Question about Western Digital My Book Essential 320GB External USB 2.0 - WDH1U3200N Hard Drive
My wd external hardrive is not recognized anymore on my pc. I have tried on other pcs and tried different usb cables and nothing. I do not want to reformat the drive because I have important information stored in it.The ex. hardrive itself makes unusual noises not heard before.
    Sergeant:
  • 356 Answers
Hi. If you here some clicking noise then your external hard drive might be busted already.
Try to contact a local tech and see if he can still pull out your data from there.
Hope you'll be able to extract your files back.
Have a great weekend!!!
^_^
Posted on Jun 04, 2010
Testimonial: "Thanks dan hopefully I can take this to a comp tech who can extract my files. Too bad i didnt save the docs online :("
Computer won't recognize external usb hard drive
try it on another computer if that dosent work you should
reformat your computer but first backup all your data by putting your another internal hardrive on your computer and move all your files you need to the empty hardrive and after that take the hardrive with all your stuff in it off the computer and then reformat the hardrive which the external hardrive does not work on and install a new operating system then put the other hardrive with all your stuff back on your computer and transfer your stuff into the hardrive with a operating system then try the external hardrive
OR
you can burn all your stuff into a CD or a DVD
OR
you can put all your stuff into FlashDrives and then after you reformat the hardrive with an operating system put your stuff back into the computer and after that the external hardrive should work
Dec 27, 2012 | Toshiba HDWC130XK3J1 Hard Drive - Canvio 3...
Hi. My computer says I ejected my WD My Passport external drive but it was not properly ejected. How can I fix this. I need all my thesis files but computer can read the external drive! Help please!
Try to test your WD Ext HDD to a different computer and check if you will get the same problem.
If the same problem persist try to use a different cable for your WD Ext HDD.
If still fails kindly ask the store where you bought the WD Ext HDD on how to retrieve your files and have WD EXT HDD replaced?
If your WD Ext HDD works to a different computer then update the BIOS and Chipset of the computer where your WD Ext HDD connected previously.
Hope this helps.
May 29, 2011 | Computers & Internet
My computer can no longer recognize my WDBAAU0015HBK, western digital portable hardrive. I have tried everything swapping computers, USB cable, etc. All I want now is to return this hardrive (RMA) to WD...
DID YOU TRY GOING TO ADMINISTRATIVE TOOLS, COMPUTER MANAGEMENT, UNDER STORAGE CLICK DISK MANAGEMENT, ENLARGE THE PAGE , LOOK FOR YOUR DRIVE, RIGHT CLICK YOUR DRIVE AND MARK PARTITION AS ACTIVE. ....HOPE THIS HELPS.......JEFFXC
Feb 08, 2011 | Western Digital WD Elements Desktop...
Wont recognize usb anymore
if the external hard disk drive powers on, perhaps replacing the USB cable could help ?
i had WD extrenal, and it crapped out on me -- i had so much vital information that i lost . i finally discovered that the power modeul inside the housing that encases the drive was bad.. i coul not get the PC board replaced.
i hope you can resolve this with new USB cable.
have you tried another computer -- see if that PC recognises the WD external drive
let me know how it works out for you
Nov 03, 2010 | Western Digital WD Passport 250GB Portable...
We bought some time ago an WD External Harddisk and now the Adapter doesn`t work anymore! What can I do?
Try connecting it to a different computer.
Any external storage device has three major parts:
* USB cable
* disk-drive
* USB-to-disk-drive adapter
Try a different USB cable.
Disconnect the disk-drive from that adapter, and connect the disk-drive as a "slave" disk-drive in a desktop computer, and see if you can read the files, which implies that the adapter is the part that has failed.
If you cannot read from the disk-drive, check its WARRANTY status. W.D. will replace it, if the warranty is still valid.
Otherwise, W.D. has a "Customer Loyalty" program: find the serial-number of your unit, access their web-site, and purchase another W.D. external storage unit, at a significant discount, by citing the serial-number.
Or, if the adapter is OK, then replace the disk-drive by a new one, and close-up the casing, to create a "revived" external storage device for your use.
Oct 23, 2010 | Western Digital Elements powered by WD 320...
EXTERNAL HARDRIVE NOT RECOGNIZED IN WINDOWS XP
Uninstall the driver and then reinstall. make sure the drive is not connected until the driver is installed.
May 30, 2010 | Western Digital Elements powered by WD 320...
I have a WD portable 320G removable hardrive I can't get my computer to reconize it's plugged in. I tried changing the cords. No luck. Keeps trying to install then comes back unable do to either being...
Connect the external disk-drive to another computer.
If it still is not recognized, then you have a problem:
* the USB-to-disk-drive interface inside the case is faulty,
* the disk-drive inside the case is faulty.
If the former, disassemble the casing, and extract the disk-drive,
and temporarily connect it as an "internal" and "slave" disk-drive to your desktop, and see if you can read the files.
Dec 01, 2009 | Western Digital Computers & Internet
My computer doesn't recognize my wd hardrive when i plug it in
its problum with the cable or with your Operating System your are using,,, try on different USB Ports the pc have...
good luck
shafky
Jun 26, 2009 | Western Digital WD Passport 250GB Portable...
My computer recognizes the WD but i cant view my files
Sounds like to me you already did the troubleshooting. If you cannot get the drive to function properly on another computer and it has the same symptoms, then logic would say that it is your drive. Note to also use a different cable to make sure it isn't the cable. I would try it on at least two more computers to make sure, hopefully with at least XP and Vista.
Jun 25, 2009 | Western Digital 250GB MyBook External USB...
Windows XP will not recognize my WD 250GB Harddrive
Just plug your USB HDD directly into your MBoard's USB port...
Feb 09, 2009 | Western Digital 250GB MyBook External USB...
Western Digital My Book Essential 320GB External USB 2.0 - WDH1U3200N Hard Drive Logo
571 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
