Question about HP Designjet 5500 (42 in.) InkJet Printer
How to reples belt HP Designjet 5500 - HP Designjet 5500 (42 in.) InkJet Printer
    Novelist:
  • 87 Answers
Good luck finding HP ASP's anymore since HP jacked us all around in spring 09 and killed most of us off for not bowing to their extortionist methods to get sales up. Anyway I've been doing these since they came out, all I took was an online certification test before Hp started charging for them. Open book test, it's not a big deal but an amount of skill on Designjets and knowing how to properly use the service manual is necessary - Sheri is right that if you botch the job you'll botch the plotter.
To ajitkadam37if you want to see the procedures to replace the belt just download the manual. DONT get sucked into buying a pirated PDF from some schmoe on eBay. Go to Feedroller.com and down the left navigation bar near the bottom there's a place to go to the manuals. When you are there click HP then go to the Designjet area and find the 5000/5500 service manual. Once you have it you can see the procedure - even if you don't repair it yourself, you at least know in advance if a repair company is trying to jack you around and make it more expensive. Also check the HP Parts store for the list price on the belt - many dealers should be drug dealers with making parts 400% and higher than list. I'm all for making a living but damn some of these places are one step from scam artists (Sheri likely will agree that some of our colleagues are bandits). New belts usually last much longer than the old rubber and cord belts - the replacements are nylon and other synthetic materials. My 2002 DSJ 800PS got a belt in 2004 (I put it in when it was owned by the previous who was my client) as it was shredded and crumbling - the belt was the factory belt. The new HP belt made of synthetics is now 6 yrs since it was installed and still looks like new even running daily.
At least read up on the procedure and you can decide for yourself if you want to tackle the job, or let someone else do it for you.
Posted on Jun 13, 2010
  • 241 Answers
You need a certified technician to replace the belt on these machines. Our technicians work on these machines all the time and it is not the most easy thing to do as they have taken the certifications and training to be able to do this. If you don't replace the belt correctly you may have other problems arise from doing this your self.
Pleas call your nearest HP authorized dealer.
Posted on Jun 04, 2010
0B0007
The error code means the vacuum fan is not detected.
Replace the vacuum fan. If that does not fix the problem, replace the Main Logic board. The fan can be ordered from: Designjet 5000 5500 Vacuum Fan and the PCA from: HP Designjet 5000 5500 parts
Jun 26, 2014 | HP DesignJet 1050c plus InkJet Printer
Hp designjet 5500 error code 0b0006
Hello. This error code indicates that the 5VDC and ground are shorted together by the trailing cable. Replace the trailing cable.
May 21, 2014 | HP DesignJet 1050c plus InkJet Printer
Hp designjet 5500 error codes
Error code 0C0040 is caused by the drop detector not detecting drops from at least 2 print heads in the same area. Run print head recovery on all the print heads and see if that clears up the problem. If not, then clean or replace the drop detector. Drop detector can be ordered from: http://www.lpscomputer.com/p-2512-c6072-60179-designjet-5000-5500-drop-detector.aspx
Sep 30, 2013 | HP Designjet 5500 (42 in.) InkJet Printer
How to find ip address in hp 5500
To locate the IP address with the HP Designjet 5500, follow these steps below:
Press the Down Arrow keys on the front panel until the Setup Menu is displayed. Press ENTER. Go to the Utilities menu and select Test Prints.Press ENTER. For the HP Designjet 5000 series, select Service Config. Press ENTER. For the HP Designjet 5500 series, select Network-card Config. Press ENTER
Feb 12, 2011 | HP Color LaserJet 5500 Printer
I have problem with my 5500 hp: check printhead path 2
The most common cause of the Check Print Head Path Error 2 is a worn out carriage belt. Open the top cover and locate the carriage belt. It is the long thin belt that extends the full length of the plotter. Use a light and look under the belt for debris that looks like pencil erasure crumbs. If the crumbs are there, the belt is disintegrating and needs to be replaced. See: http://www.lpscomputer.com/c-732-designjet-5000-5500-belt.aspx
Dec 01, 2010 | HP Designjet 5500 (42 in.) InkJet Printer
After print heads alignment its getting error 1004
The trailing cable is probably runing the printhead. Try replacing the printhead and trailing cable together. Parts available at: http://www.lpscomputer.com/c-622-designjet-5000-5500.aspx
Oct 13, 2009 | HP DesignJet 5500PS InkJet Printer
I don't know where to buy carriage belt
http://www.computercare.cc/osc/catalog/plotter/size.html
check this link out it sould give u your solution. Please get the size etc correct of the belt and iit should be really easy to find
Jul 05, 2009 | HP Designjet 5500PS 42 Printer Open Box
Change host name on HP designjet 5500
Go to the printer server and open up the printer properties in the control panel then in the shared tab, locate the name and change it.
May 21, 2009 | HP Designjet 5500 (42 in.) InkJet Printer
HP Designjet 5500 (42 in.) InkJet Printer Logo
1,217 people viewed this question
Seeker5211
Seeker5211
