Question about Maycom XP-168S 128 MB MP3 Player
My Maycom mbird mp3 player isn't recharging
My maycom bird mp3 player's battery seems to have died. It's one of earlier versions with a built in lithium battery. I accidently removed it from my pc and it crashed. I reformated it and then the battery wouldn't recharge; prior to this incident I have had no problems recharging it for the last 5 years. When it's connected to my pc I can transfer files onto as an external drive but when I disconnect it, it's completely dead. I have tried the Maycom website but it's down as I wanted to find out about the the specifications for the optional mains adapter to see if it will run off an adapter. No one here in Mexico is willing to try replacing the battery asits such a small unit and they are afraid of damaging it. Any help or advice would be greatly appreciated. thanks
My maycom scanner is stopping on a frequency,scans etc but no talking.?
Scanning may stop on channels with a carrier but no modulation (annoying) or channels where access is controlled by a code or channels arranged in talkgroups.
Feb 12, 2017 | Radio Communications
Squelch on maycom 108 works on VHF but not Airband. Was working last week?
factory reset: Push and hold AI + FUNC and turn the scanner on.
The message INITIAL are shown in the display..
Now it's reset to the factory settings,
with 124 MHz stored i memory channel 1 in the Air band,
and with 156 MHz stored i memory channel 1 in the "VHF band".
Oct 08, 2016 | Maycom AR-108 Scanner
RECEIVED RF ON AIRCRAFT BAND BUT NO SOUND
Check for mode or modulation type setting. Aircraft use AM modulation, most other radio bands will use FM.
Dec 19, 2013 | Maycom AR-108 Air Band Scanner
Maycom ah 27
I'm not familiar with this brand of radio but everytime I saw reverse polarity applied to a radio most of them have a blown diode near the input. If the diode reacted fast enough, you might get lucky and only that and/or the fuse need replacement. Most of the time, the damage is evident when you open the radio and do a visual check for burns etc.... Good luck and I hope this helps!
Dec 19, 2013 | Radio Communications
Maycom ar-108 no sound
maycom 108 no sound on air band,i to had this problem,hold radio in hand and hit on to table with a fair hard force on bottom until sound returns,yes this will work,dont be afraid to do hard,
Aug 06, 2013 | Maycom AR-108 Air Band Scanner
The battery seems to be dead, and it won't recharge
yaeh....it is replaceable ....you can get it done at your nearest sony service center....
good luck...
dont forget to rate me.....
Apr 15, 2010 | Sony Walkman NWZ-B135 MP3 Player
Maycom EM-27 Transmit noise
you don't need a noise supressor, i belive you have to change the mic or check real good your mic, specialy the transmit botton
Apr 28, 2008 | Radio Communications
Maycom XP-168S 128 MB MP3 Player Logo
91 people viewed this question
Top Maycom Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Maycom Audio Player and Recorder Expert? Answer questions, earn points and help others
