Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
My motor is not running is this reset button going to help and where is it/
    Scholar:
  • 106 Answers
Red little button is (hard to see it but it is there) on the bottom of the unit. With the power turned off, depress the red button....should feel it push in and stay. if this does not work, replace the wall switch where you turn the disposer on and off, if this does not work replace the entire unit.
Posted on Jun 15, 2010
ALSO IF ANYONE HAS ANY TROUBLE WITH RAZOR SCOOTERS WITH GETTING THEM TO GO,IT CAN BE THE TENSIONER,WHEELS,CHAIN,MOTOR,BATTERY,CHARGER,CONTROL MODULE,RESET BUTTON,LIGHT SWITCH,AND THROTTLE.IF IT WORKS,BUT...
I purchased my batteries on E-bay. Selected the highest rated with a Square trader warranty. Delivery time was 4 days, new was was going to ask.
Delivered to my house for$21.00 with both batteries, charged and ran perfectly. Extended Warranty was also offered but declined.
Batteries still working great 6-months latter.
Mar 08, 2014 | Razor E300 Scooter
Quit running when I turn the switch on nothing
1- You likely overheated the motor find the small red button on the end of the motor and push it after the motor cools down some
2- You tripped a circuit breaker in the electric panel, go to the panel and look for the breaker that does not line up with the rest of them and move it off then back on.
3- If your outlet has a GFI on it go reset the GFI reset button.
Nov 07, 2013 | Delta Saws
Reset button Hoover
The majority of hoovers do not have reset buttons. Some vacuums that do, have one that only controls the brush roller when they are run by a separate motor. I would really need the machines model number to properly answer your question.
Although they do not have "reset" buttons, most do have thermal resets. If the vacuum motor overheats. Turn off, unplug and wait for 1 hour or more for the thermalfuse to "reset" itself. Also, clean or replace all bags/filters because that's usually the cause of overheat in the first place.
Also, vacuums go dead for a number of electrical reasons. Many of the Hoover uprights have an internal switch in the upper body below the handle that commonly fails and needs replaced.
Hope this helps.
Feb 20, 2012 | Hoover Vacuums
We have a 100 ton press electric motor an a hydraulic pump.You have to hold in on the reset to make motor run.
The overload switch may have failed. Does the motor stop if you let go of the reset? If the motor (single phase) has a capacitor start, the capacitor may have failed partially which will cause overload because the motor just sits and hums without turning. If this is a three-phase motor, the overload button should shut off the motor starter which directly removes power to the motor. Don't jury-rig a switch to bypass the problem. Hope this helps!
Dec 22, 2010 | Garden
My outside fan will not run and the inside unit runs constantly. can't push the reset button on unit outside
Your out door unit fan motor not runs due to pressure not build up at Heat mode. If its cool mode only fan runs with compressor when thermostat calls for it.
Without having technical knowledge, don't press any reset button. Hope it's helpful?
Dec 09, 2010 | Ruud Central System Air Conditioner
WONT START CAN HEAR TIMER RUNNING DOOR BUTTON WORKS MAKES START BUTTON RESET CAN HEAR IT RESET BUT NOTHING HAPPENS WHEN I HIT THE START BUTTON
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 14, 2010 | Dryers
Makita 5200 Mac doesn't run
one of two things, either you have a bad start capacitor on the motor or a defective start switch inside the motor, either one can be checked at a electric motor shop
Dec 12, 2009 | Makita MAC5200 Electric Powered Air...
Compool 3600 Spa side remote
Do not reset while the motor is running. Reset the CP 3600 when the power is on but with the motor off. OK.
Jun 07, 2009 | A.O. Smith SQ1102 Pool Pump Motor
Asko dryer
May have knocked a wire loose on motor switch, or motor run winding gone bad, only fix for that is replace motor.
Sep 26, 2017 | Dryers
Dryer On Switch
If you're really lucky it may be a broken or burnt off wire at the motor, but more likely you have a bad motor. When you push the start button you are energizing the start winding on the motor, but if there is no circuit through the run winding the motor will not continue to run when you release the button. Could be a bad run winding or the centrifugal switch is not resetting when the motor stops. Either way you are most likely looking at a new motor (expensive and usually a pain to install) or replacing the dryer. Sorry for the bad news. (remember good advice = fixya rating)
Sep 03, 2008 | Dryers
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
321 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
