Question about Olympus Camedia C-350 Digital Camera
I've just bought a new DSLR Olympus camera and fully charged the battery. The camera switches on when there is no memory card inserted but as soon as I insert a memory card the camera won't switch on. If I remove the card and try to switch the camera on it still won't turn on, I have to remove the battery, put it back in then switch on the camera. Any ideas what's wrong?
    Brigadier General:
  • 11,967 Answers
If this is a brand new camera, it's supposed to work with no problems. Take it back.
Posted on Jun 04, 2010
The camera won't turn on and I know the battery is fully charged
Fully charged? or reached the correct voltage, without any charge? did you measure the voltage with a multi meter? and was it above the voltage printed on the battery? if it was exact the voltage or even one or 2 tenths of a volt lower, the battery is not good anymore. Then did you check the battery was inserted correct? and are the contacts clean and shiny? no debris in the battery housing? Just to mention some things you could check.
When you close the battery door, does it click? when closing (or opening) the battery door a switch is engaged (disengaged) to tel the logic, if the door is still closed. It will try to protect your memory card by blocking any memory access as soon as the door is opened. (It will not even start the camera as long as the door is open.)
Mar 05, 2015 | Olympus OM-D E-M1 Digital Compact System...
Even after putting a new fully charged battery camera shows battery empty
The reason you are still getting this error despite the fact that you've placed a new fully charged battery means that the battery is not compatible with the camera. The fact that it states this is because the battery isn't capable of handling the Olympus camera. I would suggest for you to buy a recommended battery pack by Olympus, or a rechargeable battery pack to avoid these errors.
Jun 30, 2011 | Olympus Cameras
I have a Kodak EasyShare C330. I have a new memory card Kodak SD Card 128MB. When I insert it in the camera, a message displays stating memory full. When I try to format the card to the camera I received...
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
Try to format the memmory card using a card reader and the PC this should solve your problem if not you have to replace the memmory card.
Mar 11, 2011 | Kodak EasyShare C330 Digital Camera
When turning camera on the shutter opens then shuts straight away and switches off
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 11, 2010 | Kodak EasyShare M863 Digital Camera
Camera switches on for a second and then swtches off btterey is fully charged
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 10, 2010 | Kodak EASYSHARE M1063 Digital Camera
When trying to charge battery green light flickers for hours
Jan 09, 2010 | Kodak EasyShare V1073 Digital Camera
Sony DSLR A100
Try a different CF card, preferably a new one.
Jul 06, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Camera does not work when memory card is inserted
just look in the slot for a short circuit. some times it does hapen on cf cards or on xd cards.
Jan 04, 2007 | Olympus EVOLT E-300 (Double Lens Kit)...
Camera still won't start...
hello, Dont worry lady, i think your problem is related to memory card. i suppose that you did not format memory card regularly, so format your memory card specific in your camera. and then try. i hope you deffinnately succeed. good luck...
Jul 30, 2006 | Olympus Camedia C-350 Digital Camera
Olympus Camedia C-350 Digital Camera Logo
89 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
