Question about Apple iMac G4 Desktop
Computer sounds like it is starting up but screen is black - is it possible that the monitor has gone bad? Or does that suggest something worse?
  • Apple Expert
  • 481 Answers
It is quite possible that your monitor has gone bad with age or impact. Fastest test is to hook up a separate display using the auxiliary monitor port -- if you get an image on that monitor but not on your main monitor, and the rest of the computer operates properly, your LCD panel or inverter has gone bad.
Either is a relatively simple fix for a certified technician. The inverter MSRPs for $60-80 but can be found for as little as $16 used. The LCD panel MSRPs for $250-300, but can be had for as little as $80 used. Prices quoted are for the 17" version iMac.
Posted on Jun 18, 2010
Flat screen has gone black but sound is fine
Suggest that you borrow a monitor from someone and try it on your system. If it works , you may have a defective backlight on your monitor , which means that you may want to replace the monitor. If the replacement monitor also is black , you probably have a video output problem , which would require repair of your computer.
Dec 01, 2014 | Bush Televison & Video
Acer monitor screen showing partial screen only. rest of screen showing black & white dots.
Hello there.
Try the monitor with ANOTHER computer,
This will prove whether it is the Monitor at fault or not.
Sep 25, 2014 | Computers & Internet
My laptop Gateway ml6720 has a black screen Ive replaced the battery and power adapter no change. The fan comes on and it sounds like it boots up but no screen.
Sounds like either the screen or the video adapter has gone bad.
Do this: Connect the computer to an external monitor (there is a SVGA plug on the side of the computer. Be sure when you turn it on that you press teh Fn-special function key combo that switches the video output to the external monitor. If the external monitor works, then it's your computer's screen. Possibly the inverter. If the external monitor shows nothing, then it's the video card (which may be built into your motherboard).
Oct 05, 2011 | Gateway Computers & Internet
Desktop PC monitor suddenly went black & power light went off
1 either ur VGA card is corrupted or
2 RAM is corrupted
3 Last may be your motherboard is gone - not sure
Jan 04, 2010 | Computers & Internet
My computer monitor screen appears to shake or vibrate
well that happens because of internal faults, it is possible that some IC have gone bad, so take your monitor to service station as soon as possible before something worse happen
Nov 11, 2009 | Computers & Internet
Monitor is black...checked all connections..OK. Turned computer off and back on,still no screen. HELP!!!
The first thing I would do if possible is hook up another monitor to the computer to see if that one works. If it does, then your monitor has gone bad. If it doesn't work either, then your video card has gone bad. Did you hear any beeps when you started up your computer? If you did, then this usually means there is something wrong with the video card. Also, sometimes the power button is turned off. Are there any lights lit at all on the monitor and are they green or yellow?
Aug 18, 2009 | Gateway FPD2275W LCD Monitor
Hp dv9000 switches on to show coloured lines on screen.
Hello
My first guess is that the screen circuitry has gone bad - although fixable. Use an external monitor to verify this. If the external monitor is fine then the screen circuitry is bad, if the external screen shows the same problem then the video chip or associated circuitry has gone bad. My company fixes these all the time.
Jul 28, 2009 | HP L1702 17" LCD Monitor
HP Pavilion laptop screen has gone black/blank
No it suggests you have a bad screen and it needs replaced
Jun 22, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Monitor flashes on when I turn computer on, then screen black
Your monitor power supply or inverter board have gone bad. Its not your computer video card
Apr 17, 2008 | Westinghouse LCM-19v1 Monitor
LaCie 10 CRT
I would try booting the computer in safe mode (if it's windows) and adjust your display settings. It sounds as though it is trying to display from your computer something that it cannot properly.
Mar 28, 2007 | LaCie Electron IV 19" CRT Monitor
Apple iMac G4 Desktop Logo
168 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
