Question about Canon LaserCLASS Fax 710 Printer
Canon's LASER CLASS 830i not sending consistently
Canon's LASER CLASS 830i not sending consisitenyly - some calls are local others are long distance
Error TX Report
TX Function was not completed
giving NG # 0018 busy/no signal errors
5 Suggested Answers
SOURCE: MP830 Canon Faxing problem
Display the fax menu and then select Print Report\List and print the Users Data List. Check the setting of the ECM TX setting. If this is ON turn it OFF. This is the Error Correction Mode setting, probability is the fax you are sending to is not ECM compatible. The MP830 is suppose to automatically send in standard mode if receiving machine is not ECM compatible however I am not sure how well this works. Turn the ECM setting off by displaying the Fax Menu and then select Maintenance\Settings, Device Settings, Fax Settings, TX settings, ECM TX.
Posted on Apr 25, 2008
SOURCE: faxing
That is the same problem that I have. I think the settings for the fax have to be reset. I am calling canon to get help.
Posted on Jul 05, 2008
SOURCE: Canon fax mp780 says 'ERROR
If you go into the fax tx settings and turn off ECM setting, the fax should send (at least it did for me when I had the same problem).
Posted on Dec 16, 2008
SOURCE: Canon MP530 - Fax - ERROR TX Report - NG
Hi flyme.. I have the same problem but on an MF5770 all in one MFP. If anyone can solve this then wow.. I've been trying to find a solution for over 18 months now...
Posted on Jul 30, 2009
How to program TX report on a canon laser class 830i
You can find instruction on how to configure Transmission Reports on page 364 of the use guide. (see below)
http://downloads.canon.com/cpr/pdf/Manuals/lc_800_series_basic_operation_guide.pdf
Hope that helps.
Dec 19, 2014 | Canon Office Equipment & Supplies
How do I print the configuration page from the canon Laser class 830i fax machine
I am using a mac, and not the same brand printer, but I go to my system preferences, pick my printer, go to the top and pick "Options and Supplies" a new screen should open. There should be a "test" icon, as well as options for allignment, cleaning heads,etc..
Nov 19, 2014 | Canon Office Equipment & Supplies
I am getting a feeder glass dirty message. I have cleaned glass and rollers. Do I need to reset
look the cartridge is there some defect.and then do the reset.Its not anything big failure just the printer sometimes mix the right info.
Jun 05, 2014 | Canon Laser Class 830i Plain Paper Fax
Our RX report for our Canon 830i fax machine lists a transaction failed (NG) with error code #0106
This error usually means you have a phone line problem.
You need to try to increase your transmission level, or check the line equalization. It could also be a problem with an echo on the phone line.
Dec 16, 2009 | Canon Laser Class 830i Plain Paper Fax
We know where to take it but how do we get warranty service on a laser class 810?
You will have to call an AUTHORIZED CANON DEALER to obtain warranty service, or ask Canon if you can send it to them.
Oct 29, 2009 | Canon Office Equipment & Supplies
Photo copys are intermittently coming out black without copier settings being changed
you need to watch the exposure lamp under the glass . see if it goes out during a copy run. if so you may have a bad lamp, wires, invertor or pcb. if it does not go out you may need a drum, chagre replacemnet or developer. you may need a tech to look at it.
Oct 27, 2009 | Canon Laser Class 830i Plain Paper Fax
When I try to fax there is a beeping sound. the report says the line is busy/noresponse
i would first reset up the machine in send and receive mode, is there dial tone. let me know what happens
Dec 15, 2008 | Brother IntelliFAX 2800 Laser Fax
Faxing Long Distance
To my knowledge, if the unit can send a fax message to another fax machine then it is safe to assume that there is nothing wrong with the fax.
Perhaps your problem may be more related to the type of phone subscription that you may have. Some phone providers have subscription for local calls only and restricted long distance. Alternately, there are some phones that would need a series of numbers to be pre-dialed before long distance access is granted.
Pls check with your local phone company. Additionally, you can try by calling long distance using your regular phone and see if it works. If it does, then long distance restrictions has been imposed/enabled in your Canon 3300. The procedures are better explained in the users manual. A copy of the user's manual for Mac users is here, all other downloads including those for Windows, is here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 18, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Canon LaserCLASS Fax 710 Printer Logo
222 people viewed this question
old marine
old marine
