Question about Panasonic Workio DP-2500E Copier
This error occurred after a paper jam: panasonic dp 2500e error code e5-12 Main CPU/LPC Interface Error. Can you tell me how to clear the error. I work for a church and we have limited funds for repair.
  • rhpc Jun 08, 2010
    Panasonic dp 2500e copy machine:
    Please accept or reject most recent solution
    Solution #1 posted on Jun 04, 2010
    hbristol173
    Rank: Wiz
    Rating: 81.35% , 20 votes
    Hello welcome to Fixya, the error code E5-12 CPU/LPC interface problem can be fix by reinstalling the drivers for your printer. If you do not have the CD for the printer please go tohttp://www.panasonic.com/Business/office... and download the drivers for your printer.
    Jun 04, 2010 - Thank you for your reply. This is not being used as a printer with the computer. When we upgraded to a new computer we found that there are no windows vista drivers for the panasonic dp2500. We began using it only as a copier. I don't have a computer to connect to it.
    I still have the same error code mentioned before: e5-12 Main CPU/LPC Interface Error
    Can you please help? Thank you.
  • 2,272 Answers
Make sure that the mis-feed indicator goes off
after removing all mis-feed paper.If the indicator is still on that means there is still a paper jam some where.Check properly and remove the paper jam.
Cpu/lpc interface error is related to internal board.The internal board connections needs to be checked.Either any of the connection is got loose or shorted.It needs to be checked.Panasonic 2500e copier is heavy duty copier.It requires proper technician familiar with this brand and model to get the internal board checked.The copier is having good life.Mostly all the users of this product are satisfied users.Get it checked by technician and get the internal board checked for clearing this fault.
There is only one reset procedure to clear minor error codes.
You can try this as mentioned.
First turn the copier ON.
Open all the trays .Then remove all the toner cartridges from the copier.Remove drum unit.Then also remove paper from the tray.Then without turning the copier off,just directly unplug it from main power outlet.Wait for 10 minutes.Then turn the copier On then reinsert everything and close all the trays and check.the reset is done.
but if this is not helping in your CPU/LPC error code then the internal board needs to be checked.
Confirm that there is no paper jam in the copier before calling a technician for circuit board checking.
Thanks.
Posted on Jun 08, 2010
    President:
  • 567 Answers
Hello welcome to Fixya, the error code E5-12 CPU/LPC interface problem can be fix by reinstalling the drivers for your printer. If you do not have the CD for the printer please go to http://www.panasonic.com/Business/office/support-downloads.asp and download the drivers for your printer.
Posted on Jun 04, 2010
  • rhpc Jun 04, 2010
    Thank you for your reply. This is not being used as a printer with the computer. There are no windows vista drivers for the panasonic dp2500. When we upgraded to a new computer we started using it only as a copier. I don't have a computer to connect to it. It is only being used as a copier.
  • Hilton Bristol Jun 09, 2010
    You should try to get someone with a windows xp computer to connect the device to and start it to see if you can if the problem will show up on the computer screen and if you have you can get more information about the problem. I need to have the information about the device while it connect to a computer, this will give me more ideas about the problem.
E4 02 error code
Paper Jam Causes 1. Paper Jam in Fuser Unit. 2. Paper Exit Sensor clear and close the front cover
Jan 10, 2014 | Panasonic DP-8060 Copier, Workio DP8060...
Machine Error E$-02
To enter service mode you press Function orginal size ledger and "3" simultaneously once in F9 -6 -04 for fuser reset. If it comes back need a new fuser unit:( or worse main board.
Mar 31, 2010 | Panasonic Workio DP-3520 Copier
DP 3530 error code E04-02
Hello sir; You have to look at heating unit you havv paper jam over there!
Aug 23, 2009 | Panasonic Workio DP-3530 Copier
Error EO4-02
the error is a fuser paper jam, ether the sensors are going fuzzy or you have a broken fuser finger or you need a new fuser.
Jan 09, 2009 | Panasonic Workio DP-3520 Copier
My Panasonic DP-2330 .... Is Showing Error Code E04-02
How enter to service mode in panasonic DP2330 copier.
Dec 01, 2008 | Panasonic WORKiO DP-2330 Copier
My Panasonic DP2500 copier
remove paper jam light stuck on, but there is no paper jam
Apr 17, 2008 | Panasonic Workio DP-2500E Copier
Panasonic 2500
e4 errors means fuser error, probably you encountered lots of fuser jamming.
the best thing to do is to ask your service provider to check your machine but for the mean time, you could erase the error log.
press function + orig. size + 3
press 9
find ram initialize
find LBP FUSER RESET
note: make sure that LBP FUSER RESET is the selected one
press set.
restart your machine
if you still encountered an e4 error, it means that there is a physical/hardware problem on your fuser unit.
i hope this could help u. : )
Mar 31, 2008 | Panasonic Workio DP-2500E Copier
Getting J33 code on panasonic workio dp-2500
That's a registration sensor error. 9 times out of 10, the registration sensor's spring fell out of place and that sensor is not popping back. When you open the right door, you'll see a sensor flag (plastic flag) sitting in the middle of a rubber roller.
Nov 16, 2007 | Panasonic Workio DP-2500E Copier
Panasonic Workio DP-2500E Copier Logo
91 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
