Hi, If you have a gas dryer.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas not Working Gas
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryeMy Danby dryer has no heat after a bad electrical - 2_bing.gifbr />
If your dryer is electric..
There could be a number of different problems...
Check out this tip that I wrote aboutMy Danby dryer has no heat after a bad electrical - 2_bing.giflem...
Dryer Troubleshooting Electric Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
