Question about Garden
Husky pressure washer model GCV 160 with honda motor will not start. Starts when starter fluid is sprayed into carb, but then dies immediately. Fuel is getting into bowl under carb.
I have the same problem lol
Posted on Apr 02, 2011
Engine rpm serges sometimes and powernosle pressure drop some times
Gas engine surging and losing power sounds like dirty carb to me.
Pressure washers are often used and then sit for months before being used again. This often creates blockage in carb passages. If you have or install a fuel cutoff valve you can reduce this problem. When you are done pressure washing, turn off the fuel valve and continue spraying water until the carb empties ( the engine will sputter and go out) Next time you want to wash turn on the valve and you should be good to go.
Mar 09, 2014 | Annovi Reverberi Sjv3g27d Pressure Washer...
Oil runs out under flywheel when motor starts honda GCV 160
Your top seal on the mower motor is faulty...replace with new seal...
Mar 25, 2013 | Homelite For Husky - Pressure Washer Pump...
I cannot get my honda 2500psi pressure washer to start at all i have changed spark plug and do have spark it has good gas in it and plenty of oil but will not start?
Three things needed for engine to run. Fresh fuel, good spark and good compression. I am assuming that water supply is disconnected for now and that you feel good resistance when you pull the rope indicating that there is compession. For now remove/unplug the low oil alert wire (if your model has one). Use carburator cleaner as fuel for now by spraying fuel directly into carb with air filter removed and choke off (do not flood just spray a little then little more if needed, the engine will only begin to run then stop unless you contine to spray fuel). If the engine does not respond most likely timing belt or plastic cam is cause. GCV series honda engines use timing belt with plastic cam gear. Gx series use metal gear. If the engine responds clean carb. Good luck
Jul 08, 2011 | Honda Garden
I have a Honda GCV 160 pressure washer from TROY-BILT and when I start the washer the motor starts but when I use the Spray Gun the motor stops and the pressure washer is jam. I think it is the motor and...
Mine is doing the same damn thing! Trying to figure out how to take off the high-pressure hose connector because I need to inspect it for clogs.
Jan 06, 2011 | Garden
My Husky pressure washer 2600 psi powered by a gcv 160 Honda. Engine starts no pressure other then from water source and soap is not being dispensed
It sounds like the (RMW 2.2 G24) pump has gone out. Mine had this problem after about 6 hours of use. I was able to order a new pump for around $160.00, and then installed it myself. Go figure it was just out of warranty. I think my next pressure washer will be one with a professional pump as I was told the one on my husky is only rated for about 40 hours of use.
Jul 10, 2010 | Garden
I have a Husky 2600 PSI power washer with the Honda GCV160 engine that I can't get to start. It was okay when I purchased it from Home Depot last spring but now I've tried putting new gas in it, spraying...
You can eliminate the motor by unbolting the pump from it and then if it will start the problem is with the pump or the unloading valve.If it does not start with the pump removed then you check for spark and get the carb cleaned or have a kit put in it.If it does start then check to see if the pump turns freely,if so disassemble the unloader valve and clean and lube it so that the pump and motor can relieve the pressure it needs to when the trigger is not engaged,if the pump can't be easily turned by hand then then pump needs to come apart,dealership should do this.
Apr 13, 2010 | Karcher 2500 PSI Pressure Washer
My almost new Honda GCV 160 engine will not start.
Hi , I think you need someone to remind you these engins are not made by god and they work by obeying three simple rules ,
1.Spark , Can you see a very good blue spark
2.compression,,can you feel strong compression ,
3.fuel , is the right amount of fuel getting in , is the air mixture good ,
Now try these things
Find the manual and PROPPER set the gap in the spark plug ,
clean and check the air filter ,
remove all fuel and replace with brand new,
check the fuel filter,even in the tank tap?
undo the screw at the carb bowl , can you see petrol leaking ,
If everything checks out then try this to get it started,,
spray "easystart" in the carb , bypassing the air filter ,
if it wants to start but cant for long then its a carb problem
check float hight , float needle,jets and pins ,too much air getting in
find someone thats good on motorbikes , They like me know all the tricks to get things to start ,
Aug 16, 2009 | Karcher 2500 PSI Pressure Washer
Fuel mix for a excell VR2522
should be a honda gcv 160 5,5 horsepower engine.
do a search for honda engine carburretor adjustment, plenty of pages on the internet detailing how to adjust carbs, mixture etc.
Excell Pressure Washer Model VR2522 Replacement Parts repair kits ...
lok at this site , parts breakdown of engine etc
Jul 18, 2009 | Karcher 2500 PSI Pressure Washer
It won't stay running
You need to either clean the carb really good (take it apart) or rebuild it or both. Sounds like your needle is gummed up and not letting fuel through.
May 29, 2009 | Honda Pressure Washer PSI 3000
Garden Logo
929 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
