Vizio tv model gv42l-fhdtv10. tv has audio,no on screen display screen is lit however,at turn on you get 3 or4 vertical bars made up of pencil thin vertical lines.as set warms up you get more bars and more lines
  • 6,993 Answers
the problem is from the VGA of your TV. Also, is your TV connected to a cable receiver?
Please let me know so that I can figure out what's causing the problem.
I look forward to your reply.
Bye for now.
Posted on Jun 12, 2010
I need recommendations to troubleshoot LED screen failure for my Vizio M55-D0 (2016).
you know this is a TV that needs to be diagnosed and you need some skills to do this.
I dont think its leds but I do think it is most likely T-con and or the main board you also could have some bad ribbons which go in and out of the main and t-con between each other and the screen
unplug and remove and reconnect the thin ribbons sometimes using a pencil eraser to rub and clean the little gold bars on those ribbons if that does not work work start with t-con or both main and t-con
Mar 05, 2018 | Vizio Televison & Video
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
My Vizio GV42L is fading to a dull whitish color after 2-3 minutes. I can still see the TV program I am on but the screen just goes to a dull whitish color. No boxes or anything popping up. Basical
Either its back light inverter board, or, the LVDS cable has the fault. First try by re-seat the LVDS cable, and check. Thus you can make sure about the fault. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic /Timeslide, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
Nov 06, 2013 | Vizio GV42L 42 in. LCD Television
Vizio GV42L
Call vizio asap they will have a tech come and fix it free.. after the manufacture warrenty runs out they want to charge you 6--$ to fix it here is the number! 877 698 4946
May 02, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
GV42L
I had this same problem. Vizio sent someone out to replace the motherboard. It didn't fix the problem. Since it was under warranty, they replaced it with a newer model VU42L. Doesn't have this problem, but it has others.
May 02, 2008 | Vizio GV42L 42 in. LCD Television
Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
Oct 15, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Sputtering,muted,crackly audio
do you have direct TV....... Direct Tv does that!!!! not the TV
Aug 12, 2007 | Vizio GV42L 42 in. LCD Television
Televison & Video Logo
110 people viewed this question
Top Televison & Video Experts
