Question about Polaris 800 Twin Sportsman Ride on Toy
Peg perego 800 Polaris 24v will not go into high gear..reverse and low gear fine, but will not kick into high gear..what to check for??
    Genius:
  • Polaris Master
  • 1,508 Answers
Did you remove the high speed lockout? if so then you probably need a new foot pedal, let me know if you do i can order you one
Posted on May 23, 2012
  • 4 Answers
SOURCE: peg perego polaris 4 wheeler
If it runs only in slow speed your hi/lo speed switch is bad. Cheapest I've found is at tigerimports.com part#MEPU002 for $11.00 plus $2.00 shipping USP. Hope that helps.
Posted on Oct 19, 2008
  • 19 Answers
SOURCE: Peg Perego Gator Ride On Toy
I had a peg perego gator hpx that was soing the same thing and I replaced both the high low switch and the reverse switch.
I found them at this website http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
hope this helps
Posted on May 02, 2009
  • 156 Answers
SOURCE: I just put together a Peg perego Polaris RZR ride
For this Peg Perego Razor model, some of them have a lever that slips over the foot pedal to keep it from going in reverse for safety reasons.
I would check the foot pedal and see if it has one.
Let me know what you find.
Posted on Jun 01, 2009
  • 156 Answers
SOURCE: peg perego gator grinding noise?
The Peg Perego Gearbox is the item that would make a clicking noise or grinding noise.
There are two different types.
One is a cross shape and another is a pentagon shape.
If you contact the folks at http://www.shopjandl.com/ they will be able to tell you what type you need. I get all my parts from them because they help me figure the problems out.
Hope this helps
Posted on Jun 09, 2009
  • 156 Answers
SOURCE: wiring specs for peg perego polaris 700
I would contact the repair help at
They seem to know a lot about these toys
Posted on Jun 23, 2009
Reverse and low gear barely - if at all - working
i had this same problem with a peg perego john deere tractor and it ended up that one of the motors was bad. I would disconnect one fo the motors and then try all of the gears and then try the same with the other motor and see if that works, you'll have to pull the rear wheels off to access the motors
May 01, 2012 | Polaris 800 Twin Sportsman Ride on Toy
Tire makes a grinding noise on perego polaris sportsman 800
Why dont u try adding grease to the nuts and screws then loosen the nuts a bit to give air space...try it out
Dec 28, 2011 | Polaris 800 Twin Sportsman Ride on Toy
I have a peg-perego sportman 800\r\nand i can't go
In high gear only 1 wheel will turn. Remove the wheel that does not turn and lift the motor. Look for a lose wire and reconnect it to the motor (it pops off the post). re-assemble and it should work just fine
Jun 05, 2010 | Polaris 800 Twin Sportsman Ride on Toy
Peg pregeo 800 worked for 30 mins. then just stopped.
Although the problem is not the exact same, it is similar. I finally got mine fixed (see post about does not work when pedal is pushed) My problem was the shifter was bad, or the plug for the shifter was bad. I had to take to Rural King to get it fixed, PP service locations are too far away from me .. hope this helps some.
Dec 25, 2009 | Polaris 800 Twin Sportsman Ride on Toy
John Deere Gator 4x2 - Left Wheel doesn't move when in 2nd gear
I would replace the high/low switch and the reverse switch. One time a replaced the high/low switch and the reverse switch quit on me 2 weeks later.
You can also get the Peg Perego Gator Shifter that upgrades the vehicle.
You can get the parts and repair help at this site
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html
They have helped me several times.
Hope this helps
May 21, 2009 | Peg Perego John Deere Gator HPX Ride on...
MY SON'S 2 YEAR OLD POLARIS WILL NOT RUN IN REVERSE AFTER A NEIGHBOR CHILD RODE IT.
I would check and make sure the wiring on the foot pedal is on.
The Peg perego polaris models will sometimes get corrosion on the red wire.
I called the guys at this website http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html and they said to check the red connection. sure enough the connector was barely hanging on.
Hope this helps
Dec 05, 2008 | Polaris 800 Twin Sportsman Ride on Toy
Polaris 800 Twin Sportsman Ride on Toy Logo
421 people viewed this question
Top Polaris Toys Experts
Adam Fjeld
Adam Fjeld
cwradio73
D. E. Hev
Are you a Polaris Toy Expert? Answer questions, earn points and help others
