Question about Lexmark Wheelwriter 1500 Typewriter
How do I release the set tabs - Lexmark Wheelwriter 1500 Typewriter
  • 610 Answers
Try pressing key marked "T clr", tab clear, and then press return key.If that doesn't work, remove the AA batteries and turn machine on. If tabs are cleared, you can re-install the batteries. The only job the batteries perform is to keep your tabs and margin sets in memory when you turn machine off.
Posted on Jun 04, 2010
I have a vintage Sears The Graduate typewriter, but can't figure out the tabs. I can set my margins, but I don't know how to set the tabs. Thank you
Normally same button sets or releases tab mechanical. Next button releases tab to next setting play around or look for the service op,man on internet
Oct 23, 2014 | Office Equipment & Supplies
At&t typewriter 6300 tab release instructions
You may have the R. margin set there. Press the mar rel key space to desired location press R. mar key.
DickyO
May 07, 2012 | Office Equipment & Supplies
Can not delete tabs and set margins
When using the margin release key just press and release it will not work if you hold it down.
DickyO
Apr 09, 2010 | Nakajima AE-800 Typewriter
Hi, I need to know how to set the tabs on my Hermes Baby typewriter and how to tab to the set place. No manual, and it has me floored. Has a key on the top left row with two arrows on it, each pointing in...
On the top row there should be 2 keys one + one - these are the set and clear tab keys. Theone with the 2 arrows is the margin release key there should also be a key that says tab that will move you rfom tab to tab.
DickyO
Feb 10, 2010 | Office Equipment & Supplies
How to clear and set margins and tabs please on
You must hit the carriage return button to find the current position of the left margin, then hit the mar release button and use the backspace key to move the carriage to the new position that you want the margin to be set at, then hit the left margin key to set it. Then move the carriage to the right to find the right mar, hit the mar release key and use the spacebar to move the right mar to the new position you want, then hit thr right mar kay to set it.
Sep 02, 2009 | Office Equipment & Supplies
How do I change the combination code for the glove box if there is not a way how would I find out what the combination is
I assume you know the current combination and can open it. To set the combination to a number code of your choice you must first remove the red plastic guard over the yellow tab next to the combination dials. Push the glove box release lever to the right to open the glove box. To change the combination:
1. With the glovebox open, hold the release to the right and slide the yellow tab up. This locks the release open and permits you to reset the code.
2.After resetting the code, write it down in case you forget it.
3. Slide the yellow tab down and the release will return to the closed position.
4. Close the glove box and move the dials off the code you set to lock it.
This is all from the 89 Pontiac Owners Manual. Good luck, hope it works.
Jun 15, 2009 | 1989 Pontiac Grand Prix
Changing tabs and move the right margin over some
On the L. side of the T/W ketboard are the keysmar left, mar right,tab set, tab clear and mar rel. Space to the location thayou want th R. mar and press right mar key, if it stops at the R. mar. press and release the mar rel key. To clear tabs tab to the one you want cleared and press tab clear. To set a tab space to the position and press tab set.
DickyO
May 26, 2009 | Nakajima AE-740 Typewriter
Tab Release
You can reset all functions to original settings by doing this simple self test.
1. Turn typewriter off
2. Hold down the margin release key.
3. While holding down margin release key, turn on typewriter.
4. release margin release key
typewriter will now begin to type on it's own.
5. Turn typewriter off and then on again
all settings will now be cleared.
Feb 02, 2009 | Swintec 7040 Typewriter
SWINTEC 8014 S TYPEWRITER
Press "MAR RELEASE", one key right of "MAR LEFT" in the upper left hand corner.
Press back space in the upper right corner until it's where you want it and press "MAR LEFT" to set it.
Tab over to where you want the right margin and press "MAR RIGHT"
Aug 05, 2008 | Office Equipment & Supplies
Lexmark Wheelwriter 1500 Typewriter Logo
65 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
