Question about Dryers
Dryer fails to heat , When the starter is depressed, the dryer engages, but stops when the starter button is released. Dryer des not heat in any event
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. No Heat issue in dryer is usually caused due to three things mainly: Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which is mounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If that’s fine then the Heating Element should be checked. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 04, 2010
Dryer button won't engage
need to replace the push statt button as it is defective, confirm this with a meter test for ohms when pushed in
Aug 20, 2014 | Kenmore Dryers
GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Nov 25, 2007 | Kenmore 63932 Electric Dryer
Clothes Dryer won't stay on after switch is depressed.
some of them dryers have a switch other than the push button located behind the console. it also has an identical heat switch beside it. if that holding switch is bad it will not stay running. of the two identical switches the run switch is on the left. good kuck.
Jan 20, 2010 | Kenmore Dryers
Kenmore Elite Dryer, start button doesn't stay on
when I press and hold the start button it tumbles but not sure if it heats up. When I let go of button machine stops
Aug 16, 2009 | Kenmore 62602 Electric Dryer
Dryer starts but doesn't stay on
HI, this is a simple fix. replace the start button. the circuit has failed. it is no longer able to hold a closed circuit.
Jul 26, 2009 | Kenmore 63942 Dryer
Asko Dryer stops running when you release the start button.
Hi, this is a simple issue here. these switches will fail from time to time. the start switch is unable to hold the circuit, in return, opening it upon release of the button.
Simply replacing the switch will fix this issue. switch is 20 dollars tops.
May 28, 2009 | Asko T701 Electric Dryer
Dryer shuts off when let go of the on button
If the motor stops when the button is released check the motor relay switch. If the motor runs but the flame goes out check the flame sensor.
May 19, 2009 | Dryers
Won't start
IF ELECTRIC CHECK 220 VOLTS @PLUG MAKE SURE DOOR SWITCH IS FULLY ENGAGED
Nov 28, 2008 | Kenmore 73952 Gas Dryer
My Dryer will only work if I hold start button, when I release start button the dryer stops.
Anra, this is a classic symptom of a failed even heat board. I've seen a lot of these failures out there. Easy to change out. Check out this link. Catriver..post back http://www.repairclinic.com/0080.asp
Mar 26, 2007 | Whirlpool GEW9878LW Electric Dryer
Dryers Logo
18 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
