Question about Samsung CLX-3175FN Printer
How do I change the photo interrupter in my printer
HP fax model C3530a says out of paper when paper is in it. The flag that feels the paper is working. I have the board out and see a photo interrupter to sense paper, could it be not working?
Past experience tells me that getting the part from HP will not be likely, more often, an entire board may be offered.
This type of photo detector may well be available (and replaceable) as a single part if you can find the part number.
Although physical characteristics (size, spacing of the light source and detector, pin spacing, etc.) may differ, the electrical specs can be very much the same.
A reliable and inexpensive (no minimum) source is Mouser Electronics:
http://www.mouser.com/
Sep 19, 2014 | Office Equipment & Supplies
I need to reset copy counter after changing Drum unit on Sharp AR 161 photo copier
Perform the following procedure to enter the simulation mode."#" key Interrupt key "C" key Interrupt key, then, then enter 24 start 7 start, then you can clear the drum count.Press 42, start, 01, start for clearing developer counter, and after clearing all this you have to press 'ca' to exit this mode, rate this and vote for this.
May 17, 2011 | Sharp AR-160 Copier
Hi...I have a problem with my HP Photosmart C7280...can you help ? the error message "Photo tray problem" keeps coming up, telling me to "lift the output tray, push the photo tray all the...
Photo tray problem
' Lift the output tray up and verify that the photo tray
' is pushed in until it stops, then lower output all the
' way down. Press OK button on the printer to
'continue printing
HP Photosmart C7280 All-in-One Printer
1. Turn off printer.
2. Pull out paper tray and photo tray
3. Remove output duplexer (on back of printer)
4. Open input sheet feeder (on top of printer)
5. Open cartridge access door. (Basically lift up control panel and scanner section of the printer)
6. Turn on printer (Power button on now raised control panel)
7. Printer may display message "Performing printer alignment - Do not interrupt"
8. Wait for a few minutes until printer stops making all setup noises.
9. Close cartridge access door, close input sheet feeder, replace output duplexer, insert paper trays
10. Do a test print. All should be fine.
Mar 11, 2011 | Office Equipment & Supplies
My printer changes color 1/2 way through printer a 8 x 10 photo
This is often indicating low ink in one or more ink tanks.
Check and replace as needed.
Do not rule out head damage or some obstruction half way down the page.
Run it through the cleaning cycle and see if that helps.
If your printing over a network.
Try hooking up directly and see if the problem goes away.
If it works fine, It is spooling to the network then the printer is getting spurious data. Meaning it could print draft, bold almost anything including 1000 pages of 4 or 5 symbols.only. Data stream to the printer is being interrupted. Direct print ok the interruption is not taking place.
You could also try setting the printer to "Direct printing" and not spool.
Side affect is it will take longer to regain control of the pc.
Hope this helps!
Mar 28, 2010 | HP Office Equipment & Supplies
It is flashing H 4 over and over
H4 flashing mean problem on FUSER section.
Problem on three things
1 Heater lamp burned out.
2 Fuse out of order
3. Thermostate damage.
Problem solve: Reset this code
Press C-Photo-C-photo press 14 press Start key
Note: Its only A4 and legel size copier.
Other thinks # interrupt C interrupt.press 14 press Start key.
Jan 25, 2010 | Office Equipment & Supplies
My sharp AR-5316E Displays 4 H and nothing else, how do i solve it
You must reset this code.
#-interrupt-C-interrupt
or C-photo-C-photo, Press 14 press start key.machine is ready.
If heater lamp was burned out you replace it.May be it problem on over temperature.
Jan 21, 2010 | Sharp AR-5316 Advanced Digital Imager...
Canon Pixma MX700 fax and color problems
I think i just figured this out.
You need to find the Fax Menu -> Receiver Control Settings
Click the Fax button, then click menu and the left icon should be Receiver Control Settings.
Change to Tel Priority Mode.
Hope this helps
Jan 19, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Samsung CLX-3175FN Printer Logo
345 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
