Question about Whirlpool Dishwashers
I have a blinking cancel light on model GU1200xtlt1 and will not start in any cycle. Also if I push another button it flashes rinse button and cancel button. Before this it ran in Sani Clean over and over again and I could not change the cycle. I emptied out a bit of water from the bottom because it did not drain also and the water was not smelling too good.
catriver
  • 878 Answers
SOURCE: Clean light flashs seven times, stops and then does the same over again.
bellman, on this model I believe you can clear the fault by pressing high temp scrub--air dry--high temp scrub--air dry in that order. Your normal cycle on this dishwasher is approx 97 minutes without the thermal holds, (pauses to heat the water to proper temps.) So of course it's going to go over 97 minutes. This is for heavy soil. Light soil, approx 89 minutes. Some models have a soil sensor, some don't. If the sensor is out of specs..it could add to long wash times. The heater may in fact be the problem, he needs to check it. The heater runs through the nuetral side of the door switch so you want to make sure the switch is closing and the dishwasher is level and secure. He also wants to check out the resistance of the thermistor, should read 48 to 52K ohms at aprox. 75 degrees. Catriver..post back.
Posted on Apr 15, 2007
SOURCE: Kenmore Ultra Wash Dishwasher - Blinking Quick Rinse Light
My guess is that the foil that the buttons are mounted to is defective.  The control module "reads" the buttons that are pushed by the fact that the resistance between two pins on the circuitboard becomes zero ie. your pushing the button shorts out two pins.  the foil could have moistire damage or the resiistance of the tracks could be too high.  Solution for both would be to replace the control panel button foil.
Posted on Oct 17, 2007
SOURCE: green clean light dishwasher will not run
unit hs had power disconected for four months
Posted on Dec 29, 2007
djnick989
  • 1067 Answers
SOURCE: SANI RINSE LIGHT KEEPS BLINKING
what model sani is yours please
Posted on Jan 21, 2008
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
Start light is red
Really need more info, like approximate age and model number. Also does it still run, or does it just sit there? Does the light blink? Does it beep at you? Can you change cycles or options? Can you press Cancel to cancel the cycle and start over? Did you try unplugging the dishwasher and plugging it back in?
Jul 25, 2014 | Kenmore Dishwashers
Blinking start/cancel light
Mine blinks if the door has been opened after a cycle has started. I reset the start by pushing the blinking start/cancel light
Oct 16, 2012 | Kenmore 24" Built-In Dishwasher with Ultra...
Green start button won't stop blinking
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
Nov 29, 2010 | General Electric GLD6966RSS Stainless...
My kenmore dw just stopped running thru cycles except drain
Hello, With the information you supplied I'm going to assume the light is blinking 7 times and pausing then blinking 7 times and so on. With the door cracked open hit the following button combination: -high temp wash
-heated dry
-high temp wash
-heated dry Then close the door and hit cancel. The pump will run for a few moments and then you should be all set. Hope this helps Mike
Nov 19, 2009 | Refrigerators
There are a bunch of lights blinking on the panel that I cannot cancel.
dont know what make/model but try pressing two buttons together to reset,start and cycle
May 07, 2009 | Dishwashers
Clean light blinks constantly
press heated dry
press normal wash
press heated dry again
press normal wash again..........
.....wait a few seconds
all the lights should come on
press cancel (should hear pump)
hit cancel again
Hope this helps, it worked for me, but it may depend on your model.
Feb 05, 2009 | Kenmore Dishwashers
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Cancel Light Flashing on Kitchen Aid Dishwasher
I ran into this same problem. Cutting the power didnt reset it.
After power reset, mine had the normal led blinking. If I pressed cancel, then the cancel and china button leds would start blinking too.
I pulled out the trouble shooting guide (from behind the baseboard kick panel under the dishwasher door). It that if the dishwasher wont run and button LEDs are blinking there is a short circuit in the keypad. It gave a keypad diagnostic sequence which I followed. (disconnect keypad and try to initiate the diagnostic cycle without the keypad by disconecting the yellow leads to OWI sensor twice in less than 6 seconds.
I could hear the diagnostic cycle start, so the problem is a bad keypad. Will order a new one tomorrow and let you know if it works.
Sep 01, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Dishwashers Logo
48 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
