Question about Kitchen Appliances - Others
Material of Sanyo titanium bowl in rice cooker
My wife is concerned with aluminum in cookware. Sanyo has rice cookers with a 5mm thick bowl with a titanium coating. What are these bowls are made of?
Thanks,
Richard Lee
richard@chi.us
    President:
  • 2,712 Answers
They are generally made of aluminum to reduce wieght. But sometimes they can be made of stainless steel as well.
One way to determine this is to open the inner pot and see the outside. If it is shiny (like chrome-look), then it is most likely made of steel. If it has a dull finish, or has the titanium coating on the outside as well, then it is most likely aluminum. However, the best way to determine is to directly contact Sanyo Customer Support.
Hope that helps!
Oh yes, and please rate this as fixya if you found my information useful, so we can close the problem ticket.
Thanks in advance,
IrishDruid
Posted on Apr 29, 2008
  • Swilin Sampson
    Swilin Sampson Apr 29, 2008
    Thank you for the rating. BTW, your wife needn't worry even if the cooker has an aluminum pot, as it is titanium coated. The food will never get in contact with any aluminum.
No matter what pot we use, it wont work
Most cookware found found in home today is aluminum or cast aluminum. These do not work on induction cook tops. Even older stainless steel Farberware doesn't work because it is not magnetic. Look for an induction compatible label or stamp on the cookware to be sure.
Induction cookware must be made of a magnetic-based material, such as cast iron or magnetic stainless steel. Fully clad cookware brands, such as All-Clad Stainless, Le Creuset Stainless Steel and Mauviel M'cooks stainless work on induction cooktops because they're magnetic.
Mar 15, 2015 | Eurodib Induction Cooker
If induction cooker does not heat the pot
Induction-compatible cookware contains contains iron or has a layer with magnetic properties. Cast iron, enamel cast iron and most types of stainless steel cookware are all induction compatible (But not all types; for instance, All-Clad's MC2 line, which is made of aluminum and stainless steel, is not induction compatible)
Nov 25, 2014 | Winco Professional Induction Cooker -...
Pressure cooker is not heated on induction cooker
Likely the pressure cooker base is not induction-compatible. This is the case with all aluminum pressure cookers and some older stainless steel models. Your cookware store will have a small metal plate that you can put on your induction burner to heat non-induction compatible cookware.
Nov 10, 2013 | Home
I need to download the instruction manual
Here is a tip that will help you figure out about using a rice cooker...
How much Rice and Water go in the Cooker
heatman101
Jan 16, 2011 | Sanyo ECJ-AC4E 4-Cup Rice Cooker
Where do I find sanyo rice cooker ec-503 power cord
You have a bad connection because the wiring has been bent around too much and has failed...this will not be repairable and you need to replace the cooker...
Here is a tip that I wrote about rice cookers and the amount of rice and water needed...
http://www.fixya.com/support/r5396567-much_rice_water_go_in_cooker
heatman101
Jun 26, 2010 | Sanyo EC-503 3-Cup Rice Cooker
Washing aluminum insert - turning water black
I have the same problem with aluminum insert and mine made in China. I am really uncomfortable with it. Anybody knows what to do?
Sep 27, 2009 | Hitachi RD5086P 8.3-Cup Rice Cooker
Instructions for sanyo rice cooker+basic gear name on cooker it's Contemporary Basic Gear by SANYO
heatman101
Mar 21, 2009 | Sanyo HPS-MC3 Rice Cooker
Rice cooker keep feature turns rice crispy
This sounds like the thermostat inside the unit has went out and is overheating whitch in turn is cooking your rice too fast and too hot! if the thermostat is replaced it will cook the rice even again!
Please rate my response to your question
Thank You!
Jan 07, 2009 | Sanyo ECJ-PX50S 5-Cup Rice Cooker
I need a replacement pot for the Sanyo rice cooker ECJ-AC4E. If the pot is in excellent condition, do you want to sell it?
Jun 13, 2007 | Sanyo ECJ-AC4E 4-Cup Rice Cooker
Kitchen Appliances - Others Logo
1,018 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
