Question about IBM ThinkPad T40 2373 Notebook
Thinkpad T40 2373 fan replacement: long or short?
Hi-
I have a noisy fan (intermittent grinding noise) that I need to replace on my t40 2373. When I search for parts on EBay I have the option of getting a "long" or "short" fan assembly. Is there any way to tell which I need without disassembling the laptop?
thanks-
Pablito
  • 2 more comments
  • pablitito Apr 10, 2008
    Please send link. thanks
  • Anonymous Apr 17, 2008
    mine has just died can you tell me how to replace it?
  • Anonymous Sep 10, 2008
    Same problem....getting "Fan Error" message and automatic shut down....how to replace fan, PLEASE.
  • Anonymous Mar 19, 2014
    Fan is intermittently grinding, after being in my bag for a while. Reverts back to normal when closed and carried for a minute or two (i.e. when its moving). Could be a wire or something hitting the fan, but I've no means of opening it
  • 159 Answers
Description
Thinkpad T40 2373 fan replacement: long or short? - s.gif s.gif Thinkpad T40 2373 fan replacement: long or short? - s.gif Thinkpad T40 2373 fan replacement: long or short? - s.gif Item Thinkpad T40 2373 fan replacement: long or short? - s.giffics - Item Condition
Thinkpad T40 2373 fan replacement: long or short? - s.gifdition: Used
Thinkpad T40 2373 fan replacement: long or short? - s.gifsrc="http://i.fixya.net/uploads/images/s.gif" alt="s.gif" class="h_mi" />
s.gif s.gif IBM THINKPAD T40 T41 T42 CPU Short Cooling Fan FRU 91P9759 91P8393 this is the fan you need. please remember to rate the solution. will send you a link to my site with the how to disassemble and reassemble
Posted on Apr 10, 2008
Speed queen noise when on spin
follow this test and fix it. God bless you
  1. MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  2. Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  3. Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  4. Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replaced.
Nov 19, 2013 | Microwave Ovens
Gh5184xps3 microwave
this cause noise ; God bless you
  • MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  • Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  • Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  • Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replace
  • Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#13#ixzz2ZPm395lp
    Jul 18, 2013 | Whirlpool Microwave Ovens
    When i turn on the laptop the lights under the the screen flash
    Hi from what you are describing it looks like the laptop heat sink (fan) needs replacing or the motherboard itself needs replacing
    I would recommend that the laptop be booked into a reputable repair firm to investigate further
    Feb 10, 2010 | IBM ThinkPad T40 2373 Notebook
    My laptop is making a loud noise
    Hi again.
    It sounds to me that the PC is overheating, get a can of compressed air and give short blasts through the air vents and the CPU fan (located underneath the laptop) once your happy that all the dust has been blown out restart the PC and it should be quieter from then on.
    Good luck and thanks for using FixYa!!
    May 11, 2009 | IBM ThinkPad T40 2373 Notebook
    Hp laptop dv9500 noisy and loud fan ...
    The sound you are hearing is probably the fan, This fan has a noisy bearing and will eventually lock up and the fan will stop spinning and therefore the CPU will overheat and shutdown.
    The fan needs to be replaced.
    Feb 13, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
    T40p fan replacement
    dear rickcat,
    i was able to get you screen shot assuming you already want to replace a new fan please take note that these screen shots guideline you but not exact model.
    Dec 14, 2008 | IBM ThinkPad T40 2373 Notebook
    Fan making noise help
    Start by taking the machine apart, cleaning the fan, and checking the connection. The failure may be due to debris buildup or a loose connection, and I've also seen fans stop working because a hair has gotten wound in them. If it still doesn't work properly after cleaning, then it will need to be replaced. Here's a link that has breakdown diagrams and instructions, this should help.
    http://repair4laptop.org/notebook.html
    Jun 26, 2008 | IBM ThinkPad T40 2373 Notebook
    Intermittent grinding fan noise on T40
    the site is ebay. the walk through is contact me when you have the new fan i'll walk you with yahoo messenger have a t40 at home that i can pull up and showv you how ok bakerandre2000@yahoo.com
    Apr 09, 2008 | IBM ThinkPad T40 2373 Notebook
    IBM ThinkPad T40 2373 Notebook Logo
    2,922 people viewed this question
    Top IBM Computers & Internet Experts
    Alun Cox
    Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
