Question about Kenmore 24032\24036 Top Load Washer
Replacing drive coupler
I need to replace the coupler on my washing machine, but was wondering if I was going to run into any surprises, when I take the clutch casing off.
Kenmore Model # 20936
Thanks
    President:
  • 1,937 Answers
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look in the section for the motor, pump gearcase and you'll see the Motor Coupler.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
YOU DON'T HAVE TO PULL THE GEARCASE AND CLUTCH.
See the following Whirlpool / Kenmore Service manuals for these machines.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Posted on Jun 04, 2010
I have a Kenmore top loading large capacity washer model 1028882791. It began washing as usual then began to making a loud humming sound. The agitation stopped. It only makes a loud humming sound. I...
The humming sound is coming from the drive motor running but unable to drive the agitator nor the basket to spin. The drive motor is definitely running as the drain function works because of the fact that drain pump is directly coupled with the rear spline of the motor. The drain pump works in either direction as long as the motor runs. The problem is obviously a broken motor coupler which transfers the mechanical energy of the motor to the transmission. The solution then is to replace the broken coupler. Click on the link below for the detailed step-by-step procedure in replacing the motor coupler.
Replacing Motor Coupler on Kenmore and Whirlpool Top-Load Washing Machines
Jan 13, 2011 | Kenmore Washing Machines
Tip
Washing Machine Motor Coupling Repair
How do you tell if your washer motor coupler has gone bad? Motor couplers are used on "Whirlpool" direct-drive washing machines. In some Whirlpool or Whirlpool-made washing machines, the motor coupler connects the drive motor to the transmission. It operates under extreme conditions and stress. Mostly during start-up and stopping of the motor. The main symptom of a bad motor coupler in the Whirlpool made washing machines is that there is no agitation or spinning action, along with the sound of the motor running. Since the motor is running, but there is no connection to the transmission, the machine will not agitate or spin the clothes out. The motor will simply run, but nothing else happens. In this case, the coupler is most likely cracked. To replace the coupler in the Whirlpool made washer, you must first unplug the washer, remove the top console by either removing the screws or using a putty knife to unsnap the top clips, rotate the console back, pull the washer front off by tilting back,and set the cabinet aside. Remove the clips holding the pump and motor on. Remove the bolts holding the motor on. Inspect the coupler and replace with a coupler if necessary. Re-assemble the motor and pump assembly. Re-assemble the washer in reverse order of disassembly. Plug in and test by running the washer through it's paces.Here is a video on repairing the motor coupler.
on Oct 18, 2011 | Whirlpool Washing Machines
The drum won't move and it make like a buzzing sound.
It doesn't agitate If your washer doesn't agitate, check these: Lid switch Motor coupler Belts Clutch Drive motor Drive pulleys Transmission Agitator Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley
Jan 21, 2010 | Kenmore Washing Machines
Hotpoint 9533 the wash machine dosen't wash
Jan 17, 2010 | Washing Machines
Washing machine fills with water and will not go to next cycle
Jan 03, 2010 | Whirlpool Washing Machines
My wilkins servis washing machine will not wash cycle
It doesn't agitate If your washer doesn't agitate, check these: Lid switch Motor coupler Belts Clutch Drive motor Drive pulleys Transmission Agitator Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Jan 03, 2010 | Washing Machines
Agitotor not spinning during wash cycle M/N: LSR8244EQ1 Machine less than 10yrs. old, good shape
Jan 02, 2010 | Whirlpool Washing Machines
Washer will fill and spin but will not agitate ge top load washer wwsr3130w0ww
Jan 02, 2010 | GE WBSR3140DW Top Load Washer
Washer runs but wont adgitate
Jan 01, 2010 | KitchenAid KAWS850L Top Load Washer
Rab5232ew it will wash and pumps the water out
no belt, drive coupler it's probably broken and needs to be replaced. but if its the drive coupler it wont wash either so recheck it.if it still washes then check tub for object through holes jamming tub..you should be able to force the tub around by hand.
Jun 12, 2009 | Roper RAS8445KQ Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
98 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
