Question about LG CHOCOLATE VX8500 Cellular Phone
My phone brings up a message that the heat sensor is detecting high temperatures and recommends that I either move to a cooler location or remove the battery pack. I have done both of those things, and nothing changes.
  • 4,102 Answers
Hi, the problem you are having is to do with the phones circuit board components over heating so the phone gives you this warning to prevent damage being done to the phone,
the problem could either be with the phone or the battery so if the battery feels hot then this is what your going to need to get replaced how ever if the problem is with the phone then the chances are that it has over heated due to the heat seal compound failing and causing the phones processor to over heat.
now if that is the case and your battery is ok then the only thing you can do is take your phone in and ask them to check if any parts are now damaged and to replace the heat seal compound if thats all it needs.
their is no easy fix for this unless it is just the battery, how ever if the phone is in your pocket and the weather is hot then this can cause your phone to give you this warning, try leaving the battery out and the phone off for about 30min then put the battery back in and give it another try now if you get the same message strait away then this would indicate problem with the heat seal compound and this will need sending off to be done, if the message takes a while to appear then it may be that its the battery that needs replacing.
leave it off for 30min after you have given the phone a good clean and then see if you get the same message.
let me know how you get on or if you need further assistance ok
Posted on Jun 04, 2010
How to replace oil; cooler on this year
  • Service and Repair
Oil Cooler Replacement
Removal Procedure
  1. Raise and support the vehicle. Refer to Vehicle Lifting.
  2. Drain the engine oil and remove the oil filter housing.
89116492
  1. Loosen the oil cooler outlet (1) and the inlet (2) lines from the engine block.
  2. Lower the vehicle.
  3. Remove the intake plenum.
  4. Remove the intake manifold.
89116493
  1. Disconnect the following electrical connectors from the water crossover:
    • The engine coolant temperature sender (2)
    • The engine coolant temperature sensor (4)
84936658
  1. Remove the water crossover bolts (1).
  2. Remove the water crossover upper and lower seals (2).
84942881
  1. Loosen the upper heat shield bolts on the left side of the exhaust manifold.
89116496
  1. Remove the oil cooler outlet line from the engine oil cooler.
  2. Remove the oil cooler inlet line from the engine oil cooler.
84942883
  1. Note the positioning of the 4 seals.
84972057
  1. Position the oil feed and return,lines out of the way and secure with mechanic wire.
  2. Remove the engine oil cooler, inlet and outlet nuts (1).
  3. Remove the engine oil cooler cover bolts (2).
84942883
  1. Remove the engine oil cooler cover.
  2. Remove the engine oil cooler.
  3. Clean all sealing surfaces.
Installation Procedure
84972056
  1. Install the engine oil cooler.
  2. Apply a 2 mm (0.08 inch) bead of RTV silicone sealant, GM P/N 12346240, in the groove around the engine oil cooler cover.
  3. Install the engine oil cooler cover.
Notice: Refer to Fastener Notice in Service Precautions.
84972057
  1. Install the engine oil cooler cover bolts (2). Tighten the engine oil cooler cover bolts to 30 Nm (22 ft. lbs.).
  2. Install the engine oil cooler inlet and outlet nuts (1). Tighten the engine oil cooler inlet and outlet nuts to 20 Nm (15 ft. lbs.).
  3. Reposition the oil feed and return lines.
84942883
  1. Install the oil cooler outlet and install the oil cooler inlet lines to the engine oil cooler. Use 4 new seals.
Tighten the oil feed and return lines to 30 Nm (22 ft. lbs.).
84936658
  1. Install the water crossover:
    • Position the crossover.
    • Install the upper and lower seals (2).
    • Install the water crossover bolts (1). Tighten
Tighten the water crossover bolts to 30 Nm (22 ft. lbs.).
  1. Connect the electrical connectors at the following locations:
  1. Install the intake manifold.
  2. Install the intake plenum.
  3. Raise the vehicle.
89116492
  1. Install the oil cooler outlet (1) line to the engine block. Tighten the oil cooler outlet (1) line to 30 Nm (22 ft. lbs.).
  2. Install the oil cooler inlet (2) line to the engine block. Tighten the oil cooler inlet (2) line to 30 Nm (22 ft. lbs.).
  3. Install the oil filter housing to the engine block. Tighten the oil filter housing to 45 Nm (33 ft. lbs.).
  4. Lower the vehicle.
Dec 22, 2014 | 2001 Cadillac Catera
Where is the bank 1 sensor 1 air flow sensor located on a 2000 toyota avalon?
Sensor diagram for a 2000 toyota avalon and list of Pcodes dbd372cc-f8f3-49ef-b0c2-2adab46c4182.jpg 8fc069a5-bedc-447d-a1ef-4335798a0a0f.jpg
P0100 Mass or Volume Air Flow Circuit Malfunction
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
P0102 Mass or Volume Air Flow Circuit Low Input
P0103 Mass or Volume Air Flow Circuit High Input
P0104 Mass or Volume Air Flow Circuit Intermittent
P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
P0110 Intake Air Temperature Circuit Malfunction
P0111 Intake Air Temperature Circuit Range/Performance Problem
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0114 Intake Air Temperature Circuit Intermittent
P0115 Engine Coolant Temperature Circuit Malfunction
P0116 Engine Coolant Temperature Circuit Range/Performance Problem
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
P0119 Engine Coolant Temperature Circuit Intermittent
P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit Malfunction
P0121 Throttle/Pedal Position Sensor/Switch "A" Circuit Range/Performance Problem
P0122 Throttle/Pedal Position Sensor/Switch "A" Circuit Low Input
P0123 Throttle/Pedal Position Sensor/Switch "A" Circuit High Input
P0124 Throttle/Pedal Position Sensor/Switch "A" Circuit Intermittent
P0125 Insufficient Coolant Temperature For Closed Loop Fuel Control
P0126 Insufficient Coolant Temperature For Stable Operation
P0130 O2Circuit Malfunction (Bank #1 Sensor #1)
P0131 O2Sensor Circuit Low Voltage (Bank #1 Sensor #1)
P0132 O2Sensor Circuit High Voltage (Bank #1 Sensor #1)
P0133 O2Sensor Circuit Slow Response (Bank #1 Sensor #1)
P0134 O2Sensor Circuit No Activity Detected (Bank #1 Sensor #1)
P0135 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #1)
P0136 O2Sensor Circuit Malfunction (Bank #1 Sensor #2)
P0137 O2Sensor Circuit Low Voltage (Bank #1 Sensor #2)
P0138 O2Sensor Circuit High Voltage (Bank #1 Sensor #2)
P0139 O2Sensor Circuit Slow Response (Bank #1 Sensor #2)
P0140 O2Sensor Circuit No Activity Detected (Bank #1 Sensor #2)
P0141 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #2)
P0142 O2Sensor Circuit Malfunction (Bank #1 Sensor #3)
P0143 O2Sensor Circuit Low Voltage (Bank #1 Sensor #3)
P0144 O2Sensor Circuit High Voltage (Bank #1 Sensor #3)
P0145 O2Sensor Circuit Slow Response (Bank #1 Sensor #3)
P0146 O2Sensor Circuit No Activity Detected (Bank #1 Sensor #3)
P0147 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #3)
P0150 O2Sensor Circuit Malfunction (Bank #2 Sensor #1)
P0151 O2Sensor Circuit Low Voltage (Bank #2 Sensor #1)
P0152 O2Sensor Circuit High Voltage (Bank #2 Sensor #1)
P0153 O2Sensor Circuit Slow Response (Bank #2 Sensor #1)
P0154 O2Sensor Circuit No Activity Detected (Bank #2 Sensor #1)
P0155 O2Sensor Heater Circuit Malfunction (Bank #2 Sensor #1)
P0156 O2Sensor Circuit Malfunction (Bank #2 Sensor #2)
P0157 O2Sensor Circuit Low Voltage (Bank #2 Sensor #2)
P0158 O2Sensor Circuit High Voltage (Bank #2 Sensor #2)
P0159 O2Sensor Circuit Slow Response (Bank #2 Sensor #2)
P0160 O2Sensor Circuit No Activity Detected (Bank #2 Sensor #2)
P0161 O2Sensor Heater Circuit Malfunction (Bank #2 Sensor #2)
P0162 O2Sensor Circuit Malfunction (Bank #2 Sensor #3)
P0163 O2Sensor Circuit Low Voltage (Bank #2 Sensor #3)
P0164 O2Sensor Circuit High Voltage (Bank #2 Sensor #3)
P0165 O2Sensor Circuit Slow Response (Bank #2 Sensor #3)
P0166 O2Sensor Circuit No Activity Detected (Bank #2 Sensor #3)
P0167 O2Sensor Heater Circuit Malfunction (Bank #2 Sensor #3)
P0170 Fuel Trim Malfunction (Bank #1)
P0171 System Too Lean (Bank #1)
P0172 System Too Rich (Bank #1)
P0173 Fuel Trim Malfunction (Bank #2)
P0174 System Too Lean (Bank #2)
P0175 System Too Rich (Bank #2)
P0176 Fuel Composition Sensor Circuit Malfunction
P0177 Fuel Composition Sensor Circuit Range/Performance
P0178 Fuel Composition Sensor Circuit Low Input
P0179 Fuel Composition Sensor Circuit High Input
P0180 Fuel Temperature Sensor "A" Circuit Malfunction
P0181 Fuel Temperature Sensor "A" Circuit Range/Performance
P0182 Fuel Temperature Sensor "A" Circuit Low Input
P0183 Fuel Temperature Sensor "A" Circuit High Input
P0184 Fuel Temperature Sensor "A" Circuit Intermittent
P0185 Fuel Temperature Sensor "B" Circuit Malfunction
P0186 Fuel Temperature Sensor "B" Circuit Range/Performance
P0187 Fuel Temperature Sensor "B" Circuit Low Input
P0188 Fuel Temperature Sensor "B" Circuit High Input
P0189 Fuel Temperature Sensor "B" Circuit Intermittent
P0190 Fuel Rail Pressure Sensor Circuit Malfunction
P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
P0192 Fuel Rail Pressure Sensor Circuit Low Input
P0193 Fuel Rail Pressure Sensor Circuit High Input
P0194 Fuel Rail Pressure Sensor Circuit Intermittent
P0195 Engine Oil Temperature Sensor Malfunction
P0196 Engine Oil Temperature Sensor Range/Performance
P0197 Engine Oil Temperature Sensor Low
P0198 Engine Oil Temperature Sensor High
P0199 Engine Oil Temperature Sensor Intermittent
P0200 Injector Circuit Malfunction
P0201 Injector Circuit Malfunction - Cylinder #1
P0202 Injector Circuit Malfunction - Cylinder #2
P0203 Injector Circuit Malfunction - Cylinder #3
P0204 Injector Circuit Malfunction - Cylinder #4
P0205 Injector Circuit Malfunction - Cylinder #5
P0206 Injector Circuit Malfunction - Cylinder #6
P0207 Injector Circuit Malfunction - Cylinder #7
P0208 Injector Circuit Malfunction - Cylinder #8
P0209 Injector Circuit Malfunction - Cylinder #9
P0210 Injector Circuit Malfunction - Cylinder #10
P0211 Injector Circuit Malfunction - Cylinder #11
P0212 Injector Circuit Malfunction - Cylinder #12
P0213 Cold Start Injector #1 Malfunction
P0214 Cold Start Injector #2 Malfunction
P0215 Engine Shutoff Solenoid Malfunction
P0216 Injection Timing Control Circuit Malfunction
P0217 Engine Over Temperature Condition
P0218 Transmission Over Temperature Condition
P0219 Engine Over Speed Condition
P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit Malfunction
P0221 Throttle/Pedal Position Sensor/Switch "B" Circuit Range/Performance Problem
P0222 Throttle/Pedal Position Sensor/Switch "B" Circuit Low Input
P0223 Throttle/Pedal Position Sensor/Switch "B" Circuit High Input
P0224 Throttle/Pedal Position Sensor/Switch "B" Circuit Intermittent
P0225 Throttle/Pedal Position Sensor/Switch "C" Circuit Malfunction
P0226 Throttle/Pedal Position Sensor/Switch "C" Circuit Range/Performance Problem
P0227 Throttle/Pedal Position Sensor/Switch "C" Circuit Low Input
P0228 Throttle/Pedal Position Sensor/Switch "C" Circuit High Input
P0229 Throttle/Pedal Position Sensor/Switch "C" Circuit Intermittent
P0230 Fuel Pump Primary Circuit Malfunction
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0233 Fuel Pump Secondary Circuit Intermittent
P0234 Engine Over Boost Condition
P0261 Cylinder #1 Injector Circuit Low
P0262 Cylinder #1 Injector Circuit High
P0263 Cylinder #1 Contribution/Balance Fault
P0264 Cylinder #2 Injector Circuit Low
P0265 Cylinder #2 Injector Circuit High
P0266 Cylinder #2 Contribution/Balance Fault
P0267 Cylinder #3 Injector Circuit Low
P0268 Cylinder #3 Injector Circuit High
P0269 Cylinder #3 Contribution/Balance Fault
P0270 Cylinder #4 Injector Circuit Low
P0271 Cylinder #4 Injector Circuit High
P0272 Cylinder #4 Contribution/Balance Fault
P0273 Cylinder #5 Injector Circuit Low
P0274 Cylinder #5 Injector Circuit High
P0275 Cylinder #5 Contribution/Balance Fault
P0276 Cylinder #6 Injector Circuit Low
P0277 Cylinder #6 Injector Circuit High
P0278 Cylinder #6 Contribution/Balance Fault
P0279 Cylinder #7 Injector Circuit Low
P0280 Cylinder #7 Injector Circuit High
P0281 Cylinder #7 Contribution/Balance Fault
P0282 Cylinder #8 Injector Circuit Low
P0283 Cylinder #8 Injector Circuit High
P0284 Cylinder #8 Contribution/Balance Fault
P0285 Cylinder #9 Injector Circuit Low
P0286 Cylinder #9 Injector Circuit High
P0287 Cylinder #9 Contribution/Balance Fault
P0288 Cylinder #10 Injector Circuit Low
P0289 Cylinder #10 Injector Circuit High
P0290 Cylinder #10 Contribution/Balance Fault
P0291 Cylinder #11 Injector Circuit Low
P0292 Cylinder #11 Injector Circuit High
P0293 Cylinder #11 Contribution/Balance Fault
P0294 Cylinder #12 Injector Circuit Low
P0295 Cylinder #12 Injector Circuit High
P0296 Cylinder #12 Contribution/Balance Fault
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder #1 - Misfire Detected
P0302 Cylinder #2 - Misfire Detected
P0303 Cylinder #3 - Misfire Detected
P0304 Cylinder #4 - Misfire Detected
P0305 Cylinder #5 - Misfire Detected
P0306 Cylinder #6 - Misfire Detected
P0307 Cylinder #7 - Misfire Detected
P0308 Cylinder #8 - Misfire Detected
P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
P0325 Knock Sensor #1 - Circuit Malfunction (Bank #1 or Single Sensor)
P0326 nock Sensor #1 - Circuit Range/Performance (Bank #1 or Single Sensor)
P0327 Knock Sensor #1 - Circuit Low Input (Bank #1 or Single Sensor)
P0328 Knock Sensor #1 - Circuit High Input (Bank #1 or Single Sensor)
P0329 Knock Sensor #1 - Circuit Input Intermittent (Bank #1 or Single Sensor)
P0330 Knock Sensor #2 - Circuit Malfunction (Bank #2)
P0331 Knock Sensor #2 - Circuit Range/Performance (Bank #2)
P0332 Knock Sensor #2 - Circuit Low Input (Bank #2)
P0333 Knock Sensor #2 - Circuit High Input (Bank #2)
P0334 Knock Sensor #2 - Circuit Input Intermittent (Bank #2)
P0335 Crankshaft Position Sensor "A" Circuit Malfunction
P0336 Crankshaft Position Sensor "A" Circuit Range/Performance
P0337 Crankshaft Position Sensor "A" Circuit Low Input
P0338 Crankshaft Position Sensor "A" Circuit High Input
P0339 Crankshaft Position Sensor "A" Circuit Intermittent
P0340 Camshaft Position Sensor Circuit Malfunction
P0341 Camshaft Position Sensor Circuit Range/Performance
P0342 Camshaft Position Sensor Circuit Low Input
P0343 Camshaft Position Sensor Circuit High Input
P0344 Camshaft Position Sensor Circuit Intermittent
P0350 Ignition Coil Primary/Secondary Circuit Malfunction
P0351 Ignition Coil "A" Primary/Secondary Circuit Malfunction
P0352 Ignition Coil "B" Primary/Secondary Circuit Malfunction
P0353 Ignition Coil "C" Primary/Secondary Circuit Malfunction
P0354 Ignition Coil "D" Primary/Secondary Circuit Malfunction
P0355 Ignition Coil "E" Primary/Secondary Circuit Malfunction
P0356 Ignition Coil "F" Primary/Secondary Circuit Malfunction
P0357 Ignition Coil "G" Primary/Secondary Circuit Malfunction
P0358 Ignition Coil "H" Primary/Secondary Circuit Malfunction
P0359 Ignition Coil "I" Primary/Secondary Circuit Malfunction
P0360 Ignition Coil "J" Primary/Secondary Circuit Malfunction
P0361 Ignition Coil "K" Primary/Secondary Circuit Malfunction
P0362 Ignition Coil "L" Primary/Secondary Circuit Malfunction
P0370 Timing Reference High Resolution Signal "A" Malfunction
P0371 Timing Reference High Resolution Signal "A" Too Many Pulses
P0372 Timing Reference High Resolution Signal "A" Too Few Pulses
P0373 Timing Reference High Resolution Signal "A" Intermittent/Erratic Pulses
P0374 Timing Reference High Resolution Signal "A" No Pulses
P0375 Timing Reference High Resolution Signal "B" Malfunction
P0376 Timing Reference High Resolution Signal "B" Too Many Pulses
P0377 Timing Reference High Resolution Signal "B" Too Few Pulses
P0378 Timing Reference High Resolution Signal "B" Intermittent/Erratic Pulses
P0379 Timing Reference High Resolution Signal "B" No Pulses
P0380 Glow Plug/Heater Circuit "A" Malfunction
P0381 Glow Plug/Heater Indicator Circuit Malfunction
P0382 Glow Plug/Heater Circuit "B" Malfunction
P0385 Crankshaft Position Sensor "B" Circuit Malfunction
P0386 Crankshaft Position Sensor "B" Circuit Range/Performance
P0387 Crankshaft Position Sensor "B" Circuit Low Input
P0388 Crankshaft Position Sensor "B" Circuit High Input
P0389 Crankshaft Position Sensor "B" Circuit Intermittent
P0400 Exhaust Gas Recirculation Flow Malfunction
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P0402 Exhaust Gas Recirculation Flow Excessive Detected
P0403 Exhaust Gas Recirculation Circuit Malfunction
P0404 Exhaust Gas Recirculation Circuit Range/Performance
P0405 Exhaust Gas Recirculation Sensor "A" Circuit Low
P0406 Exhaust Gas Recirculation Sensor "A" Circuit High
P0407 Exhaust Gas Recirculation Sensor "B" Circuit Low
P0408 Exhaust Gas Recirculation Sensor "B" Circuit High
P0410 Secondary Air Injection System Malfunction
P0411 Secondary Air Injection System Incorrect Flow Detected
P0412 Secondary Air Injection System Switching Valve "A" Circuit Malfunction
P0413 Secondary Air Injection System Switching Valve "A" Circuit Open
P0414 Secondary Air Injection System Switching Valve "A" Circuit Shorted
P0415 Secondary Air Injection System Switching Valve "B" Circuit Malfunction
P0416 Secondary Air Injection System Switching Valve "B" Circuit Open
P0417 Secondary Air Injection System Switching Valve "B" Circuit Shorted
P0418 Secondary Air Injection System Relay "A" Circuit Malfunction
P0419 Secondary Air Injection System Relay "B" Circuit Malfunction
P0420 Catalyst System Efficiency Below Threshold (Bank #1)
P0421 Warm Up Catalyst Efficiency Below Threshold (Bank #1)
P0422 Main Catalyst Efficiency Below Threshold (Bank #1)
P0423 Heated Catalyst Efficiency Below Threshold (Bank #1)
P0424 Heated Catalyst Temperature Below Threshold (Bank #1)
P0430 Catalyst System Efficiency Below Threshold (Bank #2)
P0431 Warm Up Catalyst Efficiency Below Threshold (Bank #2)
P0432 Main Catalyst Efficiency Below Threshold (Bank #2)
P0433 Heated Catalyst Efficiency Below Threshold (Bank #2)
P0434 Heated Catalyst Temperature Below Threshold (Bank #2)
P0440 Evaporative Emission Control System Malfunction
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0442 Evaporative Emission Control System Leak Detected (Small Leak)
P0443 Evaporative Emission Control System Purge Control Valve Circuit Malfunction
P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction P0441 and/or P0446
Apr 02, 2014 | 2000 Toyota Avalon
Need codes for UBD2 reader
Try these.
P1000OBD-II Monitor Testing Incomplete
P1001KOER Test Cannot Be Completed
P1039Vehicle Speed Signal Missing or Improper
P1051Brake Switch Signal Missing or Improper
P1100Mass Air Flow Sensor Intermittent
P1101Mass Air Flow Sensor out of Self-Test Range
P1112Intake Air Temperature Sensor Intermittent
P1114Intake Air Temperature 2 Circuit Low Input
P1115Intake Air Temperature 2 Circuit High Input
P1116Engine Coolant Temperature Sensor is out of Self-Test Range
P1117Engine Coolant Temperature Sensor Intermittent
P1120Throttle Position Sensor out of range
P1121Throttle Position Sensor Inconsistent with Mass Air Flow Sensor
P1124Throttle Position Sensor out of Self-Test Range
P1125Throttle Position Sensor Intermittent
P1127Heated Oxygen Sensor Heater not on During KOER Test - Exhaust Not Warm Enough
P1129Upstream O2 Sensors Swapped Bank To Bank (HO2S-11-21)
P1130Lack of Upstream Heated Oxygen Sensor Switch - Adaptive Fuel Limit - Bank No. 1
P1131Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1
P1132Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 1
P1135Ignition Switch Signal Missing or Improper
P1137Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1
P1138Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 1
P1150Lack of Upstream Heated Oxygen Sensor Switch - Adaptive Fuel Limit - Bank No. 2
P1151Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2
P1152Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 2
P1157Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2
P1158Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 2
P1168FRP Sensor In Range But Low
P1169FRP Sensor In Range But High
P1180Fuel Delivery System Low
P1181Fuel Delivery System High
P1183EOT Sensor Circuit Malfunction
P1184EOT Sensor Out Of Range
P1220Series Throttle Control fault
P1224Throttle Position Sensor B out of Self-Test Range
P1229Supercharger Intercooler Pump Not Working
P1230Open Power to Fuel Pump circuit
P1231High Speed Fuel Pump Relay activated
P1232Low Speed Fuel Pump Primary circuit failure
P1233Fuel Pump Driver Module off-line
P1234Fuel Pump Driver Module off-line
P1235Fuel Pump Control out of range
P1236Fuel Pump Control out of range
P1237Fuel Pump Secondary circuit fault
P1238Fuel Pump Secondary circuit fault
P1244Generator Load Input Low
P1245Generator Load Input High
P1246Generator Load Input Failed
P1250Lack of Power to FPRC Solenoid
P1260Theft Detected - Engine Disabled
P1270Engine RPM or Vehicle Speed Limiter Reached
P1285Cylinder Head Over Temperature Sensed
P1288Cylinder Head Temperature Sensor out of Self-Test Range
P1289Cylinder Head Temperature Sensor Signal Greater Than Self-Test Range
P1290Cylinder Head Temperature Sensor Signal Less Than Self-Test Range
P1299Cylinder Head Temperature Sensor Detected Engine Overheating Condition
P1309Misfire Detection Monitor not enabled
P1336CKP and/or CMP Input Signal to PCM Concerns
P1351Ignition Diagnostic Monitor circuit Input fault
P1352Ignition Coil A - Primary circuit fault
P1353Ignition Coil B - Primary circuit fault
P1354Ignition Coil C - Primary circuit fault
P1355Ignition Coil D - Primary circuit fault
P1356Loss of Ignition Diagnostic Module Input to PCM
P1358Ignition Diagnostic Monitor Signal out of Self-Test Range
P1359Spark Output circuit fault
P1364Ignition Coil Primary circuit fault
P1380Variable Cam Timing Solenoid A Circuit Malfunction
P1381Variable Cam Timing Over-advanced (Bank 1)
P1383Variable Cam Timing Over-retarded (Bank 1)
P1390Octane Adjust out of Self-Test Range
P1400Differential Pressure Feedback Electronic Sensor circuit Low Voltage
P1401Differential Pressure Feedback Electronic Sensor circuit High Voltage
P1403Differential Pressure Feedback Electronic Sensor Hoses Reversed
P1405Differential Pressure Feedback Electronic Sensor circuit Upstream Hose
P1406Differential Pressure Feedback Electronic Sensor circuit Downstream Hose
P1407EGR No Flow Detected
P1408EGR Flow out of Self-Test Range
P1409EGR Vacuum Regulator circuit malfunction
P1410EGR Barometric Pressure Sensor VREF Voltage
P1411Secondary Air is not being diverted
P1413Secondary Air Injection System Monitor circuit Low Voltage
P1414Secondary Air Injection System Monitor circuit High Voltage
P1432THTRC Circuit Failure
P1436A/C Evaporator Temperature Circuit Low Input
P1437A/C Evaporator Temperature Circuit High Input
P1442Secondary Air Injection System Monitor circuit High Voltage
P1443Evaporative Emission Control System - Vacuum System - Purge Control Solenoid or Purge Control Valve fault
P1444Purge Flow Sensor circuit Input Low
P1445Purge Flow Sensor circuit Input High
P1450Inability of Evaporative Emission Control System to Bleed Fuel Tank
P1451EVAP Control System Canister Vent Solenoid Circuit Malfunction
P1452Inability of Evaporative Emission Control System to Bleed Fuel Tank
P1455Substantial Leak or Blockage in Evaporative Emission Control System
P1460Wide Open Throttle Air Conditioning Cutoff circuit malfunction
P1461Air Conditioning Pressure Sensor circuit Low Input
P1462Air Conditioning Pressure Sensor circuit high Input
P1463Air Conditioning Pressure Sensor Insufficient Pressure change
P1464ACCS to PCM High During Self-Test
P1469Low Air Conditioning Cycling Period
P1473Fan Secondary High with Fans Off
P1474Low Fan Control Primary circuit
P1477MFC Primary Circuit Failure
P1479High Fan Control Primary circuit
P1480Fan Secondary Low with Low Fans On
P1481Fan Secondary Low with High Fans On
P1483Power to Cooling Fan Exceeded Normal Draw
P1484Variable Load Control Module Pin 1 Open
P1500Vehicle Speed Sensor (VSS) Intermittent
P1501Programmable Speedometer & Odometer Module/Vehicle Speed Sensor (VSS) Intermittent circuit-failure
P1502Invalid or Missing Vehicle Speed Message or Brake Data
P1504Intake Air Control circuit malfunction
P1505Idle Air Control System at Adaptive Clip
P1506Idle Air Control Over Speed Error
P1507Idle Air Control Under Speed Error
P1512Intake Manifold Runner Control Stuck Closed
P1513Intake Manifold Runner Control Stuck Closed
P1516Intake Manifold Runner Control Input Error
P1517Intake Manifold Runner Control Input Error
P1518Intake Manifold Runner Control fault - Stuck Open
P1519Intake Manifold Runner Control fault - Stuck Closed
P1520Intake Manifold Runner Control circuit fault
P1530Open or Short to A/C Compressor Clutch circuit
P1537Intake Manifold Runner Control Stuck Open
P1538Intake Manifold Runner Control Stuck Open
P1539Power to A/C Compressor Clutch circuit Exceeded Normal Current Draw
P1549Intake Manifold Temperature Valve Vacuum Actuator Connection
P1550Power Steering Pressure Sensor out of Self-Test Range
P1572Brake Pedal Switch Circuit
P1605PCM Keep Alive Memory Test Error
P1625Voltage to Vehicle Load Control Module Fan circuit not detected
P1626Voltage to Vehicle Load Control Module circuit not detected
P1633Keep Alive Power Voltage Too Low
P1635Tire/Axle Out Of Acceptable Range
P1636Inductive Signiture Chip Communication Error
P1639Vehicle ID Block Not Programmed Or Corrupt
P1640DTC\'s Available In Another Module
P1650Power Steering Pressure Switch out of Self-Test Range
P1651Power Steering Pressure Switch Signal Malfunction
P1700Transmission system problems
P1701Reverse Engagement Error
P1702Transmission system problems
P1703Brake On/Off Switch out of Self-Test Range
P1704Transmission system problems
P1705Transmission Range Sensor out of Self-Test Range
P1709Park or Neutral Position Switch out of Self-Test Range
P1710Transmission system problems
P1711Transmission Fluid Temperature Sensor out of Self-Test Range
P1713Transmission system problems
P1714Transmission system problems
P1715Transmission system problems
P1716Transmission system problems
P1717Transmission system problems
P1718Transmission system problems
P1719Transmission system problems
P1720Transmission system problems
P17294x4 Low Switch Error
P1740Transmission system problems
P1741Torque Converter Clutch Control Error
P1742Torque Converter Clutch Solenoid Faulty
P1743Torque Converter Clutch Solenoid Faulty
P1744Torque Converter Clutch System Stuck in Off Position
P1745Transmission system problems
P1746Electronic Pressure Control Solenoid - Open circuit
P1747Electronic Pressure Control Solenoid - Short circuit
P1749Electronic Pressure Control Solenoid Failed Low
P1751Shift Solenoid No. 1 Performance
P1754Coast Clutch Solenoid circuit malfunction
P1756Shift Solenoid No. 2 Performance
P1760Transmission system problems
P1761Shift Solenoid No. 3 Performance
P1762Transmission system problems
P1767Transmission system problems
P1780Transmission Control Switch circuit is out of Self-Test Range
P17814x4 Low Switch is out of Self-Test Range
P1783Transmission Over-Temperature Condition
P1784Transmission system problems
P1785Transmission system problems
P1786Transmission system problems
P1787Transmission system problems
P1788Transmission system problems
P1789Transmission system problems
P1900Transmission system problems
Mar 25, 2013 | Ford Vehicle Parts & Accessories
I have p044 code for Camry 2004
P0044 - HO2S Heater Control Circuit High (Bank 1 Sensor 3)
The P0044 is set when the ECM detects an excessively high voltage through the heated oxygen sensor heater circuit
Oxygen Sensors (O2S) or Heated Oxygen Sensors (HO2S) need to reach a minimum operating temperature of 750 degrees F to produce an accurate voltage signal. The faster the heated oxygen sensor reaches that temperature the faster the sensor will start sending an accurate signal to the Engine Control Module (ECM).
In order to achieve the require temperature, a heater element is included inside the heated oxygen sensor. The ECM controls the heated oxygen sensor heater element based on signals from the engine coolant temperature and engine load. The ECM controls the heater element circuit by allowing current flow to ground.
Symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
Possible causes
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 3 circuit open shorted to ground
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 3 circuit poor electrical connection
- Faulty Heated Oxygen Sensor (H2OS) Bank 1 Sensor 3 circuit
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 3 circuit fuse
- Faulty Engine Control Module (ECM)
The ECM monitors the voltage signal received through the heater element circuit and determines the state of the circuit by comparing the voltage detected with the factory specifications.
Hope helps (remember to rate this answer).
Mar 15, 2011 | 2004 Toyota Camry
My LG enV VX9900 Cellular Phone is overheated
Definitley your batery had developed reverse polarity and so it will not reain or take in charge. hence the battery will consume more power resulting in this message and it might alsoo be dangerous to keep this on. I would advise you to put in new battery and do the intial charging as required. Keep it on for 8-12 hours of chrage then discharge offf in use fully and rechage again. Repeat this for three time before your battery becomes fully functional. hope this helps. Good day
Jul 22, 2010 | LG Cell Phones
96 cherokee xj trouble codes list?
The error codes are given below
1192 Inlet air temperature sensor voltage is wrong
1193 Inlet air temperature sensor voltage is wrong
1194 Oxygen sensor heater performance is faulty
1195 Oxygen sensor is slow
1196 The oxygen sensor switched too slowly (bank 2).
1197 The oxygen sensor switched too slowly (bank 1).
1198 Radiator coolant temperature sensor voltage is wrong.
1199 Radiator coolant temperature sensor voltage is wrong.
1281 The engine is staying cold too long - check your thermostat.
1282 The fuel pump relay circuit seems to be having a problem.
1288 The intake manifold short runner tuning valve circuit seems to be having a problem.
1289 There's a problem in the manifold tuning valve solenoid control circuit.
1290 Compressed natural gas system pressure is too high
1291 The heated air intake sensor does not seem to be working.
1292 Natural gas pressure sensor issue
1293 Natural gas pressure sensor issue
1294 Can't get to target engine speed, check for vacuum leaks and idle speed motor issues.
1295 The throttle position sensor doesn't seem to be getting enough electricity.
1296 The MAP sensor doesn't seem to be getting enough electricity.
1297 The MAP sensor doesn't change its reading when the engine is running!
1298 During wide-open throttle, the engine runs lean.
1299 MAP Sensor and Throttle Position Sensor signals don't match, check for a vacuum leak.
1388 Auto shutdown relay circuit problems?
1389 No Z1 or Z2 voltage seen by the computer when the auto shutdown relay is used.
1390 Cam and crank signals don't match - did the timing belt skip a tooth?
1391 Sometimes, I can't see the crank or cam sensor signal.
1398 I can see the Crank Sensor's signal when I prepare for Misfire Diagnostics. Try replacing it.
1399 Problem in the Wait to Start Lamp circuit - (diesels only?)
1403 EGR position sensor not getting (enough) voltage.
1476 Too little secondary air injection during aspirator test.
1477 Too much secondary air injection during aspirator test.
1478 Battery temperature sensor voltage wrong.
1479 Transmission fan relay circuit problems?
1480 PCV solenoid circuit problems?
1481 Transmission RPM pulse generator signal for misfire detection seems wrong.
1482 Catalyst temperature sensor circuit shorted low.
1483 Catalyst temperature sensor circuit shorted high.
1484 The catalyst seems to be overheating!
1485 Air injection solenoid circuit problems.
1486 Pinched or blocked hose in the evaporative hose system.
1487 Control circuit of the #2 high-speed radiator fan control relay is having problems.
1488 Auxiliary 5-volt sensor feed is too low.
1489 High speed radiator fan control circuit problem.
1490 Low speed radiator fan control circuit problem.
1491 Radiator fan control circuit problem (may be solid state relays as well as other circuits).
1492 Ambient or battery temperature sensor voltage wrong
1493 Ambient or battery temperature sensor voltage wrong
1494 Leak Detection Pump (LDP) pressure switch problem - electrical or the pump itself.
1495 Leak Detection Pump (LDP) pressure switch problem - the solenoid circuit.
1496 Sensor feed is below an acceptable limit. (under 4v for 4 seconds - should be 5v).
1498 High speed radiator fan control circuit problem. (#3 control relay)
1594 Voltage too high in charging system.
1595 Speed control vacuum or vent solenoid control circuits shorted or lost.
1596 Speed control switch always high
1597 Speed control switch always low
1598 A/C pressure sensor voltage high
1599 A/C pressure sensor voltage low
1681 No messages received from the cluster control module (dashboard computer).
1682 Charging system doesn't seem to be working well. Check alternator, etc.
1683 Speed control servo power control circuit problem.
1684 The battery has been disconnected within the last 50 starts.
1685 Invalid key received from the Smart Key Immobilizer Module.
1686 No messages received from the Smart Key Immobilizer Module.
1687 No messages received from the Mechanical Instrument Cluster module.
1 693 The companion engine control module has shown a fault.
1694 No messages received from the powertrain control module-Aisin transmission.
1695 No messages received from the body control module.
1696 Unsuccessful attempt to write to an EEPROM location!
1697 Unsuccessful attempt to update Service Reminder Indicator (SRI or EMR) mileage!
1698 No messages received from the electronic transmission control module or the Aisin transmission controller.
1719 Transmission 2-3 gear lockout solenoid control circuit problem.
1740 Either the tcc solenoid or overdrive solenoid systems doesn't seem to be making much sense.
1756 Transmission control pressure not equal to target. (Mid pressure problem)
1757 Transmission control pressure not equal to target. (Zero pressure problem)
1762 The Governor Pressure Sensor input was too high or too low for 3 consecutive park/neutral calibrations.
1763 The Governor Pressure Sensor input is too high
1764 The Governor Pressure Sensor input is too low.
1765 Open or short in the Transmission Relay control circuit.
1899 The Park/Neutral switch seems to be stuck!
Jul 18, 2010 | Directed Electronics Dei '96 To '98 Jeep...
'coolant sensor bad' message flahses on lcd panel.
The coolant temperature sensor is most commonly located near the thermostat housing. It will have 2 wires connecting it. Don't confuse this sensor with the coolant temp sending unit that controls your gauge temp, which generally has 1 wire connecting to it. Removal and replacement of the coolant temp sensor is fairly simple and best of all, it's cheap. You'll pay maybe $15-$20 for it and I would HIGHLY recommend replacing it! It is arguably the most important sensor on your vehicle, as it tells the computer how rich/lean to run the engine based on its temperature. As it ages, the thermistor inside the sensor can tend to run out of calibration and may cause the computer to think the engine is much warmer or cooler than it really is. This can lead to hard starting, rough operation, overly rich/lean fuel mixture, etc.
I hope this helps! Please let me know if I can be of further assistance in this matter. :)
Nov 14, 2009 | 1997 Jeep Grand Cherokee
2003 corolla heater temperature varies
check your in cabin air filter located behing the glove compartment. see your owner's manual for directions.
When this filter gets clogged air flow is restricted. You can blow the filter out with compressed air or replace. make sure you put in right side up.
Mar 14, 2009 | 2003 Toyota Corolla
Faulty battery perhaps
It could be either with water damage, and if the phone is still wet inside it will overheat by plugging it in.
Get a bowl of rice, remove the battery and leave the back of the phone open. Put both battery and phone in bowl of rice and leave covered overnight. The rice will soak up any water in the phone or battery.
If this doesn't work the phone has permanent water damage and will need to be replaced.
Mar 01, 2009 | LG CHOCOLATE VX8500 Cellular Phone
2002 Grand Cherokee Heated Seats don't work
I will post it in 2 different posts because its too long DB
HEATED SEAT SYSTEM
Individually controlled driver and passenger side electrically heated front seats are available factoryinstalled optional equipment on this model, when it is also equipped with the power seat option. The heated seat system allows both the driver and the front seat passenger the option to select one of two seat heating ranges, Low or High, or to turn the individual seat heaters OFF using the heated seat switches located in the center lower bezel near the bottom of the instrument panel center stack. The heated seat switch circuit operates on ignition switched battery current supplied through a fuse in the junction block, only when the ignition switch is in the ON position.
The heated seat system consists of the following components
  • Heated seat elements
  • Heated seat sensors
  • Heated seat module (or memory heated seat module)
  • Heated seat switches.
The heated seat system also relies upon resources shared with other electronic modules in the vehicle over the Programmable Communications Interface (PCI) data bus network. The PCI data bus network allows the sharing of sensor information. This helps to reduce wire harness complexity, internal controller hardware, and component sensor current loads. At the same time, this system provides increased reliability enhanced diagnostics, and allows the addition of many new feature capabilities. For diagnosis of these electronic modules or of the PCI data bus network, the use of a DRB scan tool and the proper Diagnostic Procedures are recommended.
The electronic modules that may affect heated seat system operation are as follows:
  • Body Control Module (BCM) - Refer to Body Control Module in Electronic Control Modules for more information.
  • Heated Seat Module (HSM) - Refer to Heated Seat Module in Electronic Control Modules for more information.
  • Memory Heated Seat Module (MHSM) - If the vehicle is equipped with the Memory System, refer to Memory Seat Module in Electronic Control Modules for more information.
Refer to Power Seats Premium I/III in the Contents of Wiring Diagrams for complete circuit diagrams. Following are general descriptions of the major components in the heated seat system.
The heated seat system will only operate when the ignition switch is in the ON position, and the surface temperature at the front seat heating element sensors is below the designed temperature set points of the system. The heated seat system will not operate in ambient temperatures greater than about 41 °C (105 °F) . The front seat heating elements and sensors are hard wired to the Heated Seat Module (HSM) or the Memory Heated Seat Module (MHSM).
The heated seat switches are hard wired to the Body Control Module (BCM). The BCM monitors the heated seat switch inputs, then sends heated seat switch status messages to the HSM or MHSM over the Programmable Communications Interface (PCI) data bus. The HSM or MHSM contains the control logic for the heated seat system. The HSM or MHSM responds to the heated seat switch status messages, ignition switch status messages, and the front seat heating element sensor inputs by controlling the output to the front seat heating elements through integral solid-state relays.
When a seat heater is turned ON, the sensor located on the seat cushion electric heater element provides the HSM or MHSM with an input indicating the surface temperature of the seat cushion. If the surface temperature input is below the temperature set point for the selected Low or High heated seat switch position, the HSM or MHSM energizes the integral solid-state relay, which supplies battery current to the heating elements in the seat cushion and back. When the sensor input indicates the correct temperature set point has been achieved, the HSM or MHSM de-energizes the solid-state relay. The HSM or MHSM will continue to cycle the solid-state relay as needed to maintain the temperature set point.
The HSM or MHSM and the seat heater elements operate on non-switched battery current supplied through the power seat circuit breaker in the junction block. However, the HSM or MHSM will automatically turn OFF the heating elements if it detects an open or short in the sensor circuit, a short or open in the heating element circuit causing an excessive current draw, or when the ignition switch is turned to the OFF position.
See the owner's manual in the vehicle glove box for more information on the features, use and operation of the heated seat system.
I WILL POST THE REST
Jan 31, 2009 | 2002 Jeep Grand Cherokee
LG CHOCOLATE VX8500 Cellular Phone Logo
49 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
