Question about Ryobi Garden
Hi, My Ryobi One+ cordless line trimmer refuses to recognise a fully charged battery. It's only 18 months old, and repeated calls to find a local service dealer have proved fruitless.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 183 Answers
Give up with it as the problem will not be solved buy a new machine
Posted on Jul 27, 2010
Ryobi 40v trimmer stops working with 1/2 charge left on battery
Battery is weak. Those lights are really useless...more a marketing gimmick. It almost sounds like it developed a memory...this happens when certain types of batteries are not fully discharged before being placed on the charger. Replace the battery and make sure to follow charging directions for that particular type of battery
Aug 08, 2016 | Ryobi 40-Volt Lithium-Ion Cordless String...
How do I get the old line trimmer spool off of my Ryobi 18 volt cordless trimer
When looking at the head, you will see to two gray rectangle pieces. Press them both at the same time between your thumb and forefinger and then pull. It should come unlatched and reveal the line spool on the inside
Jul 25, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
How do I advance the line on my Ryobi 18V trimmer?
full throttle, tap on ground, line should feed automaticaly.
Jul 23, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
Electric ryobi weedeater with good battery won't start
Ryobi Trimmers unscrew halfway down the shaft (so it fits in the box). If this gets loose, the trimmer will stop working. Simply tighten the connection between the upper and lower half.
Mar 31, 2013 | Ryobi Lithium Ion 18 Volt 18v Cordless...
Cross section of ryobi 18v trimmer
the wiring maybe disconnected, either at the switch or down near the head of the trimmer
Sep 09, 2012 | Ryobi Lithium Ion 18 Volt 18v Cordless...
How long should a fully charge battery last on WG250E Hedge Trimmer
This is the info i found on WG250 battery . It says up to 50 min below in the features. Hope it helps
Battery
The WORX WG250 hedge trimmer incorporates an 18-volt 1.7 Ah Ni-Cd battery pack. You can use this battery pack with other WORX Ni-CD PowerShare tools. The included charger takes about an hour to restore a dead battery to full charge.
Cordless Hedge Trimmer 18v Worx WG250E jQuery(document).ready(function($) { $("a[rel=product-image-gallery]").fancybox( { 'transitionIn' : 'elastic', 'transitionOut' : 'elastic', 'titlePosition' : 'over', 'titleFormat' : function(title, currentArray, currentIndex, currentOpts) { return 'Image ' + (currentIndex + 1) + ' / ' + currentArray.length + ' ' + title + ''; } }); });
Features
  • Wall mount bracket
  • 3 position adjustable front handle
  • overmould soft grip for user comfort
  • Quick release handle
  • Double insulated
  • Volts: 18
  • Blade length: 510mm
  • Cutting capacity: 14mm
  • Blade action: Dual
  • Run time: Up to 50mins per charge
  • Charge time: Up to 1 hour
  • Machine weight: 3.1Kg
  • Comes with one battery and a charger
Sep 13, 2011 | Worx Wg250 20inch 18volt Cordless Hedge...
My trimmer wont start. thought it was battery put a new one in worked for a few minutes and then stopped working
your batteries aren't charging fully, check them fully charged with a volt meter,, fully charged they should have a reading of 18.5 volts, if not they are not charging, and either the batteries have used up their life, or your charger is on its way out
Jul 15, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
Trimmer is one yr old. Battery was kept inside during the winter and now won't take a charge. I called the Worx service nbr. Waited for 35 min. Went on the website Worxbattery.com and can't...
You can buy replacement batteries on ebay. If you can afford it I would highly recommend buying a quality trimmer at your local hardware store. I have had experience with the Worx trimmers and they are just plain cheap.
Jun 06, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
Garden Logo
160 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
