Question about Kyocera wild card Cellular Phone
By mistake I plugged in the headset in the AC socket. Now when i try to charge the battery with the AC charger, doesnt charge! is like the socket is damaged. What can i do?
  • 75 Answers
Ok lets replace that socket if dmaged otherwise replace the your handset battry.It will solve your problem
Posted on Jun 04, 2010
Doesnt work from time to time
yes you must use the right batteries, try resetting it.
Jan 21, 2015 | Trust Radio Communications
I have an Invacare Pronto M-91 Sure Step Electric Wheelchair that when plugged into wall socket is no longer charging chair batteries. The onboard Signet charger's led light isn't illuminating at all when...
The charger is defective. I would not try to charge it externally because if you charge it with a higher rate of current (amperage) than the original charger, it could explode or leak.
Jun 05, 2014 | Health & Beauty
Dell inspiron n15010
Before looking for a replacement charger, try this:
1. Remove charger from power socket
2. Remove battery
3. Hold the Power On button on the laptop about 10 seconds (while the battery is removed), and release
4. Plug in the charger to the laptop and power socket (without battery)
5. Try to turn on the laptop
Check also that all the cables from the charger are connected firmly.
If this doesn't work, you will need to replace the charger. Take the laptop with you, so you can try the new charger on the spot to be sure.
Jan 13, 2014 | Dell Computers & Internet
My laptop charge wont charge my laptop
is there charging indicator light on ....... check battery maybe its dry
May 30, 2011 | ASUS Eee PC 1000, 1000H, 1000HA, 1000HD,...
I have a car battery charger that plugs into a cigarette lighter. However, I lost the directins & don't know if the charger itself is charged. Also, How do I use the charger if the car battery is...
I am guessing that you mean you have one of the jumpstart devices that you plug into the lighter socket? If that is the case plug it into the lighter socket turn it on and try to start the vehicle. If that doesnt work or you think the unit itself is dead plug it into the lighter socket on a vehicle that has a fully charged battery to charge it. If you post the manufacturer, model and name of your charger we may be able to find a manual for it than i can answer your question better
Mar 20, 2011 | Toyota Camry Cars & Trucks
Does not charge when the charger is plugged. The Red light does not turn on.
Just wait for the battery to be completely drained-I did that to mine just now.after the battery is completely drained, I charged it, and it began functioning again.
Oct 05, 2010 | Nokia BH-503 Bluetooth Headset
It did not charge
The you have either not inserted the charging plug fully, the charging socket is faulty, the charger is not working, or the battery has failed.
I'll assume that you're familiar enough with your headset not to have done the first option. The charging socket is probably ok if there's no obvious visible damage and it's likely that the charger is working too as they're so reliable, but you can always eliminate it as a possibility by borrowing another charger or testing the socket output against the figures printed on the charger.
But by far the most likely culprit is the built-in rechargeable battery. It's not designed to be replaceable as the complete headset is only expected to last two years, but Jabra do have a one year warranty on it: if it fails they just exchange the complete headset for a new one (or the charger if that proves faulty). Your unit can't be very old as the model is a fairly recent one, so you should first try for a repair, refund or replacement (your choice) from the retailer (a legal right under the Sale of Goods Act if you're in the UK) and then contact Jabra directly if either the retailer won't help or if Jabra has told them to refer all repair claims to them.
You'll find a link to the warranty terms here.
May 07, 2010 | Jabra BT800 Consumer Headset
Charger isnt recognized
Dell portables use a sensing wire in the barrel of the adapter plug to determine the wattage of the ac adapter. If that fine wire in the center of the plug is bent or broken, the system cannot ID the adapter and the battery charger is disabled.
SO, first try a known good AC adapter for a D-Series Dell (You might be able to check with Geek Squad at a local Best Buy if you don'e have access to another ac adapter) If a known good ac adapter works, then replace the ac adapter.
If a known good AC adapter does the same thing then the fault is in the charging circuit of the motherboard and the motherboard will need to be replaced.
Oct 03, 2009 | Dell Latitude D600 Notebook
All of a sudden my CS 55 with plantronics stopped working. It shows that its on but the headpiece isnt charing and also doesnt work. Any ideas why?
If the Plantronics CS55 wireless headset shows that it is on, you have to make sure of the following things.
a. the green LED on the base turns on when you turn the call switch on from the headset.
b. the small green LED on the side of the headset is blinking.
c. the telephone headset is lifted from the cradle.
d. if the headset is not charging and the Amber light on the base does not blink when you place wireless headset on it; trying placing the headset more firmly.
e. If the headset is not charging and the Amber light on the base does not blink even after placing the wireless headset firmly on the charging cradle, you may need to change the battery.
Alternately you can try resetting the Plantronics CS55 wireless headset.
Reset Plantronics CS50, CS60 or CS55 Wireless Headset
If you have problems with the sound or connection of your Plantronics CS50, CS60 or CS55 wireless phone headset, you may want to try to hard reset it using the following steps:
Note: Ensure the IntelliStand switch (on the right side of the charging base) is in the - position and NOT the = position.
1. Press both the call control button and the listening volume/mute button for 5 seconds. When the indicator light blinks release both buttons.
2. Press the call control button again. The talk indicator light will again blink to indicate the headset is back to normal.
3. Disconnect the AC charger from the AC charging jack for 5 seconds.
4. Reconnect the AC charger.
Now give the Plantronics headset a try.
Jan 10, 2009 | Plantronics CS55/HL10 Wireless Office...
Kyocera wild card Cellular Phone Logo
121 people viewed this question
Top Kyocera Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
