Question about Hayward Pool Products Hayward Power Flo LX Above Ground Pumps
System runs fine until trying to vacuum
System runs fine through normal usage backwash filter etc. But when I push water through vacuum hose and try to vacuum the suction goes away and we have to reprime the pump because no suction. I've checked all the hoses and connections and everything is in working order. In fact it worked the day before and the next nothing. The pump is around 5years old and has never given us any problems until now.
  • 1,305 Answers
Pull the strainer basket out of the pump and reach into the intake of the pump at the bottom of the basin. If any debris gets into this area, the pump will not have great suction. The baskets and pipes etc will appear in good condition, but if the intake is plugged up, this could be your problem.
Posted on Jun 05, 2010
How to use back wash
backwash is easy. dont let it scare you.
here are the steps:
-turn off pump
-roll out backwash hose
-push down on handle and rotate to backwash
-turn pump back on
-depending on type of filter, run for minimum 2 minutes (watch discharge water. run until it is clear) if there is a glass vial, you can watch that until water is clear.
-turn off pump
-push down on handle and rotate to rinse
-turn on pump and run for 30 seconds (water will leave discharge hose)
-turn off pump
-push down handle and rotate to filter
-you can run pump immediately
May 20, 2014 | Hayward SAND FILTER, PRO SERIES
Tip
Backwashing A Sand Filter with A Push/Pull Slide Valve or Multiport Valve
Lots of people are first time pool owners and pool professionals forget to teach these "newbies" about the simplest aspects of pool ownership.
One of the biggest questions we receive from new homeowners is "How do I go about backwashing my sand filter exactly?"
It doesn't matter if you have a Hayward, Pentair, Jandy, Sta-Rite or any other number of Sand Filters on the market they all utilize the same basic valves for backwashing; a push/pull slide valve or a multiport valve.
To backwash with a multiport valve:
1) Shut off pump motor.
2) Press down on valve handle, rotate valve from FILTER to BACKWASH position.
3) Roll out any backwash hose or open any waste line valves.
4) Open air bleeder assembly on filter, and turn pump on.
5) Watch pressure gauge for backpressure and hose for kinks. Be prepared to shut off pump quickly.
6) After hose fills with water, run for 3 - 5 minutes or until water runs clear.
7) Shut off pump motor and move multiport valve handle to RINSE position. Run on rinse for 15 - 25 seconds.
8) Shut off pump motor and move multiport valve handle to FILTER position.
9) Turn pump back on and note lower pressure.
10) Roll up backwash hose so the dogs use it as a chew toy.
To Backwash a sand filter with a slide valve:
1) Shut off pump motor, roll out backwash hose.
2) Twist to unlock plunger T-handle, push or pull(depending on manufaturer) the plunger 2" - 3".
3) Open air bleeder assembly on filter, and turn pump on.
4) Watch pressure gauge for backpressure and hose for kinks. Be prepared to shut off pump quickly.
5) After hose fills with water, run for 3 - 5 minutes or until water runs clear.
6) Shut off pump motor and push T-handle back down into locked position.
7) Turn pump back on and note lower pressure.
8) Roll up backwash hose.
Now you are a backwash Guru!
More tips and tricks are available form The Ugly Pool Guy, www.WeFixUglyPools.com
on Dec 14, 2010 | Pool & Spa
Pump is blowing cloudy water back into pool
Cloudy water is the bane of sand filters!. I suggest letting filter run day and night. Do not backwash until the pressure rises 8 - 10 pounds above clean starting pressure. Do not try to vacuum or stir up the sediment. when water clears, vacuum to waste. Keep the hose running while vacuuming. A dirty filter is a better filter (up to a point). At a higher pressure the filter will trap more of the fine particles that are clouding your water.
May 28, 2013 | Pentair Meteor Above-ground 22" Sand...
No dirt comes out when I do a backwash only clear water. Filters are dirty but backwash not pushing dirt out. Water was full of algae so I am trying to get this cleaned up, so every time filters get full I...
use TSP to rinse first tri sodium phosphate get at hardware store its a degreaser then clean with 4 parts water 1 part muriatic acid then try again try vacuuming algae to waste so you don't clog filters
Apr 15, 2013 | Hayward Pool & Spa
I need to know what all the settings are like bacwash filter on the valve system
FILTER is the valve position when the system is in the normal filtering mode.
When you backwash the filter you first need to turn off the pump, place in BACKWASH position, and run the motor for 45 seconds (or until the backwash water is clear). Turn off pump and run in the FILTER position for 15 seconds. Repeat twice more.
The RINSE position is to clear any dirt in initial start-up cleaning, plus resetting filter bed after backwashing.
The WASTE
position is for vacuuming directly to waste, lowering pool level, or draining the pool.
The CLOSED position is for shutting off all flow through the valve.
The RECIRCULATE position allows water to flow from the pump through the valve and directly to the pool.
You will probably only to use the FILTER, BACKWASH and maybe the RINSE valve position. The RINSE position is not as important as indicated by the fact that many backwash valves don't have a RINSE position.
I hope this helps.
Sep 05, 2011 | Hayward SAND FILTER, PRO SERIES
After I vacuum the pool, backwash it and then turn the filter system back on it blows in a lot of green water back into the pool. What should I do?
1st Green water is algee. Kill the algee in the pool. 2nd when you're finished backwashing the filter. Stop pump and move valve handle to rinse position. Then restart pump. Run in rinse mode until glass is clear. Then stop pump again, and move lever to filter position. When you're backwashing, you're reversing the flow of the water through the filter. When you switch directly back to filter, anything left loose in the filter flows back to the pool. When you select rinse, it reverses the flow back to normal, but keeps the water going to the waste outlet until clear, that way that green puff of water will go out the drain. You can get complete manuals from www.haywardnet.com
Jul 20, 2010 | Hayward SAND FILTER, PRO SERIES
My pool is a 24x52 intex and the pump wont work
Try backwashing the filter until the pressure is between 10 and 20 psi. (backwash for a couple min then run it on filter for a min and so on until the filter pressure is normal). If this doesn't work, the hose may be cracked/punctured, if so you will need a new hose.
Jul 16, 2010 | Aqua Vac Tiger Shark
No water coming out when I backwash. I cleaned
water level must be about the discharge (eyeball) in the pool to back wash. Check the hose connections to make sure that hoses off the the filer head are going to the right place Look for the words "Pump" , "pool" and "waste" molded into the valve. I've seen it a number of times where "Pump" and "pool" were connected the wrong way.
Jul 04, 2009 | Hayward SAND FILTER, PRO SERIES
Out of the ground pool-hayward sand filter
This one is easy...
You simply fill your pool to the normal level which is at the top of the skimmer.
Now apply the "Shock" treatment to begin clearing the water.
With the pool full, attach the hose for back flushing to the filter 'Outlet" or discharge side and then move the selector handle to the "backwash" position and turn the pump on. It will begin discharging water out of the hose. Run it this way until it begins sucking air.
You have now "backwashed" your filter.
Fill the pool back to the normal level and finish treating water to get the Ph and Chlorine right.
Enjoy swimming.
Jun 01, 2008 | Dehumidifiers
How to connect the vacuum system in the swwiming pool
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=564116
Generic problem for all Vacuums
Posted by herpor on May 02, 2008
How to connect the vacuum system in the swimming pool
This is not a problem that I can help you with, you need to contact someone in your area that deals with swimming pools and they have vacuums that are specially designed to do the swimming pools and they can better direct you in what to do.
Don – The Vac Man
Go Ahead. Use Us.
May 02, 2008 | Vacuums
Hayward Pool Products Hayward Power Flo LX Above Ground Pumps Logo
172 people viewed this question
Top Hayward Pool Products Pool & Spa Experts
Jay Finke
Jay Finke
ray gallant
Tom Chichester
Are you a Hayward Pool Products Pool and Spa Expert? Answer questions, earn points and help others
