Question about Quintum (501-0025-00) (501002500) Call Relay
Quintum Call Relay - Need Help
Need help with Quintum call relay to do SIP calls to pass through from origination DDI to client wholesale
I.e. we wish to use this relay to do wholesale DDI and calling card access selling service.
Happy to pay for expert service and training.
Please help - admin@zamirtelecom.com
Distributor of Quintum
Posted on May 15, 2008
What are the advantages of SIP for VoIP?
SIP (Session Initiation Protocol) is an application layer protocol that is based on IP. It is a major communication standard mostly responsible for VoIP (Voice over IP) telephonic system. In the traditional phone networks, ISDN (Integrated Services for Digital Network) is considered as the communication standard designed for the transmission of voice traffic. Both ISDN, and SIP are usable with equal reliability; however, in ISDN system, the clients need to pay for the data service, and voice service separately, while in the SIP system there is no separate charge for data and voice. Thus, SIP is just good for the customers as it decreases the telephone charges drastically.
Reliance Global Call-Enterprise is one of the most reliable and popular SIP trunk providers over VoIP. It helps to install SIP trunk at the organizational levels, enabling to cut international call rates like local calls. Moreover, the users can connect their landlines, as also mobile lines with the SIP trunk service for VoIP.
Feb 22, 2017 | The Computers & Internet
I got 98 GMC Envoy there no power to A/C fan control, 4x4 switch, temperature gauge and fuse gauge,I'm try to sawp the fuse and relay under the hood and check under dash fusebox alls fuse ok but
if there have some problem on your A/C, may be the Multi-Diag Access J2534 can help you. It has the function for air condition, such as Diagnosis of cooling electronic,
Reading settings cooling circuit,Test servo actuators
http://www.allobd2.com/wholesale/Multi-Di@g-Access-J2534-Pass-Thru-OBD2-Device.html
Oct 08, 2012 | GMC Envoy Cars & Trucks
I want to confugre Tenor A800 to make SIP
Hi
For making/reciving SIP calls with A800 u need its SIP firmware.
u can add me on MSN for more help.
MSN : hezare3@hotmail.com
Apr 22, 2011 | Quintum Tenor A800 (501-0026-00)
Is that mean D-Link DVG-G1402S router does not support VPN Server?
IT does Security • SIP Authentication with Password Encryption • Configuration Download Using HTTPS and SSL/TLS Clients Certification Encryption and Authentication • VoIP NAT Traversal (SIP/STUN) • NAT/Firewall (NAPT, TCP/UDP, DMZ, ALGs) • VPN Pass-Through • Packet Filtering by IP Address, Port Number, and Protocol
Mar 06, 2011 | D-Link DVG-G1402S Wireless Router...
When I connect my router to my modem, I cannot surf the net, nor can I access my router homepage. I have my modem in bridge mode, but I appear to have no connection.
I would set it up in 'router' mode. Bridge mode is for a specific application for an intranet (not internet).
Bridge Mode Router Mode Does not block any broadcast or multicast Blocks and provide protection against broadcast storms Transparent bridge and can pass Non-IP protocols Only IP protocol is supported PPPOE protocol Pass-through No PPPOE protocol pass-through Able to transport VLAN tagging Doesn't supports VLAN No network segmentation. One broadcast domain Network segmentation (Clients can be on different IP subnet) Can only relay the DHCP client's request to the external DHCP server Can Act as DHCP server & relay which Prevents IP conflict & DHCP Injection Bridges maintains bridging table (Mac) & STP can be used to avoid loops No STP feature; maintains routing table External bandwidth Controller can be used to control the speed of the clients by Mac or IP address External bandwidth Controller can be used to control the speed of the clients by IP only In client device, it uses MAC address to associate which requires WDS compatible AP Use SSID to associate, work with any 802.11a/b/g AP
Dec 30, 2010 | Linksys BEFSX41 Router (DHBEFSX41)
I have a tenor dx 6120 connects to an omnipcx office but i cannot make a voip call with it although I 've configured it to make sip call
Unfortunately, there are any number of reasons this could be a problem. The only sure way to tell what's going on is to look at the SIP traffic directly.
If you are up for it, here are the steps you'll have to take:
1. Download and install Wireshark(it's free) from www.wireshark.org
2. Install wireshark on a PC and connect it to the same switch as the Tenor,
3. Configure the switch to use the PC port as a monitor port for the port the tenor is connected to; you need a managed switch for this.
4. Start a capture with Wireshark for the appropriate interface. You'll probably see a shocking amount of traffic on your network all of a sudden. Don't worry, we're going to filter out the stuff that doesn't matter and it will be much more manageable.
5. Click the Telephony tab and select "VOIP calls". Try to make a call or two and see if this provides any useful info.
6. If #5 didn't help, go back to Telephony and select the "SIP" filter. This will provide more basic info on what is going on with the Tenor by showing every SIP packet. If you don't know anything about SIP it can be pretty hard to read though - you may need to post results here and let us take a look.
Jul 15, 2009 | Quintum Tenor DX2048 (501012100) 2x10/100...
Several problems, please help
try to debug test the line .. maybe one of the line are loose..
Mar 01, 2009 | Quintum Tenor A800 (501-0026-00)
Quintum DX2024
These links will help you:
http://www.quintum.com/support/xplatform/ivr_acct/webhelp/ANI-based_Post-Paid_Services.htm
http://www.quintum.com/support/xplatform/ivr_acct/webhelp/Pre-Paid_Application.htm
Jan 06, 2008 | Quintum Tenor DX2024 Router (501011500)
Quintum DX2060
http://www.quintum.com/support/products/2G/tenor_2G/sysdoc/webhelp/calleridgeneration.htm
Try the search box at this URL: http://www.quintum.com/support/
Just copy & paste the parameter name into the box.
Jan 13, 2007 | Quintum Tenor DX2060 (501-0122-00)...
Quintum (501-0025-00) (501002500) Call Relay Logo
187 people viewed this question
Top Quintum Computers & Internet Experts
David Payne
David Payne
Are you a Quintum Computer and Internet Expert? Answer questions, earn points and help others
