Question about Mitsubishi WD-52631 52" Projection HDTV
STATUS LIGHT YELLOW, LAMP LIGHT GREEN: TV TURNS OFF.
I READ THE OWNER'S MANUAL AND WITH THE ABOVE STATUS IT SAYS ONLY THAT THE ROOM IS TOO HOT. WELL, THE ROOM IS THE BASEMENT AND IT IS QUIET COOL. WHEN THE TV IS FIRST TURNED ON, IT IMMEDIATELY GOES TO STATUS LIGHT YELLOW (SOLID) AND LAMP LIGHT (FLASHING GREEN) AND THE TV SAYS TO CHECK THE AIR FLOW. COINCIDENTALLY, THE FIRST TIME THIS OCCURED, I HAD JUST MOVE THE TV ABOUT 8 FEET TO A CORNER AND REPLACED THE SATELLITE CABLE THAT RUNS FROM THE WALL TO THE BOX.
  • 2 more comments
  • deroyal May 07, 2008
    The TV turns off, yellow light stays on, room is not hot. Where do I find the air flow filter?
  • iceman99 Jun 05, 2008
    Mitsubishi DLP HDTV (WD-57731) shuts off. A measage reads " TV will shut down in a few seconds"? A message on the TV reads " TV will shut down in a few seconds, be sure air flow is not blocked". Which it is not. The status lights is solid yellow - that is not in the owners guide. TV is 1 year old.
    I have the identical problem. What was the solution? Repair man insist that I need to replace my lamp at a cost of $250 plus labor $100 (includes house call.) I have my doubts that this is the problem.
  • crosscd Jun 16, 2008
    I'm having the same problem. TV states to check the air flow. I took the back off and used a vacuume and it worked for about a week. I got the message back and this time I blew the unit out with an air hose then sucked out any additional dust. The problem was not fixed. Where is the filter? I don't see that I have one. Also, the fan is running when the tv is turned on and continues to run few about a minute after shut down. Any solutions yet?
  • guitarfarmer Sep 13, 2008
    STATUS LIGHT YELLOW, LAMP LIGHT GREEN: TV TURNS OFF. Indicate check airflow
Actually, I think I found the problem. I took the light out and cleaned the filter (screen) on the light cartridge. I turned the tv back on and it still gave me the message. As the tv was still on, I tapped on the fan that sends air directly to the light cartridge and the message went away. About 2 days later, I got the message back but went I shook the tv and tapped it on the stand a few times, it worked. I think that particular fan is going out and seems to be a problem with other tv's as well. Any ideas where I can buy a fan? Hope this helps you all out.
Posted on Jun 24, 2008
  • Mitsubishi Master
  • 8,617 Answers
Have you checked the air filter located on the side of the unit? Also can you hear the fan start as soon as you plug the set in?
Posted on Apr 09, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
Mine is doing the same thing i put 2 fans on the back for 1 day it is 74 deg in room and the yellow light is still on
  • ptowncarson Jun 24, 2008
    in is not the lamp note that the status light is on and it says its to hot in room
    need to pick up a small fan to add to tv from the front add fan on the left side next to the vent i tried this and work watching tv right now dont use a box fan to point at the tv you need to move the air though the inside back of tv
Why does my Mitsubishi XD221U projector click and blink red/green on the power light when turned on?
All projectors run a self diagnosis when you press the power button. This does a kind of "pre flight check". If some component isn't working right then the projector won't fire up.
There's no mystery to these status lights. The answer to what they show is written in the manual. Sorry to be blunt, but if you had bothered to read your manual then you would know that red green flashing power light means that the lamp housing cover isn't closed properly. If it is the status light, then it means that the lamp has gone past its due time for replacement. I only know this because I read the bit in the manual just now about the Status Lights.
Sep 03, 2014 | Mitsubishi XD221UG DLP Projector
Yellow blinking light . what does it mean
A blinking yellow for this model indicates the TV is too hot, unplug & allow 30-45 min to cool before re-plugging .
OR: lamp not installed or lamp door not closed. there is a lamp door switch that may not be closing, simulating door not closed
LED Indications
The front panel Status LED provides an indication of
the set's operation and the possible cause of a malfunction.
If an abnormal condition is indicated, perform the
Self Diagnostics procedure.
Self Diagnostics
To activate, press the front panel <ACTIVITY> &<CH
??> buttons at the same time and hold for 5 seconds.
The STATUS LED will then flash denoting a two digit
code.
• The number of flashes indicates the value of the
MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2
second.
• The LED then flashes indicating the value of the
(ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED
will flash two times, pause, and then flash three
times.
Table 2-2: LED Indications
Error Codes, descriiptions and the most likely cause of
the error are listed in Table 2-3.
Note: The TV must be in "Shut Down." The LED
will probably be indicating an abnormal
condition. If the TV is switched Off, AC is
removed, or a System Reset is performed, the
code automatically resets to "12" No Error.
See the Error Code Log to retrieve a history of
errors.
Note: Use the front panel buttons, not the remote
control.
Note: If there is no response, the front panel may be
locked by a V-Chip setting. To unlock, press
and hold <ACTIVITY> on the front panel for
8 seconds.
LED Indication Condition
Off Off (standby)
Green Power On
Slow Blink Green Power Off with Timer Set
Fast Blink Green (80 seconds) > Off Power Off (Cooling fan still working, 80 sec)
Red Lamp Failure
Yellow TV Too Hot
Slow Blink Red TV May Require Service
Slow Blink Yellow Lamp Door Open or No Lamp Installed
NORMAL INDICATIONS
ABNORMAL INDICATIONS (For details perform Self Diagnostics Procedure.)
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
Status light yellow, won't power on
Hey, I just unplugged my Cyberhome DVD for about 5 minutes and replugged it in. It is working fine. Try it with yours and let me know..
Lcamp518@zoominternet.net
Feb 08, 2009 | Cyberhome CH-DVD 300 DVD Player
TV doesn't come on
Please change Lamp and procedure is written in user manual of TV.
You can see price details of Sony original Lamp at Sony Accessories Store by typing model number in search box and click.
Jan 19, 2009 | Sony Grand WEGA KF50SX300 50" Television
TV was working earlier, today came home no green power light no nothing
I looked up the manual online - after you replace the bulb, you need to reset the bulb life timer. Using the TV remote push the menu button, SETUP menu, select the lamp reminder option to reset the hours to zero. That might help the status indicators.
Sep 04, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Yellow status light on mitsubishi wd-65733 tv
When tv goes out, press the menu and input buttons. The green light will flash with a 2 digit code.
Jul 26, 2008 | Mitsubishi WD-65733 65" HDTV
Tv keeps turning off?
cutta, you will most often hear a click on boot then the fans start up and lamp will then fire. The picture will start to show up....at what point does it shut off? and do you hear a click when the tv is turning off? Is it the complete tv shutting down, fans and everything that turns off? Do you see any lights on the the front panel "POWER", "STATUS" or "LAMP", what are they doing? If you see a Power, Status or Lamp light after it shuts off the below are what they mean if there is an issue. POWER - STATUS - LAMP - CONDITION/ISSUE: Off - Yellow - Off - Temp. high/dirty filter/excess room temp Off - Off - Yellow - 4000 hrs. Lamp usage warning Off - Off - Blink Yellow - Lamp Cover open Off - Blink Yellow - Off - Air Filter Cover open Off - Off - Red - Lamp failure (failed to turn On or broken) Off - Blink Red - Off - Fan Has Stopped Off - Red - Off - Circuit failure (short) or DVI cable disconnected If you want to check for the last "Error Code", after you first turn the TV on, by pressing the front panel ?DEVICE? and ?MENU? buttons at the same time and holding them for 5 seconds, it activates the Error Code Mode. The ?Power LED Light? blinks/flashes (1/2 sec delay) and then flashes again denoting a two digit Error Code indicating no problem or an error has occured since the last Initalization. i.e. "Power light" blinks 3 times (1/2 second delay) and then blinks 4 times then 1 sec delay and repeats a few times. This would mean "Error 34 - Lamp abnormality". See below for error codes..... Error Code - Description or issue 12 - No Error detected, check Power Supply 32 - Lamp Cover is open 33 - Air Filter Cover is open 34 - Lamp abnormality 36 - Light Engine (DMD or LAMP Fan stopped) 37 - Exhaust or Lamp Ballast Fan stopped 38 - Lamp temperature high 39 - DMD temperature high 41 - Short is detected 44 - DVI cable between FMT & Engine disconnected. Sorry for the long answer but it was an open ended question.
Jul 11, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52631 52" Projection HDTV Logo
921 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
