Question about NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111)
How Do I Close the Netgear Wireless Adapter Window
Everytime I start my computer. The Netgear Wireless Window opens automatically. Everything works except I have to close it everytime I go into my computer. Is there a way to get rid of this?
  • 4,281 Answers
For that you have to disable startup.
For that press windows key +R key so you can see run then type in "msconfig" without "" then press ok.
Then you can see system configuration utility click on last tab startup and disable all startup or netgear utility then apply and restart computer then it not open at startup.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Jun 04, 2010
Netgear WN111v2 Adapter disconnected
Is the Netgear Wi-Fi Management software installed on the computer? If it is, you may have a conflict between Window's built in Wi-Fi Manager and the Netgear Wi-Fi Manager. If it isn't, you may need to install it.
Assuming it isn't, there's links to download the software at the Netgear Global Download Center.
I would default to the most current version, if you're running Windows XP, you may need to install the v2.1, however, I would assume the v3.1 would be backward compatible with XP.
Install the software and follow the prompts that will guide you through the installation/setup.
Now, if the software is already installed, you need to find the program and configure it through that avenue. If that does not fix the issue, you should uninstall the Netgear software, remove the Wi-Fi adapter and reboot the computer. After it completely boots back up, you should either plug in the Wi-Fi adapter, let Windows recognize it and install the drivers, (they should still be in the system even after you uninstalled the software). Once Windows successfully locates and installs the drivers, reboot the computer again, (no need to remove the adapter). Once Windows completely loads again, open Start, Control Panel, and System. On the resulting window, click the hardware tab at the top then click the "Hardware Manager" button in the middle about 1/3 down the window. Click the "+" next to "Network Adapters" and verify that your WN111v2 is indeed installed.
Assuming it is at this point, close out everything but the Control Panel and open "Network Connections". Find the wireless adapter there, (may be listed as "wireless connection2" depending on how many times it's been installed). Right click on the wireless device and select "Show Available Wireless Networks"
I'm also uploading a video showing what needs to be done.
Establishing WiFi Access in WinXP
Jan 27, 2014 | NetGear Computers & Internet
Tip
How to connect to always automatically connect to your SSID
Ever turn on your computer and try to connect to the internet? Ever see all the many SSIDs in your neighborhood listed in your wireless radar or your "Windows Wireless Connection". Then you'd scroll down to double click on your SSID so that you can connect to the internet. Imagine doing this everytime you have to connect to the internet. Wouldn't that be annoying?
The Objective
The objective of this Tip/How-To is to have you turn on your computer and connect to the internet automatically via your SSID (Wireless Network Name). Hence, you wouldn't need to manually find your SSID everytime you need to connect to the internet.
Pre-requisites or Must haves for this Tip to work
  1. A computer with a wireless adapter
  2. A wireless router
  3. An active internet service
  4. This tip is designed for Windows XP. I will post one up for Windows Vista and Windows 7.
  5. This tip is designed to work with Wireless Networks (SSID) that do not have any passwords or encryption.
Active Tip Dictionary (throughout this TIP)
SSID
is the technical term for your broadcasted network name. This is basically what you will see listed in your WIRELESS NETWORK CONNECTIONS manager.
To make your computer connect automatically to the internet via your SSID, we will need to manually tell your computer to connect to your SSID and then we will need to save this setting so that your computer will automatically connect to your SSID everytime you turn on your computer.
Let's Begin.
Start your computer by turning it on.
Click on your Start Button.
Move your mouse over to Control Panel and then left click on it.
Double click on the Network Connections icon.
Double click on Wireless Connection. Now in the picture above you see Wireless Connection 3 but on your screen you should see Wireless Connection.
Now click on Properties.
Click on the Wireless Networks Tab.
Now scroll up and down under Preferred networks until you find your Wireless Network Name (SSID). For me, it's called linksys therefore I will select linksys.
Now click on the Connection tab.
Under Automatic connection, click to check "Connect when this network is in range". This will tell your computer to connect automatically to your Wireless Network Name (SSID).
Click OK to save this setting.
Click OK again to get out of the Properties window.
Click OK again to get out of the Wireless Connections window.
Then click Close to close out of the Wireless Connections window.
And there you have it, you have setup to automatically connect to your Wireless Network (SSID) everytime you turn on your computer.
Now restart your computer and give it a few seconds, and voila, you are automatically connecting to your Wireless Network (SSID). Now you can surf the internet. You can set this on all your computers at home that have a wireless card.
Remember to give me a good rating and vote for me. If you require further tips and tricks, feel free to contact me through the contact box. I will post up your tip.
on Apr 05, 2010 | Computers & Internet
After I installed a netgear usb adapter wg111 I periodically receive a chime. Where is it coming from? Why am I receiving the chime? How do I diable the chime?
Well, the chime sound is generated by the NETGEAR utility software installed on the computer. You may perform the below steps to configure the Windows utility so as to avoid the NETGEAR utility to connect to wireless network and this in turn will disable the chime sound:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply.
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab.
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
7. Highlight thee SSID from the list that you want to connect to.
8. Type the security Key here and click on the 'Connect' button.
9. You should have successfully established a wireless network connection.
Hope this allows you to resolve the issue.
Regards
Anand
Mar 19, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
After i install my netgear wireless adapter, it
Please perform the below steps to configure the wireless connection:
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jan 11, 2010 | NetGear WG111T 802.11g/b (E82321) Wireless...
Make Netgear WG111 802 start automatically without showing wizard
download the compabtible driver to this adapter fromt he manufacturer's website. look for vista driver for netgear wg111
Nov 06, 2009 | NetGear WG111 802.11g/b Wireless Adapter
Netgear wg111 usb 2.0 won't connect even after clicking repair
Hi, Follow the steps below to configure settings:
4. Highlight thee SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
Sep 02, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear Wireless adapter not working
Hi, Follow the steps below to configure the wireless adapter settings on the XP system:
8. Go to the 'Wireless Networks' tab .
If I have helped you, please help me, and rate this suggestion with the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jul 28, 2009 | NetGear WG111 802.11g/b Wireless Adapter
I have just purchased a netgear MA111 wireless adapter, for my desktop pc, which is running xp, the problem i have is that everytime i plug in the adapter, the computer restarts, if i disconnect the...
Hello annwiles,
Checking IRQ Conflict in Windows 2000 or XP:
1. Click on the Start button, and click on the Run option.
2. When the Run window opens, please type in devmgmt.msc and click OK.
3. When the Device Manager Window opens, click the View menu. Then, select Resources by Connection.
4. Expand the Interrupt Request (IRQ) category to view IRQ assignments.
5. Once you find your adapter on the list, check if the number that is assigned to it is the same as anything else on the list.
6. If your adapter is sharing an IRQ with another device, you may be having an IRQ conflict.
Resolving the IRQ Conflict:
1. Try placing the Network Adapter into different PCI slots. By doing this, the BIOS will assign the network adapter a different IRQ.
2. Disabling COM and parallel ports, or built in motherboard devices (sound chips, etc) in the BIOS may help to free up their IRQ's.
Note: Changes to the BIOS can cause major problems with your computer. If you are unsure, please contact the manufacturer of the PC for further assistance.
3. You may be able to assign IRQ's by PCI slot in the BIOS. Please contact your computer manufacturer for more information.
Apr 09, 2009 | NetGear MA111 802.11b Wireless USB Adapter...
Wireless USB Adapter not wanting to open.
Hi This problem usually happens when the usb adapter as been plugged in before the software as been installed, try uninstalling the software restart your computer then reinstall your software, once finished close computer down plug adapter into usb port then re-start the computer hopefully this will work and you can configure the wireless settings via Netgear Network.
Aug 07, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
How can I install a wireless usb adapter WG1111....
First put in the cd that came with the wireless USB adapter. Close the auto setup page(we will use windows wireless network manager which works better with windows firewall . Plug in the wireless adapter and the laptop will automatically install the driver. If for some strange reason it asks you to install new found hardware, follow the promts and install manually and select cd and the directory the WG1111 drivers are located. Press ok and wait for install. Restart the computer.
After restart the computer will come up with a caption New Wireless Networks found. Double click on the wireless Icon in the bottom left hand corner. It will open a seperate screen with all wireless connections avaliable to you. Might be 1 or more networks, depending on whether your neighbours have wireless networks. Anyway find your specific wireless network could be for example NetGear, Dlink, or my home network. Click on connect your wireless connection. Another smaller screen will appear with Key in your password twice( WEP key or WPA key)
Key in your key or password twice and apply or ok. It will connect and close screen.
Restart computer!
After restart the computer will pick up your connection automatically and your ready to go on line. If you move your mouse down to the icon with wireless network in bottom left hand corner it will show your wireless connection in a caption stating the connection name and how strogn signal is. Connection complete.
NOTE: YOU MUST HAVE A WIRELESS MODEM OR WIRELESS HUB CONNECTED TO YOU MODEM TO USE THE WIRELESS WG1111. THANKS!
Aug 02, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111) Logo
81 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
