Question about Mitutoyo #117 107 0 1 Uni Mike Micrometer .0001
I lost my owner's manual and need to know how to reset the micrometer to zero
    Scholar:
  • 130 Answers
This is based on an old Brown & Sharp guide book. 1. Carefully clean the measuring surface by pulling a piece of soft paper between the surfaces while the anvil and spindle are in light contact with it. 2. with the anvil and spindle apart, unlock cap with spanner wrench (supplied with unit), then tighten cap lightly with fingers to bring slight tension between thimble and spindle. 3. Bring anvil and spindle together by turning SPINDLE and set zero line on thimble to coincide with line on barrel. 4. Move spindle away from anvil by turning SPINDLE, NOT by turning thimble. 5. Holding thimble only, tighten cap with fingers. Do Not Touch Frame. Lock cap with wrench, still holding thimble only, and adjustment is complete. NOTE: Check zero setting after adjustment is made. Hope this helps
Posted on Jun 08, 2010
I have a fowler IP54 outside caliper micrometer 7-8" that is zeroed out. There are only 2 keys, a mm/in and zero. How do I reset to have it read 7.0 at 7.0?
Generally, micrometers are "zeroed" to a standard -- an object of a known specific length or diameter. If you have placed a 7-inch standard in the micrometer and brought the spindle into proper contact with that standard, and then zeroed the micrometer at that point, it will be properly set to seven inches. Standard micrometer travel is only one inch, and only that range is usually displayed. The user must then add the standard length to the face display or thimble reading to get the "developed" measurement.
Jan 08, 2015 | Fowler Measuring Tools & Sensors
My ignition is locked lost my key 1100 Silverado
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
YAMAHA XVS1100 Owner Manual
OEM parts for Yamaha
Yamaha XVS1100 Service Manual
Road star ignition bypass
Re Bad ignition switch Road Star Forum Yamaha Road Star
Apr 03, 2014 | 2004 Yamaha V Star 1100 Silverado
How do i reset service indicator yamaha x-city
YAMAHA XCITY VP250 Owner Manual Handlebar Switches
YZFR 125 OIL SERVICE LIGHT RESET OIL WARNING LIGHT RESET OIL WARNING
Yamaha YP125R Service Manual
Feb 21, 2013 | 2009 Yamaha XCity 250
How do you put a preset in Mitutoyo uni-mics?
Normally you would adjust it to the part being measured then press the 'Zero' button to zero out the display. Now every time you measure the same type of part, it should read zero or the dimension plus or minus from that zero point.
Nov 20, 2012 | Mitutoyo 317-351 Digital...
How to reset depth micrometers , any style , easiest method for Mitutoyo line
The nut on the end of each rod is for calibrations. On a clean flat surface check your reading at "0"and see if adjustment is needed either left or right on the nut for getting before zero or after zero readings. Adjust the nut as little as possible and re check for zero multiple times because the nut is sensitive. hope this helps.
Jun 29, 2011 | Mitutoyo Depth Micrometer 0-6"
2006 Yamaha Stratoliner replace the battery
Hi, Joe9200 for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Roadliner Stratoliner battery replacement
how to put new battery in 2008 yamaha roadliner
Yamaha XV19SW Service Manual
Yamaha ROADLINER XV19SW Owner Manual
May 02, 2010 | 2006 Yamaha Stratoliner
I need to adjust a 293-761-30 mitutoyo micrometer.
there should be a small silver spanner with a couple of pins protruding to do that with comes in the box if you haven`t got it come back to me
Aug 15, 2009 | Mitutoyo 293 831 Electronic Digital...
How to reset Mitutoyo 314-351 "V" anvil micrometer. It should not read "0" when turned all the way in.
In order to reset the zero point for your specific micrometer, you will need to have a standard set of pre-set dimensional pin(s). You can check the attached link (page 71 of the Mitotoyo catalog) for the information you need). I guess you could try to find or make a pin with the same dimensions as those noted on the catalog page, but if you're using this in a manufacturing setting, you might have no choice but to purchase a set of gauges for calibrating your micrometer.
The only other option is to contact the manufacturer for an alternative method, but I doubt they'll be able to provide any alternative, as precision setting of the zero point is required for accurate readings with this specialty micrometer.
http://www.mitutoyo.co.jp/eng/products/micrometer/Micrometer_2.pdf
Jul 28, 2009 | Mitutoyo Measuring Tools & Sensors
Micrometers out of calibration
Micrometers must be calibrated at 4 spots around the barrel and at zero and full scale to be truly accurate. You will have to send it to a calibration lab or back to Starrett for a full calibration because they will check it with gauge blocks of known length and verify the spindle and anvil surface flatness.
If you are only concerned with the zero and not as much about the full accuracy of the tool, then you can reset the zero yourself. With the mic fully closed (spindle and anvil touching), turn the barrel with the funky, half circle shaped wrench that came with the mic in the box. There is a little hole in the barrel where the nub on the wrench will fit then you just turn it until it reads zero. Good luck.
Mar 07, 2009 | Starrett T216XRL-1 - MICROMETER, DIGITAL
Lost manual, need instruction on how to reset Taylor 5700 BMI
personalcare.owneriq.net/manuals/mfg/taylor/5571.html
go to that address and you can download the manual.
Feb 03, 2009 | Health & Beauty
Mitutoyo #117 107 0 1 Uni Mike Micrometer .0001 Logo
349 people viewed this question
Top Mitutoyo Measuring Tools & Sensors Experts
Doug Adams
Doug Adams
Glenn
Glenn
Are you a Mitutoyo Measuring Tool and Sensor Expert? Answer questions, earn points and help others
