Question about Dryers
Dry run is running but no heat maybe heater is gone maybe fuse
  • Dryers Master
  • 43,501 Answers
Hi, If you have a gas dryerdry run is running but no heat - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas dry run is running but no heat - 2_bing.gifsrc="http://i.fixya.net/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip thatdry run is running but no heat - 2_bing.gifbout this problem...
Dryerdry Troubleshooting2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Jun 05, 2010
My LG Model DLEX3360 dryer will turn on, run about 20 seconds and stop running -- but displays still says it is drying.
Dryer Thermal Fuse Replacement - LG Electric ... - YouTube
? 5:29
https://www.youtube.com/watch?v=b74Mt5sSgRI
Dec 21, 2012 - Uploaded by RepairClinic.com
Dryer Thermal Fuse Replacement - LG Electric Dryer Repair (Part ... The most common reasons for replacing the thermal fuse are when the dryer won't start or ... I have an LG GAS DRYER model # DLGX8001V and it will not ... My front load dryer won'tturn on. .... My LG dryer recently stopped working.Missing: seconds
LG Electric Dryers, no heat? Try this first... - Home Forums
ths.gardenweb.com > Home Forums > Laundry Room
Apr 1, 2006 - I own an LG Electric Dryer model DLE0332W. ... Serviceman: The part you need is a heat regulator and its going to run you about $20 and the labor ... Look into the hole to the left and you will see the Heater Unit right within reach. .... Came back a second time because it still wouldn't dry my clothes (maybe ..
Nov 24, 2015 | LG Dryers
My hot tub will not heat up and the one pump is running. I can not turn the lights on or adjust the controls
check the fuses if no heat sounds like the pump that isnt running is the recirculation pump (which heater is connected to) if fuses keep blowing try disconnecting the heater element maybe shorted
Mar 04, 2015 | Jacuzzi Pool & Spa
Maytag Neptune Model #MDE5500ATW How to tell if the thermal fuse is blown
If this THERMAL fuse is blown it would not operate at all. If it runs but don't heat it probably is a limit or the heater. If you see a lot of junk in the vent pipe AND it still runs then the heater limits are gone. If the vent it clear but filter housing or blower has an issue then it won't run and the thermal fuse is gone bye bye.
SERVICE MANUAL for slopefaced dryer
Sep 03, 2012 | Dryers
Dryer runs but does not dry clothes
Dryers run on two circuits. One runs the motor and the other runs the heat. Check to make sure the fuse isn't blown or the breaker isn't tripped. Usually there is a fuse box behind the dryer with two fuses. One is for motor, one is for heater.
Jul 24, 2011 | Dryers
Kenmore cloths dryer no heat --- drum and air but no heat ---think it is therma fuse clean vents
Well it runs so that is not the thermal fuse. I would check the limits on the heater or maybe the heater itselfthemobilian_2271.jpgthemobilian_2272.jpgthemobilian_2273.jpgthemobilian_2274.jpg
If these components check ok and yall still have no heat then the timer may be bad.
or the dedicated house dryer circuit breaker is gone on the heat load side.
The motor works on 120 volts or L-1 and neutral. The 5000 watt 240 heating element needs both sides of the breaker to operate correctly. Heat can be iffy or none at all if this is the case.
I have service manual and more HERE
May 02, 2011 | Kenmore Dryers
My Kenmore 66512690 dryer will not heat up or dry cloths. The drom rotates and the motor seems fine.
check your fuses in your panel. If one is gone the dryer won,t run if the other is gone it just won't heat
Oct 27, 2010 | Dryers
My dryer runs and turns but doesnt heat up or dry clothes
It sounds like you may need a GE element part number WE11M23. this is a common problem and can be replaced by taking out the drum and exposing the large circular heating element. the thermostats on the heater housing can usually be re-used. secondly check you house fuses as this can save you alot of grief. it is possible that simply a wire has been burned or your cycling thermostat is gone. I would need a model number in order to give you a part number for this. hope this helps.
Thanks
Oct 12, 2009 | GE Dryers
Dryer doesn't heat up
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 09, 2009 | Bosch Nexxt WTMC3321US Electric Dryer
Blower moter runs on heater constantly
Blower motor should not be keeping your heater from heating up. Something must be going on with your flame. Have you cleaned the heater recently? Is the igniter working? Is your burner ring in good condition? Maybe a sensor has gone bad? Trouble shooting at the rural energy website might be helpful.
Nov 18, 2008 | Rinnai Toyostove Direct Vent Heater:...
Dryer runs but will not dry
It may be a thermostat that has gone, thus preventing the heater from going on. Check your power source as well, maybe you have lost a line.
SGt 48
Jun 17, 2008 | GE DCVH515EFWW Electric Dryer
Dryers Logo
48 people viewed this question
Top Dryers Experts
