Question about Logitech MX900 Bluetooth 800 dpi Optical Mouse with Bluetooth Wireless Hub (MOLOMX900)
Is Logitech MX900 charging?
Silly question... I have a Logitech MX900 wireless mouse, and I haven't used it in years, so I don't remember how to tell if it's charging. I just put Energizer rechargeable batteries in it. The red light on the top is flashing very quickly, followed by a slow flash by the red light on the bottom. Is this correct?
Genius2k4
  • 27 Answers
SOURCE: flashing light
cycle the batteries in a external charger a fex times (charge then discharge) I suspect that over the years of using then putting it in its dock the batteries have had a very erratic charge discharge cycle cycling them as I suggest should bring them back.
Posted on Jul 25, 2007
SOURCE: Logitech M700 Mouse recharging problem
try replacing batteries by newones,since they are ni-cd type,they do have limited no.of charge/recharge cycles and tend to lose performance with time.
Posted on Jan 09, 2008
Squirm57
  • 152 Answers
It depends on the mouse. Sometimes the red light flashes to signify the processing of a command. If it is continually flashing, then you may want to replace the battery.
Posted on Apr 06, 2009
  • 9 Answers
SOURCE: red light flashing top of logitech wireless
The flashing light could be a reflection from the LED and mirror or laser on the bottom of the mouse. I had this similar problem and it drove me nuts until I happened to hold it up to a mirror and noticed the flashing was in sync bot top and bottom of the mouse.
Posted on Jun 10, 2009
SOURCE: CE0682 logitech mouse
"Normal" batteries are 1.5 Volts per "Cell" However Ni-Cads, rechargeables, each "Cell" is only 1.2 Volts. So the rechargeables simply may not work... If they do work, then there is NO reason why not.
Posted on Feb 14, 2010
My wireless Logitech mouse stopped performing. I changed batteries. the red light comes on even before I changed the battery. I have had it about 3 months. Wal Mart told me to look on the back of mouse. ...
So much for Wal-Mart tech support.
If your mouse is not working, first check the batteries to be sure they are good.
You wireless mouse has a USB "antenna" or sending unit. It may have a button on it that says "connect." If so, push it.
The mouse itself has a little button on the bottom that says "connect."
Push that one next. It should now work.
If it doesn't, switch USB ports and try again.
And no, we don't charge for this answer.
May 13, 2011 | Logitech Cordless Mouse
How do you change the battery in the Mouse
model no. all the wireless mouses have battery partition at downside. check it
Mar 08, 2011 | Logitech Cordless Mouse
I CAN NOT GET MY WIRELESS MOUSE TO WORK ON MY COMPUTER,,IT JUST RESENTLY STOPPED WORKING,,AND I HAVE PUT IN NEW BATTERIES,,CAN YOU PLEASE GIVE ME SOME SUGGESTIONS
Silly question for me for you -- are the batteries in correctly? Have you tested the batteries to be sure BOTH are up to 1.6 or more volts with a voltmeter? Even new unpened battery packs may be short on charge and not have enough juice within them...
If the above is not the issue, try the receiver of the wireless mouse, it may not be fully engaged.
Jan 05, 2011 | Logitech Wireless Access Duo Optical...
My Logitech mouse is wireless # CE0682 and the red light on the mouse is always flashing, even when on the receiver. I also have some problems when I want to use the mouse to hilight a block of text, as I...
Gina, I've had my Logitech ce 0682 for years and have had some similar problems. The mouse is supposed to rest in the cradle and recharge the batteries, but I've noticed that it rarely works for me. The connectors on the mouse seem to scuff and corrode easily and I'm sure that degrades its ability to charge batteries. So my solution was to buy a 4 pack of rayovac rechargable batteries(AA) and a usb battery charger. I never put my mouse in the cradle now and keep 2 batteries recharging at all times so I always have fresh batteries when that pesky red light comes up telling me the batteries are dying. As far as your highlighting text problem. Sorry don't have a solution on that one.
Sep 03, 2010 | Logitech Cordless Mouse
Logitech mouse frozen up we changed batterys in
If the mouse is freezing up though the batteries are fully charged, here's what you need to do:
1. Try to use different batteries just to make sure that it's not a power issue.
2. Connect the wireless USB dongle into different USB ports of the computer.
3. Try to connect the USB dongle in different computer and try to use the mouse (to make sure that it's not a computer issue).
4. Make sure that there's no cordless phone, cell phone and other wireless devices that might interfere the wireless signal.
The Logitech wireless mouse is running on 2.4MHz frequency, same frequency as the other wireless devices. Any wireless device might cause the mouse to freeze.
If same problem occur, then it's a hardware problem. Contact Logitech and RMA the mouse.
Thank you and good luck!
Apr 18, 2010 | Logitech Cordless Mouse
How do I install/begin using wireless mouse? It worked before then batteries ran out and I can't remember if I need a disc to re-install.
Most Logitech wireless mouse are just Plug-n-Play and it does not require any driver installation. All you have to do is to plug the wireless dongle to the computer and connect the mouse. Here's what you need to do:
1. Make sure that the batteries are fresh or fully charged.
2. Turn ON the mouse using the switch button.
3. Locate the connect button on the dongle (receiver) and then press it once.
4. Hold down the connect button underneath the mouse for 5 secs. and then release it. And the mouse should work.
If the mouse is not responding, then hold down the connect button on the dongle and on the mouse at the same time for 5 secs. and then release them both. Move the mouse around.
Hope this helps and have a great day!
Jul 17, 2009 | Logitech Cordless Mouse
Acer N30 - Bluetooth License Expired?
Seems like the Bluetooth Stack that you have is a licensed software, you may need to buy a license or switch to a free stack like the Windows stack, which will require a Microsoft dongle to activate.
Aug 10, 2008 | Logitech MX900 Bluetooth 800 dpi Optical...
Computers & Internet Logo
97 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
