Question about Nokia 6133 Cellular Phone
Cannot get phone to ring only vibrate - Nokia 6133 Cellular Phone
  • carolinejinks
    carolinejinks Apr 13, 2014
    turn off vibrate and turn ring
  • carolinejinks
    i want to activate 7,000.00 aweek for life gwy no 3080 alert 1508
    Sniper:
  • 84 Answers
To change the Nokia 6133 to ring, do the following-
Select Menu > Settings > Profiles > Select any one profile that is available in your mobile. (Ex. General)
1. Menu > Settings > Profiles > General > Personalise > Incoming call Alert > Ringing
2. Menu > Settings > Profiles > General > Personalise > Vibratibng Alert > Off
After this activate the profile(Ex. General)
Menu > Settings > Profiles > General > Activate
After this the phone will only ring and wont vibrate.
If you want both then change the vibrating alert to On.
Good Luck.
Posted on Jun 07, 2010
I want to activate 7,000.00 aweek for life gwy no 3080
Posted on Apr 13, 2014
2 Suggested Answers
  • 99 Answers
SOURCE: ring vs vibrate
This phone allows you to independently set ring and vibrate modes. When you access "Call Vibrate" to set the mode, also visit the "Call Ringtone" menu to turn off the ringer.
You may want to leave the vibrate mode OFF and your ring tone ON and use the quick keys to switch between ring and vibrate. Two ways to do this, push and hold the # key to switch between normal mode (the settings you chose in "Call Ringtone" and "Call Vibrate") or use the side volume button to access the "Master Volume" and select "All Off", "Vibrate" or a ring tone volume.
If this helps you, please leave me a good rating.
Posted on Aug 17, 2008
My iphne 3 will only vibrate but not ring
If you're missing incoming phone calls due to your iPhone not ringing, you may have accidentally switched the ringer to vibrate or silent, according to Apple. The switch on the left side of the iPhone turns off the ringer and usually sets your phone to vibrate mode, but if your iPhone's vibrate setting is also disabled the phone will instead be set to silent mode. When in the phone's sound settings vibrate mode can be enabled, and the ringer volume of your phone is adjustable.
Read more: My iPhone Will Not Ring ' eHow.com http://www.ehow.com/how_7384812_iphone-not-ring.html#ixzz22OJOMZGR
Aug 02, 2012 | Apple iPhone 3G
Tip
BlackBerry Tour: How to make it ring and vibrate for incoming calls
You can customize your BlackBerry Tour so that either it rings when you get a phone call, or it vibrates -- or both. To make your phone both ring and vibrate when you get a call, go to your BlackBerry's sounds and ring tone options, which you can get to by either of the following two ways:
#1 - Use the trackball to go to the sound icon in the upper left corner of the main screen and click on it, then toward the bottom of the list that appears, select Set Ring Tones/Alerts, then select Phone.
#2 - On the main screen, press the BlackBerry button (the one with the seven dots) to take you to your Home folder. Scroll down to the Options folder (it's usually toward the bottom, and it has a wrench icon) and click on it, then select Sounds and Ring Tones.
From this scren you can select the ring tone that you want and adjust the ring tone volume. Then scroll down to Vibration and set it for On.
There is also an option for Vibrate with Ring Tone. If you turn this option on, the phone will both ring and vibrate at the same time when you get a call. If you turn it off, the phone will vibrate first, then ring. Either way, you'll get the ring and the vibration -- it's just a matter of whether they happen together or not. To see the difference between the two options, use the "Try it" option at the bottom of the screen.
When you've made the selections that you want, exit out of the options screen, but be sure to choose Save rather than Discard to save your changes.
on Jul 10, 2010 | RIM BlackBerry? Tour 9630 Smartphone
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
Message Vibration not working
make sure you have "txt messages" set to ring/vibe not "calls to line 1 ring/vibe"
May 29, 2009 | LG Shine KE970 Cellular Phone
Cant get the phone to ring. it is set to vibrate & ring but only vibrates
Set the ******** off and see if it rings otherwise try any ringtone as your default callertune and observe if the speakers ring. If not then best to take it to a technician...........sodeep
May 04, 2009 | Motorola Mobility W375 Cellular Phone
Setting Vibrate on an AX260 (LG Scoop)
Okay, here's your answer:
1. Open up your menu and go to "Settings"
2. Select "Sound"
3. Select "Alert Type"
4. And finally select ring and vibrate
Cheers!
Dec 12, 2008 | LG VX8300 Cellular Phone
Ring vs vibrate
Aug 17, 2008 | Samsung SCH-u340 Cellular Phone
Pantech C120
change the speaker on the phones and also have the ringer check on the main-board.
Mar 18, 2008 | Pantech C120 Cellular Phone
In vibrate mode, phone continues to vibrate after being answered
The phone is in "vibe then ring" mode.
Go to tools then ring styles using the "-" at the top center of the keypad. It will be set to vibe then ring, press "change" alter the style to vibe, vibe then ring, silent, loud or whatever you like. That is also where you find what ringtone is used for the ring.
Oct 30, 2007 | Motorola Mobility RAZR V3
Nokia 6133 Cellular Phone Logo
274 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
