Question about Hayward SAND FILTER, PRO SERIES
My hayward sand filter will filter but the backwash and rinse does not work. What can be the problem?
  • 8,404 Answers
Do you have a multi port valve or a push pull?
And what is the evidence it doesn't work???
Disassemble the valve and check the O rings or the spider gasket. If a multi-port ... you are suppose to turn it ONLY in a clock-wise direction.
Since yo mention rinse, Im guessing you have a multiport valve. You will not see much evidence of activity in this mode ... this blows the last little bit of backwash water out the waste line.
Do you have a site glass on your back wash?
Posted on Jun 05, 2010
  • A Miller Jun 06, 2010
    ... so what happened???
How to get the right pressure to backwash and rinse
you dont need a lot of pressure to backwash just make sure water is clean coming out then rinse for 30 sec then put back on filter do not turn valve while filter is running you will ruin multiport gasket
Jul 18, 2014 | Hayward SAND FILTER, PRO SERIES
I cannot read the diagram on top of my hayward sand tank filter pro-series s244t filter,close,waste which way
go to westport pools.com and see if you can find a picture of it or go to hayward filters..
Jan 06, 2014 | Hayward SAND FILTER, PRO SERIES
I have a Dream Line sand pump and label on top fell off. Can not tell where to set valve for backwash, rinse,waste or recirculate are? thank you for your time and help.
Filter position is with notch on handle seated and pointing to the pressure gauge.
Working clockwise - Waste; closed; backwash; recirculate; rinse;
May 05, 2013 | Hayward SAND FILTER, PRO SERIES
Hayward s166t sand filter has sand in sight glass during backwash
did you get sand in vertical tube if so it will take time to get out of line
Jun 12, 2012 | Hayward S166T Pool Filter System w1 HP...
I put my Hayward ST180T on rinse to vacuum the pool and I ended up with sand in the pool what happen?
You are using the wrong setting to vacuum. This type of pool filter should be set to "filter" for normal vacuuming or to "waste" for heavy loads. The "rinse" setting makes sure that all of the dirty water is out of your filter after backwashing.
Jul 14, 2011 | Hayward SAND FILTER, PRO SERIES
Recommend backflush pressure of a hayward pool filter
After you have backwashed your filter until the site glass run clear. Go to rinse mode for 30 seconds. Make note of the filter pressure. Don't backwash until the pressure goes up 10 psi!! It is important not to backwash too much. As pressure climbs the sand filter actually filters better.
Aug 02, 2009 | Hayward SAND FILTER, PRO SERIES
I have a hayward s200 sand filter. When I vacuum, i backwash but dirty water doesnt seem to backwash out, just clean water. When I turn filter on small amounts of dirt you cant see come out of jets and re...
Are you using the rinse setting for a few seconds following the backwash? If not, once you finish washing, stop the pump, change the valce to rinse, then run it about 3 to 5 seconds. Shut down then switch to filter and the particles should stop coming back to the pool.
Jul 05, 2009 | Hayward SAND FILTER, PRO SERIES
Multi-valves on hayward sand filter mixed up
Key Cover Assy needs new spider gasket. If it is a newer model the gasket is made into the key cover and it will have to be replaced
Apr 27, 2009 | Hayward Pro Series 18" Above Ground Pool...
Hayward SAND FILTER, PRO SERIES Logo
320 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
