Question about Carrier 38CKC030 Air Conditioner
Turned unit on for first time, it will not kick on
Replaced both fuses
    Sergeant:
  • 338 Answers
Does the indoor fan blow? If it does you are getting the 24 volts from the thermostat to the ouside contactor need to check your contactor in the oustide unit this is what kicks on the compressor it take the 24 volts and goes to 230 volts to run the compressor and condensor fan. check your schematic for the placement of the contactor.
Posted on Jun 04, 2010
Armstrong Ultra SX 80 Central Unit won't kick off heat setting
From what you describe it sounds like it might be a relay problem.
It needs to be diagnosed properly first.
Apr 21, 2017 | Heating & Cooling
My XTR-690SE will no longer power on. I have replaced the fuse so that's not the issue and have also tried 4 different vehicles with no luck. Any suggestions or warranties for this product??
Press IN on the power/volume button. Its possible that the Vehicle battery saver feature kicked in and turned off the unit. THis status remains in the unit's memory so plugging/unplugging the power cord does not correct it. You need to press IN on the power/volume button to turn it on.
Aug 22, 2013 | Whistler Xtr-690se High Performance Radar...
The condenser unit will not kick on...it is a concord unit,10=12 years old,13 seer,3 ton. The air handler works fine. I thought it was the capacitor. The old one was bad,I verified that with multimeter....
It could be a low refrigerant cut-out (switch), grounded or shorted motor windings, open internal winding overload protector (check at the common winding), a broken conductor, or no power at condensing unit from blown fuses or open/tripped breaker.
Aug 22, 2013 | Intertherm Heating & Cooling
Fan dont work but when i turn on cooling system two fan work please give me lay out for cut-off and fuse
If you have two electric fans the fan on the passenger side of the vehicle is the radiator cooling fan, that fan should run when the motor gets to hot. The fan on the driver side is the ac condenser fan that fan runs only when the a/c is turned on. The only time that both fans run is if the a/c is on and the motor or coolant is above normal tempeture.
Aug 15, 2011 | 1995 Hyundai Sonata
2002 intrepid 2.7 Im getting no crank from the starter and I dont hear the fuel pump kicking on when the ignition key is turned on, I do get power to the radio and dash, Ive checked fuses and replaced...
Under the hood, there should be a fuse block. Remove the cover and there will be a 20amp(i think) fuse that protects the fuel pump and starter circuit. I've run into this problem many times and every time it ends up being the starter that blows the fuse.
Jun 19, 2011 | 2002 Dodge Intrepid
I have a saniplus toilet, the macerating unit runs about every 2 minutes for 1-2 seconds at a time. I'ver replaced the flapper and even turned off the water to the unit and stopped using it, but it keeps...
Water pressure makes the unit kick on and off. Water could be leaking from the toilet tank into the bowl and from bowl into the pump. Or the check valve inside the discharge elbow (on top of the lid) may not be sitting properly or is being obstructed causing waste water to leak inside the pump, creating enough water pressure to make the unit kick on and off by itself.
Sep 06, 2010 | Saniflo & Saniplus& Macerator Pump
Carrier A/C in RV won't run
check your breakers make sure when running unit this is the only thing on the breaker 15 to 20 amp be sure to keep a window cracked as well unit does freeze over so don't have all the way on cold
Jun 23, 2009 | Dometic Rooftop RV Air Conditioner
Unit does not work
all the mitsubishies had auto diagnosis,you must set up with the remote control to see the code and how many times blinking the button to the indoor unit.
Oct 09, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
When turned on, the unit sounds like it will start then turns off within a minute.
Presently according to my information there is no recalls for Fedders products at this time for this model type.
May 27, 2008 | Fedders A&B Chassis A1A07W2B Air...
Carrier 38CKC030 Air Conditioner Logo
136 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
