Question about Ducane 30400040 Stainless Steel Grill
Replaced the 3 burners, cannot get them all to fire
I would get 2 working, then take the front assembly appart and start over, after 3 attempts, none will lite (using matched, somehow the gas is not travelling down the pipe
  • 8,220 Answers
These newer tanks have a touchy anti leak device built into them. Remove the tank and check for obstructions. Shut all valves. Re install tank and SLOWLY open valve just enough to allow gas out. Then retry.
Posted on Jun 04, 2010
I have a Model CG206B. One front burner will not fire unless I fire the back one and then turn the front one on.
The problem is going to be that the switch that turns on the spark for that front burner is defective and that switch needs to be replaced. To replace the switch on that cooktop which splis over the gas valve for that burner is remove all knobs and remove the face plate over all the burner valves, the switch slides off of the burner valve and the wires to it just slip onto the new switch,the part number for that switch is Y704512 it could be purchased at your local appliance partstore or online at;
apdepot.com
partselect.com
apwagner.com
repairclinic.com
applinacepartspros.com
before attempting any repair on the cooktop be sure to disconnect power and turn off gas supply
GENE
Oct 09, 2011 | Cooktops
Purchased a grillpro 3 (three burners plus side burner) from orchard. They installed but side burner will ignite. Igniter is working and I hear gas when I turn the burner knob. Fire the igniter and it will...
You're getting gas to the burners, just not enough to ignite the burners.
To solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank.
I hope this helped you & thanks for choosing FixYa.
Jul 28, 2011 | GrillPro Grill Pro 80016 Hose and...
Every time I start the machine the f1 error comes up within a few seconds. have to press pause & start about 3 times & it will finally start to work. have to do this several times during the entire...
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^@#$%
Jun 02, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I AM LOOKING FOR THE SCHEMATICS ON A ROPER DRYER MODEL # RGL4632BQ0, CAN YOU PROVIDE ME WITH THAT INFORMATION? MANUALS ONLINE DOES NOT HAVE THAT MODEL OR ANY OTHER FOR THAT MATTER. I HAVE TO PUT IN A GAS...
Before attempting to buy the ignitor or any other part take the back off and check the fuse. 958e138.jpgNote: on gas models this fuse kills the power to the burner unit only. If its bad you needs ta clean out the filter chute. Remove it From the dryer and wash it out. Remove sand and lint from blower area etc. If that is ok then you need to take a look at the burner assembly. efaa486.jpgCheck the igniter for continuity if open it is bad, check the flame detection unit if this is open then the ignitor won't fire off. Don't touch the ignitor silicone carbide filement or it will be ruined. Service manual
Wiring diagram
Apr 08, 2010 | Dryers
My Maytag LDG8200AAW does not stop automatically and does not sta
It's likely one of the coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. The number for the coil kit, which will replace ALL the coils, for your machine is 279834.
Disconnect power and turn off gas before working on this dryer.
Service on gas appliances should be undertaken by professionals only due to the danger of gas leakage which can cause fires or death by asphyxiation.
The disassembly procedure is covered beginning on page 3-11 of the manual listed at the link below. Operation and replacement of coils is covered at page 3-32. Replace All coils with Kit Number listed above. Take care not to touch or hit the ignitor or you will be replacing it also. It is VERY brittle.
Reverse process to re-assemble.
http://www.servicematters.com/maytag_library/docs/16008714.pdf
Sep 24, 2009 | Maytag Dryers
I have a Whirlpool GGW9879PW0 gaas dryer. When starting cold I hear the click of the igniter, the igniter glows and the burner ignites. When starting warm or when the burner cycles the burner never comes...
Disconnect power and turn off gas before working on this dryer. Working on gas dryers is not recommended for people who are not professionals.
Disconnect Power. Lift Cover on lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Looking down inside dryer on left and right see a 5/16” hex head screw about 6 inches down. Remove each side while holding front panel in place. Pull top of front panel about 3 inches forward from sides and then pull up. This will disengage the front panel from lower pressure clips and allow you to turn it sideways and expose the dryer interior. Reverse process to re-assemble. Take careful note of belt configuration BEFORE removing it. Draw a diagram of its travel.
Motor and idler pulley for dyer will be on right. Gas components will be on left. Replace All coils with Kit Number listed above. Take care not to touch or hit the ignitor or you will be replacing it also. It is VERY brittle.
Sep 06, 2009 | Dryers
Burner will not light
you need to tell me what the burner is doing when it starts up. Some basics to look for:
1- bleed pump of any air- is it a new install? 2- If you are getting fuel, are you getting spark on the electrodes? 3- if you are, you may need to adjust draw assembly air, and or air intake per Carlin specs.
Jan 02, 2009 | SySTOR Systems (400S52) Burner
Jenn-Air Gas Cooktop Model CVGX2423
you will need to contact your certified local service tech.you might have a distributor problem at yor ignitor box.if the problem is not with your ignitors.
Jun 30, 2007 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Replacing control valve/burner valve switch
This just started to happen to ours too. It's because you can't get let water get into the valve/switch assembly. Ours got so much water in there that it was making huge sparks and flames which charred up the switches. You may have to replace the whole 5-burner igniter switch assembly. I think it's part number 74010753. To access, remove 2 screws under the front of stovetop. open Top oven door to access. remove the 2 screws that hold the gas valve assembly. Remove 2 screws out of each burner assembly. Remove the green grounding wire on the right hand corner of stove top. The stove top will come off revealing the 5 white igniter switch assembly which is all wired together in parallel. Remove the large metal panel on the rear. There are two wires that are off the 5-burner switch assembly that you unplug. Replace this whole assembly and the problem should be fixed. Hope this helps
Jun 18, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Ducane 30400040 Stainless Steel Grill Logo
149 people viewed this question
Top Ducane Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
