Question about HP OfficeJet J4580 All-In-One Laser Printer
How do I change the setting to legal size copies
  • 241 Answers
To change the paper size in your software to print legal size please follow the link for step by step guide lines on how to do this. You can apply this solution to almost all software you may be printing from.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01518768&tmp_task=useCategory&lc=en&dlc=en&cc=ca&lang=en&product=3645100
Posted on Jun 04, 2010
How to copy legal to letter on copystar CS 4005i
Make sure your default settings are for AUTO paper selection and 100% magnification to start. That is the most common default settings. Then, under "Zoom" change to AUTO magnification and under PAPER SELECTION specify Letter (either landscape or portrait). Now when you copy a legal original (8.5" x 14") it will be reduced at 78% to fit it on an 11" sheet. An alternative is to use "X-Y" zoom. Now you can stipulate 78% for the "X" dimension and leave the "Y" dimension at 100%. You will want letter size paper to be feeding lengthwise (portrait). Now you can copy legals and the image is reduced top-to-bottom only, leaving it much more readable.
Mar 16, 2015 | Copystar Office Equipment & Supplies
Copying legal size on a Brother MFC 7420
This is for a temporary, as needed solution: Press "Menu/Set" button. Select "General Setup". Scroll down and select "Paper Size", find and select "Legal" size. Press Menu/Set button again. Press "Stop/Exit" button.
Insert legal size paper to be copied on the feeder tray and put a legal size paper in the Manual slot. Hit "Print"
You need to do these same steps again to return the settings to Letter size again.
May 09, 2012 | Brother MFC 7420 All-In-One Laser Printer
How do I print a legal size docunent on a HP J3680 without downsizing the copy. While searching the different options in the window of the product I do not I do not find the option for a legal size...
Hello there,
I have the same printer and here is what you can do.
Follow these steps to change the print settings on your computer to print on legal size paper.
  1. Press the Cancel button on the product to stop the current print job, if necessary.
  2. In the software program that you are using to print, click File , and then click Print .
  3. Make sure that the appropriate product is selected.
  4. Depending on the program, click Properties , Options , Printer Setup , or Printer . The Print Properties dialog box opens.
  5. Click the Features or Print/Quality tab.
  6. In the Paper Type or Type Is drop-down list, click the appropriate paper type.
  7. In the Size or Size Is drop-down list, click A5 or Legal .
  8. Click OK to save the settings.
  9. In the Print dialog box, click Print or OK to start printing.
Please do not forget to click the feedback and leave a testimony. If there are additinal questions, i'd be more than happy to help.
Mar 09, 2011 | HP J3680 Officejet All In One Printer
How should i do photo copy of legal size
oh legal size you mean 8 1/2 x 14 in?
if that's what you mean, first we have to identify if your machine is set US standard. there you will be able to copy legal size. Otherwise if JP/EU standard, you can only copy 8 1/2 x 13 as the nearest size.
please check it first
if the sizes on the scree you see are A4, A5, A3, FLS, then your machine is set to JP/ EU standard. If you see LTR, INV, LGL, LDR, then your machine is set to US standard, and just select LGL for you to copy legal size.
that's it
May 20, 2010 | Panasonic DP-8016P Copier
Legal size copies
Your printer doesn't support Legal size to Scan and Copy, you can scan/copy it by reducing the size of the paper from the menu. 10% will fit since the actual paper size supported by your printer is 8.5X11.7inch while the legal size is 8.5X14inch. Good luck. For more info check out here : http://h10010.www1.hp.com/wwpc/us/en/sm/WF06b/18972-18972-238444-12019-3328086-2511708-3643610-3643611.html
May 15, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Coping Copies of Legal Size
For either a Printer or Copier, the 1st thing is you have to use full-size LEGAL paper. If your copier won't accept this, then you cannot do it. It has to fit in the paper tray.
Second, use the setup menu of your copier and set paper to 8.5 by 14 or LEGAL size, for a Printer
goto Start, Settings, Printers and Networks and find your printer/copier, Right click it, select Properties, select General or Paper tab and look for Advanced Settings. There you will find Paper Size pull down. Change it to Legal, Click Apply, Click Close
Done!
Mar 26, 2009 | Office Equipment & Supplies
CANON IR2000 CANT PRINT MORE THAN 1 COPY
You just stated the problem yourself!!!!!!!!!!!!!!!!!!!!!
Are you using Letter or Legal?? then the tray need to be set to that particular size.
If using Legal set to Legal, otherwise the machine will automatically know you are using the wrong size.
Aug 14, 2008 | Office Equipment & Supplies
How do i get my printer to print a legal size copy
In your printer settings as you hit print
select the printer setting prefferences
select paper size( change from letter to legal) and your problem is solved
When you copy through the software program from brother you can change this in there. Just redo the prefferences.
Apr 28, 2008 | Brother MFC 8500 All-In-One Laser Printer
HP OfficeJet J4580 All-In-One Laser Printer Logo
110 people viewed this question
Seeker5211
Seeker5211
