My jvc kd-r310 worked fine and then i took the faceplate off and music was still coming through the speakers. i then put faceplate back on and it flashed "protect" and nothing worked. then i took faceplate off again and back on and now i get nothing. i pushed the reset button and can hear that there is power to the unit but nothing happens just blank display
  • 942 Answers
Since your JVC worked and just the faceplate of your system that did not work, there might be a issue with comes to faceplate.
The faceplate itself might be old , meaning JVC receiver works but the faceplate is not compatible to it. I suggest to check the faceplate manual and how long you have been usen the faceplate. If in case this is brand new, you could replace the entire face-plate and cover it in grill cloth (if the original stuff would come off you could use that or buy new cloth).
If that did not work, then you can check your face plate manufacturer and ask what will be the compatible face plate for your JVC receiver...
Posted on Jun 04, 2010
  • 1 more comment
  • red98jc Jun 04, 2010
    the receiver and faceplate are barely a month old. i think that the faceplate is totally for the actual deck because that is how it came in the box brand new from the store a month ago. is it possible that the faceplate is just faulty from the factory? if so i would think that the store would replace it or jvc themselves.
  • backflip420 Oct 15, 2010
    im having the same problem. i took my car to a audio install store and they said i have a wire grounded some where, and my back speakers are getting feed back when i reset my deck and put the face plate back on and it went back into protect
  • tyler_houck9
    tyler_houck9 Feb 20, 2013
    I have same problem in a way. I get power to the headunit, but none of my buttons work, so its stuck playing a cd, and only way to turn it off is to remove the faceplate. Any ideas?
How do i get protect mode off on a jvc-kd-r310
Are you a technical person? If so, reply. Otherwise it is advisable to take it to a service center.
Oct 20, 2014 | JVC AM FM CD DET FACE CAR STEREO
Replacement faceplate for a jvc kdhdr50
Are there other faceplates that are compatible with my jvc kd-hdr50 because someone stole mine and i cant find anywere that sells just faceplates
Jun 27, 2012 | JVC KD-HDR50 Car CD/ MP3 Player
When playing from the AUX (i.e. iphone), can't hear from both speakers, only one; but when playing from a CD, the sound is fine. Any suggestions/advice/help? The odd thing is that if I press down
hi, seems like you may have a faulty aux jack socket(if the socket is mounted onto the face) or you may have some dry joints on the socket, or even a cracked pc board around the aux socket connections. also try cleaning the face connection pins both on the unit and on the face. if you not technically minded, check out you jvc repair center. cheers!
May 24, 2012 | JVC Kd-r310 Car CD/ MP3 Player
Why does my cd player read the cd and plays but Im not getting any audio
If it was working before and no changes made to wiring, then it needs service.
Feb 15, 2012 | JVC Kd-ahd69
How do i reset the cd player back to factory defauly.
The reset switch is usually behind the faceplate (there should be a tiny hole).
Using a paperclip (or fine tip pen), gently press and hold this switch in, for approx. 3 seconds.
Nov 28, 2011 | JVC Kd-r310 Car CD/ MP3 Player
My jvc kd-r418 is protect
that happened to me too once, in my case it turns that one of my speaker wires came loose from back of speaker and was touching the metal in my truck. after correcting the wires it still said protect, i then found the reset button located under faceplate and held it down for a few seconds and my receiver was back in business.
Oct 01, 2011 | JVC Kd-r418 Car CD / USB/ MP3 Player
How do I set the color on my JVC KD-R310 ? I already lived through the 1970s. I don't need the disco lights effect in my car.
push the color button when the display light's up you can choose between one color for the button or one color for the display by turning the volume button and choose which color fit's your liking when u find your color push the volum button. that should help you out on that part.
Apr 24, 2011 | JVC Kd-r310 Car CD/ MP3 Player
What are good settings to have to make the music sound clear for a jvc KD-R310 deck?
you will need to access the bass and treble setting on the unit.
If you have stnadard speaker then dont put the bass to high as you can not turn the volume up high.
The same for the treble.
Set them at about the same and turn the volume up until it sounds good.
If it is to quiet then turn the treble and bass down and then the volume up more
Mar 02, 2011 | JVC AM FM CD DET FACE CAR STEREO
JVC KD-R610 is stuck in Protect mode
Try disconnecting your battery, reconnecting it, and resetting your stereo. If that doesn't work, the constant power (yellow wire) or ignition wire (red wire) may have come in contact with ground or isn't properly connected. Make sure everything is connected properly and try resetting your stereo. If it is still flashing "protect", the unit needs servicing Contact JVC Customer Care Center at: 800-252-5722.
Jul 22, 2010 | JVC AM FM CD DET FACE CAR STEREO
JVC KD-LH300 Wont Work
Clean the parts on the connector between the faceplate and the stereo maybe get dirty
Sep 04, 2008 | JVC Sirius KD-LH300 CD Player
114 people viewed this question
 Grubhead
Grubhead
