing the compressor for your fridge.
Apr 04, 2009 | Kenmore 57029 Side by Side Refrigerator
Compressor runs for 5sec.
your relay and overload on side of compressor is bad.you can replace with original parts or a 3-n-1 hard to start.
Mar 09, 2009 | Whirlpool ED5GHGXMQ Side by Side...
How can I tell if my fridge isn't working?
Unplug the Ref for 15-20 min. take off the cover so you can see the compressor, then plug it back in and listen for the compressor to start. You should be behind the Ref so you can tell the difference between the fan running or the compressor.
The compressor should start and keep running.
The fan cooling the compressor should be running.
The fan in the freezer should be running.
You should feel cold air coming into the Fridge side from the freezer side.
Jan 12, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Fridge running but not cooling
Sounds like you're low on gas...assuming that the condenser coils are clean.
Nov 20, 2008 | Kenmore 64802 Top Freezer Refrigerator
Fan running but not keeping cold
check to see if the compressor is running, if not you may need a start kit, (relay,overload) If the compressor is running take the back freezer panel off and check to see if there is a frost pattern, might be out of gas if frost pattern has receeded
Nov 08, 2008 | Whirlpool ET1FHTXM Top Freezer...
Refrigerators Logo
383 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
